1. evoldroid's Avatar
    Can someone provide a link to where I can get the android sdk to install on my computer.please be patient guys this is my first time doing it.And the link that shows how to do it is like a Chinese map to me I'm lost.But I refuse to give up until my nexus s 4g is rooted.
    07-25-2011 08:35 PM
  2. piaband's Avatar
    I'm having similar problems. I think I'm fairly computer literate but I have not been able to root my nexus, even though its the "easiest" one to root.
    Alot of times I assn following a tutorial and the links don't work.
    I even had problems running the one click root method
    Can't someone put together a tutorial that is easy to follow and has active links?
    Sent from my Nexus S 4G using Tapatalk
    07-25-2011 10:06 PM
  3. evoldroid's Avatar
    There should be something that has all the links and instructions for people like us lol.I will get it tomorrow I won't let it win lol
    07-25-2011 10:40 PM
  4. Shabbypenguin's Avatar
    you dont need teh sdk, use the one click.. there is even a video on how to use it
    it has drivers for you in there incase you cant find any.. the only thing you need to worry about is if you have windows 32 bit or windows 64 bit...
    07-25-2011 11:07 PM
  5. piaband's Avatar
    I did try it, I had a problem. Posted it in the main thread for the one click root
    07-25-2011 11:18 PM
