11-15-2011 10:48 PM
2,282 ... 2930313233 ...
tools
  1. beezy's Avatar
    how do i remove network?
    In the settings press on the network and choose Forget. Might have to long press.
    10-25-2011 07:03 PM
  2. jwhood's Avatar
    Yeah ill jump over that way in a little while tied up at the moment.
    K thanks bro,and congrats on this huge project!!!
    10-25-2011 07:05 PM
  3. Tomgombosi's Avatar
    thats what i figured. both are a no go.
    10-25-2011 07:05 PM
  4. Batting1000's Avatar
    Well it was working right and now its not, idk why.
    Sent from my Nexus S 4G using Tapatalk
    10-25-2011 07:09 PM
  5. beezy's Avatar
    Check and see if its getting a IP address.
    If it's not then you are seeing what happen to me and i wasn't able to trouble shoot it,everything seemed to work how it should. Then it just out of the blue worked.Also try wiping cache. If it doesn't work and i get a update up and then still doesn't we'll get together and pull a log to see if its showing different then all the logs i already looked at.
    That's why the update took so long yesterday wifi didn't work then it did.lol
    10-25-2011 07:12 PM
  6. RevolutionXDA's Avatar
    Nice man , it's really amazing what your doing . I need some help with my port for the MT4G
    10-25-2011 07:13 PM
  7. adamw1101's Avatar
    yeah my wifo has been working solid. As for that app draw issue the activity manager crashed and reloaded wiping my apps again I think its not saving the apps in its memory or something
    10-25-2011 07:16 PM
  8. beezy's Avatar
    Thank you ill shoot you a pm here or over there in just a little bit with my email im beezy420 over there
    10-25-2011 07:17 PM
  9. Tomgombosi's Avatar
    It says obtaining ip address then says connected then about 3 seconds later it disconnects. I actually just tried a fresh install and same results.
    10-25-2011 07:22 PM
  10. hooperb63's Avatar
    does anyone know if there is any plans to release beta3 in the next couple of hours 00.25am here i uk dont wanna wait up if there i no point. may aswell wait till the morning!!! thanks.
    10-25-2011 07:26 PM
  11. ejc2t2012's Avatar
    I can't push the notifications panel back up after I pull it down. I have to use one of the soft key buttons to exit out of it
    I had similar issues, it's kind of intermittent though, sometimes after restarting it won't go back up and then magically it will start. not too much of an inconvenience though.
    10-25-2011 07:28 PM
  12. rougegoat's Avatar
    with the same like four repeat questions over and over for the last several pages, I'm half tempted to write up an FAQ for the main post. Sadly, I know that the same people wouldn't bother reading it so I don't think it'd be too helpful. Thoughts?
    10-25-2011 07:30 PM
  13. tylerwatt12's Avatar
    I was about to ask beezy if i could, then he could put it up on the first post. But, I don't think anyone would read it either..
    10-25-2011 07:35 PM
  14. joker2wild's Avatar
    First of all, want to give thanks to Breezy, War attack, and all devs on this. Second, Been running since yesterday and I have to say this is awesome. Been a long time MIUI rom user, and the best compliment I can pay u guys is this will now be my new daily driver. Let me know if you need testers for future releases. Keep up the GREAT work
    10-25-2011 07:36 PM
  15. beezy's Avatar
    It's okay i plan to change the first post up and make it so if you don't read the whole post you might not find the link and it should cover works/doesn't fully i've just been throwing it together.
    Cory Streater and justmerob like this.
    10-25-2011 07:37 PM
  16. tylerwatt12's Avatar
    lol, It's Beezy not Breezy
    10-25-2011 07:40 PM
  17. Tomgombosi's Avatar
    Beezy not sure why but all of a sudden my wifi connected. hmmm thanks for all your help. This rom kicks @ss!
    10-25-2011 07:50 PM
  18. beezy's Avatar
    Lmao,weird how it does that but glad it's going again.Thanks.
    10-25-2011 07:56 PM
  19. Paul627g's Avatar
    Beezy, I'm going to take a wild guess and say you have had success decompiling and recompiling the framework-res.apk or SystemUI.apk?
    I've already gone to work doing some theme work but unfortunately I can't get Apk Manager 4.7 or 4.9 to re compile the either. I even updated my APKTOOL to the newest version from Google which I felt was the first problem.
    Edit: Note, I attempted a re compile as you should before making any changes just to see and untouched it won't recompile for me
    Still a no go...
    10-25-2011 08:01 PM
  20. blozout's Avatar
    Firstly - awesome job Beezy. This is a great starting point, more fully functioning than some CM7 nightlies
    Second - Anyone able to drag down the notification bar while on the lockscreen? That's a feature I'm really excited about with ICS.
    10-25-2011 08:07 PM
  21. intheb0x's Avatar
    Found another keyboard issue
    I'm unable to open anything in the SwiftKey menu besides the faq that opens the browser, thought id mention it, you can click away but nothing will open.
    Can't change the theme either.
    Just a heads up,
    Sent from my Nexus S 4G with Ice Cream Sandwich
    10-25-2011 08:12 PM
  22. Kuffoman's Avatar
    I just signed up to say, hell yeah!
    I've been waiting for this update, and your rom will curb stomp my ice cream sandwich cravings for now!
    thanks man! Huge props, keep it up Beezy!
    beezy likes this.
    10-25-2011 08:12 PM
  23. evoldroid's Avatar
    Quick question Beezy is there a way to add more screens? Like home screen when your scrolling from side to side
    10-25-2011 08:18 PM
  24. hooperb63's Avatar
    Woohoo drew shud have beta3 up by 10 pm eastern. Come on nexus s
    10-25-2011 08:19 PM
  25. jralabate's Avatar
    Heres my flashable ZIP
    It:
    • Roots the device (I'm aware of window size bug)
    • Replaces DroidSans with Roboto
    • Replaces Clock Font with ICS one
    • Replaces bootanimation.zip with Galnex boot animation
    Download Flashable ZIP
    More coming later..
    can u make a zip with out root as i rooted my by hand
    10-25-2011 08:20 PM
