1. evoldroid's Avatar
    I just rooted my nexus s 4 g first root ever.I am really new at this.Can some one supply a link and step by step directions on how to overclock my phone.I did the one step method to root my phone if that helps any.Thanks in advance
    07-27-2011 07:33 PM
  2. digitalslacker's Avatar
    start by finding a good kernel to install. I like Matr1x.
    I don't believe you an OC without a custom kernel.
    honestly, I don't really notice any difference between 1.0 and 1.44 for day to day use. I stay at 1.0.
    07-27-2011 07:56 PM
  3. crzycrkr's Avatar
    Yeah, you need to flash a kernel. I prefer Matr1x as well. I leave it at the default setting, which is 1200
    07-27-2011 08:11 PM
  4. beezy's Avatar
    First you will need to unlock and flash custom recovery if you haven't yet follow the great sticky by ksmith,if you have custom recovery then go http://forums.androidcentral.com/spr...tml#post945889 foloow the links. Download a custom kernel cause stock can't be overclocked.
    To install
    -boot into recovery
    -make nadroid backup
    -flash custom kernel,zip
    -reboot phone
    -install one of the overclocking apps, (i prefer setcpu)
    -Overclock and enjoy.
    07-29-2011 03:56 AM
  5. evoldroid's Avatar
    how do you know if your really overclocked? Is there a way to check it once done?
    07-29-2011 05:38 AM
  6. enik's Avatar
    You need to use a program to overclock. Personally I recommend CPU Master Free. It allows you to set the mhz. For example I usually have my phone clocked at 100-800 mhz unless I am gaming.
    07-29-2011 06:13 AM
  7. DeathsArrow's Avatar
    SetCPU will tell you what the processor is currently running at as well as stats to how long the CPU has stayed at each clock speed.
    07-29-2011 07:47 AM
