4I_i
What changed from the beta-1b? I could flash that and run it (the two-finger one) but this one i cant even flash! :-/
Wifi works perfect for me, No issues on that front..
Also no haptic yet...
keep getting installation aborted message whenever I try to flash... anyone else having this issue? I am downloading on a Mac. I did a factory reset, wiped cache, and dalvik... do i need to have the previous build installed first and update to the new one?
Wait, so you guys actually have network reception on your i9023? Mine can't find any networks.
Actually can someone double check their wifi mine is working now and it wasn't before i have a ip lock now.lol
Just asking one's with the NS4G only need two replies.thanks
ok thanks will try that
Nexus S ICS SDK Port Beta 2
INSTALL INSTRUCTIONS:
1.Reboot Into Clockwork Recovery
2.Wipe Data/Factory Reset
3.Wipe Cache
4.Wipe Dalvik
5.Install Nightly Build From Zip
6.AFTER YOU HAVE INSTALLED NIGHTLY BUILD INSTALL NETARCHY KERNEL FROM ABOVE OR ELSE WIRELESS WILL NOT WORK!
drew stated this on his website, but where is the netarchy kernal for nexus s 3g i cant find it anywhere?
