11-15-2011 09:48 PM
2,282 ... 1920212223 ...
tools
  1. wesdwilliams's Avatar
    if u have the NS4G the wifi works doesnt matter what kernel you have...
    10-25-2011 04:32 AM
  2. MrHaxx1's Avatar
    so the wifi works fine without netarchy kernel?
    Yup. At first it didn't get the IP address, then I set it to forget the network, connected again and it worked.
    nkhs9412235 likes this.
    10-25-2011 04:32 AM
  3. wesdwilliams's Avatar
    Has anybody played around with the camera on this rom and had any issues????
    10-25-2011 04:33 AM
  4. faizalmzain's Avatar
    mine seems to stuck at google logo for quite sometime.
    on nexus s.
    10-25-2011 04:36 AM
  5. MrHaxx1's Avatar
    The camera somewhat works. It tends to crash, but I've taken pictures and recorded videos with it.
    I can use the Panorama mode, but I can't save the picture, as it doesn't react when I press 'OK'.
    10-25-2011 04:37 AM
  6. hce's Avatar
    on nexus s.
    Don't you have an I9023?
    I'm not sure, but I think the beta2 you downloaded at DrewGaren.com could be only for I9020A...
    (Can someone confirm?)
    EDIT: Sorry for wrong information: MrHaxx1 has is running on I9023...
    10-25-2011 04:40 AM
  7. MasterOSX's Avatar
    mmm...only for I9020???
    10-25-2011 04:42 AM
  8. MrHaxx1's Avatar
    I use it on I9023.
    hce likes this.
    10-25-2011 04:42 AM
  9. faizalmzain's Avatar
    yes on 19023, rebooted now, will setup in alittle bit.
    update: restoring data now.
    10-25-2011 04:42 AM
  10. MasterOSX's Avatar
    Mmmm... strange, on mine (I9023) I've no network and if I flash netarchy I get bootloop
    10-25-2011 04:47 AM
  11. geovaunie's Avatar
    Amazing Rom best ive ever seen and fast response. considering ics was just announced about 5 days ago.
    10-25-2011 04:47 AM
  12. wesdwilliams's Avatar
    i dont think u need to flash a kernel just wipe everything and then just flash the rom thats it.
    10-25-2011 04:51 AM
  13. faizalmzain's Avatar
    anyway, what is the multitask button?
    10-25-2011 04:58 AM
  14. MrHaxx1's Avatar
    Long-press home.
    faizalmzain and nkhs9412235 like this.
    10-25-2011 05:01 AM
  15. haka's Avatar
    this is build 13, right?
    therefore we have old icons and face unlock missing?
    any solution to get newest build 14?
    10-25-2011 05:22 AM
  16. tolgapaksoy's Avatar
    Too bad both Roms result in no network on the i9023. It also clearly says the nexus S Rom is for i9020
    10-25-2011 05:32 AM
  17. MrNago's Avatar
    So, just to sum-up:
    Nexus S i9023:
    -WiFi connects but doesnt work.
    -Calls/sms work, but no data
    -If flashed Netarchy Kernel, stuck at boot logo.
    This is my XP, so mileage may vary.
    10-25-2011 05:32 AM
  18. shabgard's Avatar
    Thank you, great rom its fast and good for daily driver, Root will be nice for NS4G.
    10-25-2011 05:35 AM
  19. MrHaxx1's Avatar
    So, just to sum-up:
    Nexus S i9023:
    For everyone with WiFi problem:
    1. Try to connect to your network - it will most likely not work.
    2. Disconnect and forget the network.
    3. Connect again, then it should work.
    That's what I did anyway, and it works just fine.
    Also, I get decent performance in Cut the Rope and Google Earth, though it's better on GB. Just thought I should say this.
    EDIT: Surprisingly enough, 3rd party keyboards works without problems. Only tried SwiftKey, though.
    10-25-2011 05:37 AM
  20. wesdwilliams's Avatar
    Ya that worked for me to fix my wifi when i flashed this earlier.. So it sounds like that method would be the way to go to easily fix that issue.
    10-25-2011 05:43 AM
  21. djw39's Avatar
    Nice work. Anyone get roboto font on here? Downloaded superuser and font installer from the market,font installer says I don't have root access.
    Sent from my Nexus S 4G using Tapatalk
    10-25-2011 05:56 AM
  22. haka's Avatar
    surprisingly EACH & EVERYTHING IS working! Nexus S i9023.the only thing i'm dying for is Face Unlock.
    I am using that DG guy's ROM
    10-25-2011 06:06 AM
  23. MrHaxx1's Avatar
    xda-developers - View Single Post - Ice Cream Sandwhich Goodies from SDK! Roboto Font and /system partition!
    Try to flash this. I can't guarantee it works.
    Didn't work for me.
    10-25-2011 06:15 AM
  24. tolgapaksoy's Avatar
    Wait, so you guys actually have network reception on your i9023? Mine can't find any networks.
    10-25-2011 06:30 AM
  25. st1172's Avatar
    This is truly exciting! Having a working version of Android 4.0 on my device before the device touted to be the first to run it is available! Beezy I appreciate what you've done greatly! Thank you so much!
    10-25-2011 06:31 AM
