11-15-2011 09:48 PM
2,282 ... 3334353637 ...
tools
  1. Kuffoman's Avatar
    is the menu button supposed to work on the main dashboard? Just question and do current kernels work on this build? Thanks in advance!
    10-25-2011 10:40 PM
  2. Bongzilla's Avatar
    Awesome, thanks a ton!
    10-25-2011 10:41 PM
  3. Charles Dolly's Avatar
    Is Google Wallet installed on this build?
    Yeah it's not and NFC is not working at this point.
    beezy likes this.
    10-25-2011 10:42 PM
  4. Charles Dolly's Avatar
    I don't think so because there is not going to be a Menu button on the Galaxy Nexus, but if you need to change anything you can just go to... App Drawer > Settings. Good luck.
    beezy and tylerwatt12 like this.
    10-25-2011 10:49 PM
  5. jcaicedo82's Avatar
    no I didn't. Just the initial set up
    10-25-2011 10:50 PM
  6. Charles Dolly's Avatar
    And you fully wiped any cleared everything?
    beezy likes this.
    10-25-2011 10:57 PM
  7. intheb0x's Avatar
    Again, I really appreciate the work being done here but it is killing me not having voodoo controls haha
    agreed,
    the screen looks so dull and grey!
    cant wait until some kernel options come out!
    10-25-2011 10:58 PM
  8. jcaicedo82's Avatar
    Yes. I followed the procedures
    10-25-2011 11:03 PM
  9. Paul627g's Avatar
    Well look at it this way everyone... We all part of a small group of lucky ones getting a chance at running ICS in very good form before its even out on any device...
    That alone is worth it all in a nutshell... The kernels, and other goodies will be here soon enough...
    intheb0x likes this.
    10-25-2011 11:04 PM
  10. Charles Dolly's Avatar
    Hmm not sure, I asked Beezy he's not having the problem at all.
    beezy likes this.
    10-25-2011 11:04 PM
  11. intheb0x's Avatar
    ICS Nexus S 4G [WIP] - xda-developers
    It's pretty much what this thread says, only on XDA.
    the bootanimation was probably videoripped. Not really sure how that was obtained. I mean if we have a Galaxy Nexus Bootanimation, why dont he have a full system dump? Anyway. I tried working on some launcher2.apk mod's but i've been busy helping people out.
    Agreed.
    Earlier in this thread, someone chimed in saying they can get access to a galaxy nexus in the near future, and perhaps rip a nandroid or something from it and beezy messaged him with the info he needed or something to that effect.
    10-25-2011 11:05 PM
  12. jcaicedo82's Avatar
    Did your phone restored apps from your previous rom? Mine did it even tho I wiped factory, cache, dalvik and boot.
    10-25-2011 11:10 PM
  13. Paul627g's Avatar
    If you had Google saving all your settings/apps (Settings/Privacy/Back up my data) from your previous setup and then allowed it to restore those on initial boot of ICS then yes you would have your previous apps back.
    10-25-2011 11:18 PM
  14. FL0OD's Avatar
    It gets worse. Check out this clown....
    http://forum.xda-developers.com/show....php?t=1319647
    Sent from my neXus S 4g
    10-25-2011 11:30 PM
  15. Charles Dolly's Avatar
    [ROM][SDK]T.A.R.D.I.S. 4.0 (Ice Cream Sandwich!) - xda-developers
    Yeah we know lol
    beezy likes this.
    10-25-2011 11:35 PM
  16. Kuffoman's Avatar
    Thanks a ton, very helpful :]
    I thought for a moment I did something wrong lol
    10-25-2011 11:36 PM
  17. christofur84's Avatar
    thanks for the hard work guys.....this rom has been running great...wifi works with no problem...has anybody had an issue with the notifications bar getting stuck on the home screen. I can pull it down but not back up until i hit back or home. This does not happen anywhere else but the home screen. any ideas???
    10-25-2011 11:41 PM
  18. Charles Dolly's Avatar
    No problem man
    beezy likes this.
    10-25-2011 11:41 PM
  19. kristoferallen's Avatar
    I've seen it work before on a video. Probably build 14
    10-25-2011 11:43 PM
  20. jcaicedo82's Avatar
    OK thanks! So I did a fresh flash and disable Google restore n now the icon is gone.
    10-25-2011 11:44 PM
  21. Paul627g's Avatar
    No prob...
    Once this turns into more of "Custom ROM" like it will have the Google settings save/restore option disabled in the initial setup wizard like most custom ROMs do and you won't have to worry about that anymore...
    Its a nice feature but if you let that baby sync on 3g you could be there all day waiting on 30, 40 , 50 apps to restore... LOL..
    10-25-2011 11:47 PM
  22. Charles Dolly's Avatar
    Hmm... I haven't heard of anyone else having that problem.
    beezy likes this.
    10-25-2011 11:50 PM
  23. syndtr's Avatar
    what powervr driver on kernel side do you use? It's from omap?
    10-25-2011 11:56 PM
  24. blankit's Avatar
    nfc doesnt work!
    10-25-2011 11:56 PM
  25. MgWach's Avatar
    Hey all! So I got everything to go by the book (directions) and now after rebooting with Beezy's ROM, I'm waiting on the normal NS4G startup animation which seems to be taking forever. Is that normal?
    10-25-2011 11:57 PM
