Source/Link: [KERNEL]*Matr1x* Kernels
Designer: mathkid95
ICS Kernel Features
- Based on Linux kernel version 3.0.32
- I/O Backport from 3.2 kernel (Thanks to franciscofranco)
- OC to 1.46 Ghz
- Voodoo sound and color (Thanks to supercurio)
- BLN (Thanks to neldar)
- BFS (Thanks to Con Kolivas) + -ck tweaks
- SLQB memory allocator
- Deadline, SIO, and BFQ I/O Schedulers
- Additional governors (Smartassv2, Lazy, Minmax, InteractiveX, Lulzactivev2, Intellidemand, Wheatley, Savaged-Zen)
- Stochastic Fair Blue (Internet packet queue management algorithm)
- CIFS, TUN, NFS
- USB OTG (Thanks sztupy!)
- KSM (Kernel SamePage Merging)
**Ezekeel's mods** (Thanks to Ezekeel)
- LiveOC
- BLX
- BLD
- Ezekeel's voltage mod
- Touch Wake
- Bigmem
Changelog:
Changelog:
v11.0 Applied pvr and mxt patches to Matr1x gingerbread source for ICS compatability.
v11.5 Applied all of the updated ICS patches from Kwiboo and fixed BLN.
v12.0 Fixed the wifi for alpha12+ compatibility, added Ezekeel's bigmem mod, and updated his liveoc mod.
v12.5 ICS 4.0.3 compatibilty and any Ezekeel mod updates.
v13.0 Fixed the YouTube video decoding, added voodoo, and uploaded wifi script for Iran i9023 users (thanks Alireza Asgari!).
v13.5 Added the 100% "battery tweak", patched up to 3.0.14, added the LagFree and InteractiveX governors, BLN app support, INIT.D support, and any Ezekeel bug fixes.
v14.0 Added the Lulzactive governor and fixed the deep idle wake issue.
v14.5 Added SIO I/O Scheduler, Lulzactivev2 governor, BLN blink interval code, and green screen fix.
v15.0 Updated kernel base to 3.0.17, added the Wheatley governor by Ezekeel, BFQ, USB OTG support, and any Ezekeel bug fixes.
v15.5 Updated kernel base to 3.0.18, I/O Backport from 3.2 kernel, USB OTG build 5, some ext4 tweaks, conservative governor + tweaks, and v? I/O scheduler.
v16.0 Fixed the 0.00B ram issue, updated kernel base to 3.0.19, removed deep idle and added cpuidle backport from 3.2 kernel, added the Intellidemand governor, and added some various performance tweaks.
v16.5 Put deep idle back in, added some performance tweaks, added any ezekeel bug fixes, updated kernel to 3.0.20, and added the Lionheart governor.
v17.0 Updated kernel base to 3.0.21, added KSM (Thanks morfic), and added some performance tweaks.
v17.5 Updated kernel base to 3.0.22, added the smartassv2 bug fix by abev66, added the Savaged-Zen governor (Thanks Savaged-Zen team), and added some performance tweaks.
v18.0 Updated kernel base to 3.0.24, added byeonggon's Selective LiveOC, added SWAP capabilities (Thanks for the 55swap script imoseyon), and added some performance tweaks.
v18.5 Updated kernel base to 3.0.26, added Fast Charge by Chad Froebel (Be sure to get his widget here: https://play.google.com/store/apps/d...stchargewidget), removed SWAP due to lag, and added some performance tweaks.
v19.0 Updated kernel base to 3.0.28, added the updated SIO I/O Scheduler, added the 4.0.4 ICS code, added the Bigmem mod from the CM9 kernel, and added some performance tweaks.
v19.5 Updated kernel base to 3.0.30, fixed the ondemand sampling rate issue, added CM9 wifi support, and added some performance tweaks.
v20.0 Updated kernel base to 3.0.32, changed the refresh rate to 50Hz, added some performance tweaks, and changed some governor tunables.
Links to ICS version:
v16.5 zips:
CFS Matr1x-cfs_v16.5.zip
BFS Matr1x-bfs_v16.5.zip
v16.0 zips:
CFS: https://goo.gl/rs38q
BFS: https://goo.gl/syIlW
v15.5 zips:
CFS: https://goo.gl/Q7OLS
BFS: https://goo.gl/VfTur
v15.0 zips:
CFS: https://goo.gl/pd7kv
BFS: https://goo.gl/B8LQS
v14.5 zips:
CFS: https://goo.gl/nEHrR
BFS: https://goo.gl/JAcH7
CFS - colors: http://derekcwilkinson.com/Matr1x-cfs_v14.5-colors.zip
BFS - colors: https://goo.gl/XCssz
v14.0 zips:
CFS: https://goo.gl/21YX5
BFS: https://goo.gl/jlkXa
v13.5 zips:
CFS: https://goo.gl/gJ0gD
BFS: https://goo.gl/5x3pk
v13.0 zips:
CFS: Matr1x-cfs_v13.0.zip
BFS: Matr1x-bfs_v13.0.zip
v12.5 zips:
CFS: Matr1x-cfs_v12.5.zip
BFS: Matr1x-bfs_v12.5.zip
v12.0 zips:
CFS: Matr1x-cfs_v12.0.zip
BFS: Matr1x-bfs_v12.0.zip
Gingerbread Based Kernels Below
v11.5 zips:
CFS: Matr1x-cfs_v11.5-ics.zip
BFS: Matr1x-bfs_v11.5-ics.zip
v11.0 zips:
CFS: Matr1x-cfs_v11.0-ics.zip
BFS: Matr1x-bfs_v11.0-ics.zip
Note: Download links are used and listed with permission from mathkid95. Thank you mathkid
Designer: mathkid95
ICS Kernel Features
- OC to 1.46 Ghz
- CIFS, TUN, NFS
- LiveOC
- BLX
- BLD
- Touch Wake
- Bigmem
Changelog:
Changelog:
v16.5 zips:
v16.0 zips:
v15.5 zips:
v15.0 zips:
v14.5 zips:
v14.0 zips:
v13.5 zips:
v13.0 zips:
v12.5 zips:
v12.0 zips:
v11.5 zips:
v11.0 zips:
