11-15-2011 09:48 PM
2,282 ... 2324252627 ...
tools
  1. beezy's Avatar
    something odd that i noticed but when i was roaming, the icon on the top right turned into the GB 4 bar icon that was green....
    please tell me this isnt some messup?
    also noticed that in android version it says ICS not 4.0 anywhere?
    not be be a skeptic but how did that all get thrown out the window and dissapear from last version?
    thanks in advance and loving the ROM btw =D
    The name change is a very simple build.prop edit. You could go in there and change it to uncle sam is a great ole guy if you wanted. If everyone wants ill change it back to say 4.0 in the next update. The signal stuff is just framework nothing to be worried about. This is ICS some of it's older some of it's new some files are from GB because that's all we have to work with it get this going.
    MrNago and nkhs9412235 like this.
    10-25-2011 11:18 AM
  2. hooperb63's Avatar
    will somebody please help me with my network connection. no data at all works but wifi does strange!!!
    10-25-2011 11:21 AM
  3. beezy's Avatar
    What version of the nexus you running?
    10-25-2011 11:23 AM
  4. austsamson's Avatar
    okay thanks for clarification man, you have all my support dont fret!
    and just for the record, i love the honeycomb clock on the lockscreen =D
    beezy likes this.
    10-25-2011 11:23 AM
  5. evoldroid's Avatar
    I'm having a issue downloading titanium back up is anyone else?
    10-25-2011 11:25 AM
  6. hooperb63's Avatar
    your not going to like this beezy but google nexus s 3g. im getting no data at all. i used the rom from drews website!!!
    10-25-2011 11:29 AM
  7. hooperb63's Avatar
    also when i actually install from zip file i always get a random offset error but for some reason i have different numbers display all the time this time its 0x1f its never the same error
    installed again my error number this time is 0x3cd
    10-25-2011 11:33 AM
  8. evoldroid's Avatar
    correction nothing is downloading from app market
    10-25-2011 11:38 AM
  9. slacker76's Avatar
    This rom doesn't have root yet.
    10-25-2011 11:41 AM
  10. beezy's Avatar
    Im 100% sure on everything that needs to be changed for the 3g. I was thinking mainly sum vendor files and few other edits. I probably should take to drew and see what he's doing and help if i can.
    Are you around a pc with adb set up?If so run a log when trying to make a call.
    adb logcat
    or
    adb logcat > logcat.txt
    which would give you a text file you could post for all of us to look into the error.
    Yeah im hoping to be able to do away with that in next few updates.
    hooperb63 likes this.
    10-25-2011 11:45 AM
  11. rougegoat's Avatar
    My experience so far...(NOTE: NS4G)
    • WiFi works out of the box, no issues
    • GPS works splendidly
    • Can't tell if 4G is working or not since it's not listed in settings.
    • No NFC
    • No bluetooth
    • Live wallpapers seem sluggish, but I rarely use them anyway
    • Menu button doesn't respond on homescreen, but that's to be expected as the new homescreen doesn't have a menu button on it.
    • Some apps FC, but they are also notorious for not supporting new OS versions very quickly
    • camera works fine, some issues with panoramas. Luckily, I don't really use that.
    • widgets dont' seem to be resizable just yet
    • one application with multiple widgets can get some funky results
    • screen shot works fine(vol down + power)
    • What exactly is "Movie Studio" and why has no one mentioned this so far?
    beezy likes this.
    10-25-2011 11:47 AM
  12. beezy's Avatar
    Some times it hangs for awhile. Im going to work on market a little later to see if there's a way around things. I know not all apps will show either.
    Everyone root will be added to the rom and uploaded later,if you want to use work around then you are welcome to. If you don't want to mess with it for now then just hold tight and it'll get there. It really did slip by cause you can get root with adb. So it's half rooted.lol
    justmerob and nkhs9412235 like this.
    10-25-2011 11:49 AM
  13. lightyear420's Avatar
    To get root, just flash this zip in recovery:
    Superuser-3.0.6-efgh-signed.zip
    Most things that require root will work. The only one I've found that doesn't is titanium.
    10-25-2011 11:52 AM
  14. hooperb63's Avatar
    adb logcat
    or
    if you give me some basic instructions to set up adb i will do it mate. i rooted from phone via an all in one program and installed pda just give me a brief what to do and ill do it.
    10-25-2011 11:53 AM
  15. beezy's Avatar
    • No NFC
    • No bluetooth
    Thank you very easy to read.One thing widgets are sizable you have to long press like your going to delete and then you can move the sides that have a diamond shape. It took me awhile to get it
    10-25-2011 11:53 AM
  16. beezy's Avatar
    Try this if you want. after the SU zip, go download rom manager and open look for fix issues or problems and i think it will install a newer busybox that should allow all root apps to work. That's just a quick guess.
    Edit just got told no it doesn't work that way sorry
    10-25-2011 11:56 AM
  17. hooperb63's Avatar
    also in the app store it says music and voice search not installed if i try to install music is says this item is not available in your country lol.
    10-25-2011 11:58 AM
  18. tylerwatt12's Avatar
    when i flashed i got an error but it still worked
    anyone know why this is? or what's it about?
    10-25-2011 11:58 AM
  19. beezy's Avatar
    Yes it's how things have to be to set everything up properly on flash. It should be taken care of in next few updates.
    tylerwatt12 likes this.
    10-25-2011 12:01 PM
  20. rougegoat's Avatar
    Weird. None of the widgets I have, be they Google defaults or third party ones, are re-sizable even following your instructions. No diamond shape pops up, it just kind of sets it back down as it would in Gingerbread. Is there anything beyond just long holding you need to do?
    10-25-2011 12:03 PM
  21. xJRECHx's Avatar
    It takes a while to get used to it but resizable widgets do work
    beezy and nkhs9412235 like this.
    10-25-2011 12:07 PM
  22. MrNago's Avatar
    Try the Calendar widget
    Just hold it and when you get the haptic feedback, let go. You shoud get that blue square around it with the diamond at the bottom. I do!
    beezy likes this.
    10-25-2011 12:07 PM
  23. beezy's Avatar
    Try doing it with bookmarks or calendar I know them two work. In the video i show me scrolling the bookmark widget it's as big as can be.Just long press the trash can will come up release then it should have a blue outline.
    10-25-2011 12:08 PM
  24. rougegoat's Avatar
    tried all the widgets, and the Calendar widget is the only one that was resizable for me. curious...
    10-25-2011 12:09 PM
  25. joliva's Avatar
    I don't know if this has been covered but to gain root access download super user binaries 3.0.3 efgh from rom manager. Then boot into recovery and find the file you dl'ded and flash it. Wipe delvik and reboot. When the device completely loads go into market and download superuser. Finally update the superuser binaries( it might say they are up to date, update anyway). After that you should be rooted. This is the method I just used and it works without any issues.
    10-25-2011 12:12 PM
