11-15-2011 09:48 PM
2,282 ... 2122232425 ...
tools
  1. 4I_i's Avatar
    Its a shane that i cant use it on my ns 9020 beezy do you think you can port it to the ns?
    Great job anyway though!!
    EDIT: ok ive just found it for the nexus s on xda! great job beezy!! ;D i fully admire your skill!
    10-25-2011 08:47 AM
  2. meh8036's Avatar
    ok thanks will try that
    10-25-2011 08:48 AM
  3. 4I_i's Avatar
    keep getting installation aborted message whenever I try to flash... anyone else having this issue? I am downloading on a Mac. I did a factory reset, wiped cache, and dalvik... do i need to have the previous build installed first and update to the new one?
    Ive got the same issue but ive got a nexus s not 4g...
    10-25-2011 08:53 AM
  4. faizalmzain's Avatar
    Wait, so you guys actually have network reception on your i9023? Mine can't find any networks.
    network reception is fine on my i9023 but data is not working. that's the only bummer so far.
    10-25-2011 09:02 AM
  5. ghostzyden's Avatar
    This is awesome work, thanks a bunch. Wifi works perfect, ive had a few things crash like the music app. But im amazed at the stability and speed of this release. Just wanted to thank everyone that made this happen
    10-25-2011 09:03 AM
  6. hooperb63's Avatar
    Nexus S ICS SDK Port Beta 2
    INSTALL INSTRUCTIONS:
    1.Reboot Into Clockwork Recovery
    2.Wipe Data/Factory Reset
    3.Wipe Cache
    4.Wipe Dalvik
    5.Install Nightly Build From Zip
    6.AFTER YOU HAVE INSTALLED NIGHTLY BUILD INSTALL NETARCHY KERNEL FROM ABOVE OR ELSE WIRELESS WILL NOT WORK!
    drew stated this on his website, but where is the netarchy kernal for nexus s 3g i cant find it anywhere?
    10-25-2011 09:22 AM
  7. vhgomez36's Avatar
    Actually can someone double check their wifi mine is working now and it wasn't before i have a ip lock now.lol
    Just asking one's with the NS4G only need two replies.thanks
    My WIFI is working as well. Thanks Beezy great Rom
    10-25-2011 09:22 AM
  8. ejc2t2012's Avatar
    I have had problems on my ns4g with some of the newer Clockwork versions when choosing the rom to install from Rom Manager. It normally works if I boot into recovery and then manually do the wipes and select the rom to install. I just select reboot to recovery in rom manager. just a thought.
    10-25-2011 09:24 AM
  9. hooperb63's Avatar
    3.Wipe Cache
    4.Wipe Dalvik
    Kernels
    Netarchy CFS Universal
    download
    i think i found it on the downloads section own his website!!!
    10-25-2011 09:25 AM
  10. Vinnypel2ella's Avatar
    Uh, any way to get root on this ROM? And nfc does not work thus the wallet app won't open cause it needs nfc. Can we use a custom kernel? Great great job on this, I love what it says about Google plus on initial setup lol. Only reason that i'm not using as daily is cause of the nfc issue and some apps don't work yet in it
    10-25-2011 09:26 AM
  11. MrNago's Avatar
    Kernels
    download
    Downloads for Nexus S
    Netarchy universal
    On the i9023 we're getting a bootloop, so if you have that model don't flash the kernel. WiFi works good anyways for us.
    hooperb63 likes this.
    10-25-2011 09:27 AM
  12. ejc2t2012's Avatar
    Can NS4G users use different kernels without losing functionality, I would like to be able to OC.
    10-25-2011 09:30 AM
  13. hooperb63's Avatar
    Netarchy universal
    well it hasnt worked for me at all. it said somethink about offset when i installed the update. i rebooted it and now its stuck o the google screen!!!! strange lol
    the error it displays is random offset: 0X2C7
    THEN it says install from sd card complete but gets stuck on google sign!!
    i retryed and now it worked. wtf that is strange i tried it without the kernel this time though!!!!
    10-25-2011 09:32 AM
  14. MrNago's Avatar
    I got the random offset too, but it booted no problem.
    Try wiping dalvik, cache and data. Flash again the zip and see if it works. It should!
    10-25-2011 09:37 AM
  15. slacker76's Avatar
    Has anyone tried a Matrix Kernel with success?
    10-25-2011 09:38 AM
  16. TehMan's Avatar
    Got this one to work on my phone. Wifi is working and everything. anyone test out the screen shots?
    10-25-2011 09:43 AM
  17. MrHaxx1's Avatar
    Screenshots works perfectly fine.
    Power-button + Volume-down. In that order.
    10-25-2011 09:44 AM
  18. hooperb63's Avatar
    my 3g is not working though but wifi is this is strange
    10-25-2011 09:44 AM
  19. casserly's Avatar
    Are other i9023 users able to send text messages and make phone calls?
    10-25-2011 09:45 AM
  20. MrHaxx1's Avatar
    I am.
    Franco.kernel makes everything smoother and faster, but breaks WiFi. I'll test some more kernels.
    Matr1x doesn't even get past the Google logo.
    10-25-2011 09:46 AM
  21. casserly's Avatar
    I am.
    Thats pretty weird, cause I cant even flash other kernels, just gets stuck at the google logo. And in regard to making phone calls and stuff, did it work straight after you flashed it, or did you have to do something?
    10-25-2011 10:01 AM
  22. MrHaxx1's Avatar
    It just worked.
    10-25-2011 10:08 AM
  23. codemonkey85's Avatar
    It looks like I can't get Music Beta to sync with my phone now. Has anyone gotten this working?
    10-25-2011 10:20 AM
  24. slopokdave's Avatar
    I got stuck at the google boot logo at first too, did a reset back into recovery, data wiped, booted fine next time into ICS..
    10-25-2011 10:20 AM
  25. codemarshank's Avatar
    On my NS4G, when I tap to enable NFC, nothing happens. Is NFC not working yet?
    10-25-2011 10:22 AM
