1. vertigosrs's Avatar
    So for some reason BLN randomly stopped working. I'm using pete's kernel and the latest version of miui and things have been fine until yesterday I noticed BLN wasn't working. I went into the BLN control and it says: The BLN mod is not installed. Do you like to open a website to get help? Anyone else experiencing problems or have any idea why this is happening?
    09-02-2011 06:17 AM
  2. tony1208's Avatar
    His kernel doesn't support bln yet..
    Sent from my Asus Transformer Tab
    09-02-2011 12:47 PM
  3. dammitcubs's Avatar
    His kernel does support it. GPA17 + BLN control works just fine on my phone. Just get the official release to be safe
    09-02-2011 01:22 PM
  4. vertigosrs's Avatar
    I thought the GPA17 was his rom?
    09-02-2011 01:24 PM
  5. digitalslacker's Avatar
    His kernel support BLN
    His ROM, GPA17, uses his kernel, which supports BLN
    I'm running GPA17 and needed to install BLN Control from the market in order to get BLN working. Now that was 3 builds ago, so I'm not sure if anything has changed since then.
    You said you are running MIUI so I'm not sure if that complicates things at all.
    hope that helps!
    09-02-2011 03:56 PM
