11-15-2011 09:48 PM
2,282 ... 2728293031 ...
tools
  1. intheb0x's Avatar
    I know i thought it didn't i need to edit first post thats all.lol
    thanks hadn't messed with other KB's yet.
    Try a different back up sounds like you just have a messed up nadroid it happens sometimes. If you don't have another then wipe everything and flash the rom you were running.
    I sure will be getting ahold of Hero that great of him to offer to help.
    Also running SwiftKey with a small notification issue where it asks to select input method in the pull down , but the keyboard is working like normal and i ignore that.
    Can't wait for beezy /hero kernel options :-)
    Sent from my Nexus S 4G using Tapatalk
    10-25-2011 04:06 PM
  2. tylerwatt12's Avatar
    Heres my flashable ZIP
    Works with NS4G and NS
    It:
    • Roots the device (I'm aware of window size bug)
    • Replaces DroidSans with Roboto
    • Replaces Clock Font with ICS one
    • Replaces bootanimation.zip with Galnex boot animation
    Download Flashable ZIP
    More coming later..
    10-25-2011 04:07 PM
  3. beezy's Avatar
    Heres my flashable thingy lol
    It will Root the device and Update Fonts and boot animation
    Flashable ZIP
    Thanks ill probably be adding this in with credit to you for your work. Thanks for helping out.
    tylerwatt12 likes this.
    10-25-2011 04:09 PM
  4. jlopez1286's Avatar
    I've been using this Rom from this morning... it works awsome...one thing i was thinking about... is the face lock and unlocking part of this Rom??
    10-25-2011 04:11 PM
  5. beezy's Avatar
    Nope has todo with this having a mix of old and new files. It's on the list of things that need done.
    10-25-2011 04:13 PM
  6. amehdi43's Avatar
    Does mobile network work? I flashed it today. It couldn't search for any services and 3g didn't work
    10-25-2011 04:22 PM
  7. shaunm89's Avatar
    Does anyone elses phone reception just suddenly die and stop working?
    10-25-2011 04:25 PM
  8. loso831's Avatar
    yea mine did but i just reboot and put in the apn settings and it was up and never came back down
    10-25-2011 04:27 PM
  9. Paul627g's Avatar
    I've been using it now for a few hours... I must say I'm very impressed at this point... You know Google has had to caught wind of this by now and should be impressed by what one person with some good help from members has accomplished
    I love teasing with that new Tapatalk sig below...
    Sent from my Nexus S 4g running Ice Cream Sandwich.
    beezy likes this.
    10-25-2011 04:29 PM
  10. jlopez1286's Avatar
    ok, thanks...once again this rom is awsome...thanks for all the work you've done...
    beezy likes this.
    10-25-2011 04:29 PM
  11. vabeachboy0's Avatar
    Great job to all the devs everything works so far. Just having an issue with superuser but other than that everything works. Havent had a force close on the camera, wifi connected no problems. Tried out trinity kernel doesnt work stuck on boot screen, ill try diffrent kernels and post working ones.
    10-25-2011 04:30 PM
  12. Formula84's Avatar
    THanks the last few page should have the info you are looking.I would copy&pasted but im on mobile right now.
    Sorry man i look from pages 59 to your post and dont see anything about titanium restore issues. I do have root with SU working Titanium can remove apps but not restore it just sits there forever...what weird is there used to be an apps processing mode that i cant find now.
    Anyone actually restore apps via titanium yet? if so can you check preferences for me and see if apps processing mode is there for you?
    10-25-2011 04:35 PM
  13. djw39's Avatar
    Lock clock font!
    Attachment 16996
    10-25-2011 04:35 PM
  14. dexgen's Avatar
    Hey guys, I've been working some more on Beezy's rom here to get it more functional on the Nexus S 3G and I have made it a little bit more functional. Here's what to expect in tonight's release, fully updated ui closer to the released version of android 4.0. Some added 4.0 apps. Modified apps. I have also started working on NFC, it's not there yet but I may get it by tonights release if not then I'll get it with bluetooth in the next update. I have updated all audio, bootanimation, and I am also adding superuser in. This will be up later today on my site or you can follow me on twitter for updates @drewgaren. I don't know how to contact Beezy so Beezy email me via my website drewgaren.com if you would like to collaborate. Your rom is amazing and I am only helping improve and bring it to the Nexus S 3G community.
    Any update on data connectivity issues on Nexus S 3G, Drew?
    PS. You rock! You and Beezy both!
    10-25-2011 04:47 PM
  15. vabeachboy0's Avatar
    Boot screen is awsome
    10-25-2011 04:47 PM
  16. adamw1101's Avatar
    when I reboot my phone and contacts icon diss appears from next to the app dew icon
    10-25-2011 04:51 PM
  17. beezy's Avatar
    So does the whole app disappear or just the icon?
    10-25-2011 05:02 PM
  18. djw39's Avatar
    I guess we have to edit launcher2.apk to change out the app drawer icon?
    10-25-2011 05:06 PM
  19. mak213's Avatar
    will we get custom kernel support?
    10-25-2011 05:10 PM
  20. adamw1101's Avatar
    the whole app it happened after restoring data with mybackup
    10-25-2011 05:11 PM
  21. stuartjmoore's Avatar
    I love this, thank you.
    Two questions:
    1. Does the notifications panel work on the lock screen? I can't slide it down or find a setting to allow me to.
    2. Why does the clock show up twice on the lock screen? The Galaxy Nexus doesn't do this.
    Small things I know, but just some things to keep an eye on.
    10-25-2011 05:11 PM
  22. Batting1000's Avatar
    I can't push the notifications panel back up after I pull it down. I have to use one of the soft key buttons to exit out of it
    jeffreynothing43 likes this.
    10-25-2011 05:16 PM
  23. Paul627g's Avatar
    Haven't used Titanium but My BackUp Pro worked fine for me
    10-25-2011 05:17 PM
  24. beezy's Avatar
    This is my bad for not making a very detailed first post yet. The problem is restoring apps right now not a good idea probably going to give you a lot of problems. Wipe and install everything manually for now.
    10-25-2011 05:19 PM
  25. tylerwatt12's Avatar
    I'm debating whether or not I should attempt to modify Launcher2.apk I haven't even taken a look at it yet. Does anyone know if the launcher "App Drawer" icon is in Drawable-hdpi? I might have to install Windows 7 again. Linux is quite powerful, but I don't think I really need it right now. It's just holding me back. So, ill be back updating my patches in a few hours
    10-25-2011 05:19 PM
