I did the One-click-Root and then got the update OTA and let it install, but now I'm on the exclamation point/android guy screen and can't do anything!
What do I do?
What do I do?
I did the update and lost Clockwork Mod. I re-downloaded ROM Manager and it won't flash Clockwork for me, please help.You're in stock recovery. You lost Clockwork Mod. just reflash that and superuser.
are you locked or unlocked?I did the update and lost Clockwork Mod. I re-downloaded ROM Manager and it won't flash Clockwork for me, please help.
I am unlocked. The power up screen still shows an unlocked icon. I didn't know that I have to re-root after an update....are you locked or unlocked?
you lose root if you install the Over the Air update.I am unlocked. The power up screen still shows an unlocked icon. I didn't know that I have to re-root after an update....
just run the new one click 2.0 it will get ya up and runnign again
All the information and pros and cons are out there.Never rooted before and am considering trying one click. Are there any negative side effects of using this process? Any problems at all? If not, do you happen to have a link to the new one click 2.0? Sorry for all the noob questions and concerns.
My question was not so much about the pros and cons of rooting, but rather the pros and cons of using the one-click method. Now worries, among other reasons, I am considering rooting because I feel that it will allow me to more fully use my phone. One of the advantages of the Nexus is that it is (supposedly, lol) easy to root and I would like to learn.All the information and pros and cons are out there.
The original problem in this thread was warned about time and time again throughout the various threads regarding the update. If people are going to jump into modding, they should be a bit more thorough in their research before clicking OK.
My opinion, of course.
Can I ask why you even want to root if you don't already have an idea of the negatives and positives?
http://forums.androidcentral.com/sprint-nexus-s-4g-rooting-roms-hacks/
The only disadvantage to the One Click method is not learning how to do it the long way by yourself.My question was not so much about the pros and cons of rooting, but rather the pros and cons of using the one-click method. Now worries, among other reasons, I am considering rooting because I feel that it will allow me to more fully use my phone. One of the advantages of the Nexus is that it is (supposedly, lol) easy to root and I would like to learn.
I guess it doesn't matter either way because even when spoon fed there are still hiccups.But if you'll never have to do it the long way.... what is the con in that? Lol.
