11-15-2011 09:48 PM
2,282 ... 3435363738 ...
tools
  1. turbofan's Avatar
    Beezy,
    Still working with that md5 issue. I have several other backups from several different roms. None of them worked, all failed md5 check right off the bat. I can make and restore backups of the ICS rom no problem.
    Any ideas on how to fix this? Do you think doing the root fix would make any difference or does that not affect CWM?
    It would be really great to get this fixed. Anyone else having this issue?
    Thanks,
    Ed
    10-26-2011 12:00 AM
  2. Charles Dolly's Avatar
    Give it a bit then just do a battery pull, boot into recovery, Factory reset > clear Cache > clear Dalvik > then just try it again
    Cory Streater and beezy like this.
    10-26-2011 12:01 AM
  3. Charles Dolly's Avatar
    Hey all! So I got everything to go by the book (directions) and now after rebooting with Beezy's ROM, I'm waiting on the normal NS4G startup animation which seems to be taking forever. Is that normal?
    beezy likes this.
    10-26-2011 12:02 AM
  4. MgWach's Avatar
    Ok will do, thanks.
    10-26-2011 12:02 AM
  5. Charles Dolly's Avatar
    np, Just report back and let us know how it went
    beezy likes this.
    10-26-2011 12:04 AM
  6. Paul627g's Avatar
    nfc doesnt work!
    Already noted, pages and pages back and then some..
    10-26-2011 12:05 AM
  7. MgWach's Avatar
    WOOOT!!! All is good!! Thanks everyone for the help! It's working great.
    10-26-2011 12:18 AM
  8. Charles Dolly's Avatar
    Glad to hear it
    beezy likes this.
    10-26-2011 12:21 AM
  9. syndtr's Avatar
    what powervr driver on kernel side do you use? It's from omap?
    oh, nevermind I got it working using omap4 driver... finally ICS on Fascinate... but is this ICS from Nexus S that the video has been leaked sometime ago?
    10-26-2011 12:32 AM
  10. Cory Streater's Avatar
    I have a Fascinate. Can't wait to see your video demo.
    beezy likes this.
    10-26-2011 12:48 AM
  11. Kuffoman's Avatar
    Is the speed able to be tinkered with? With the help of set CPU or installing a compatible kernel?
    Sorry if its a stupid question lol
    10-26-2011 01:05 AM
  12. Jerry Hildenbrand's Avatar
    hi!
    beezy will this work on the hero?????
    drewwalton19216801 and beezy like this.
    10-26-2011 01:15 AM
  13. beezy's Avatar
    [HL]
    hi!
    [/HL]
    Sure,wipe three times. Then goldcard flash our bootloader flash six times pull battery wait a year reboot.
    10-26-2011 01:24 AM
  14. intheb0x's Avatar
    Lol
    Beezy,
    Is this compatible with the g1?
    -sarcasm-
    Sent from my Nexus S 4G with Ice Cream Sandwich
    10-26-2011 01:29 AM
  15. Charles Dolly's Avatar
    If you have installed SU then you should be able to use turn on CPU governor in setCPU But I wouldn't try to Overclock / Underclock.
    beezy likes this.
    10-26-2011 01:32 AM
  16. Jerry Hildenbrand's Avatar
    I kno u said to wait a year, but smoke came out the heaDPHONE HOLE. iS IT SUPPOSED TO DO THAT?
    I'm done now lol
    10-26-2011 01:53 AM
  17. xgunther's Avatar
    I literally can't wait.
    10-26-2011 02:16 AM
  18. barrelomonkeys87's Avatar
    Yeah, me too.
    Yeah I've been having that issue. Even when I disable sync from power control widget(stock).
    10-26-2011 02:38 AM
  19. Charles Dolly's Avatar
    Beezy said, to check and see if you have updated any google apps since you flashed the rom, If you did try to uninstall if and reboot.
    beezy likes this.
    10-26-2011 02:41 AM
  20. wesdwilliams's Avatar
    Rom is very smooth, most of apps all are working for me had one issue with astro file manager when i downloaded it from the market it wouldnt access the folders it just would highlight over the folder that i clicked on but when i went to use another file manager it worked perfect so don't know why i had that small issue with that but everything else is working perfect installed swype on it and that went thru flawlessly so great work. Thanks Beezy!!
    Charles Dolly likes this.
    10-26-2011 02:59 AM
  21. Charles Dolly's Avatar
    Yeah it might just be an issue with the ROM or it might just be a problem with astro and 4.0
    beezy likes this.
    10-26-2011 03:06 AM
  22. l1zart's Avatar
    I created a test Timelaps video and put it on youtube
    10-26-2011 03:57 AM
  23. lightyear420's Avatar
    anyone else having trouble getting adobe flash working?
    I'm on 11.0.1.153 and I keep getting that lego block icon every time I load flash sites.....is it not working yet?
    10-26-2011 04:46 AM
  24. Batting1000's Avatar
    Hmm... I haven't heard of anyone else having that problem.
    I had this problem with the notification bar.
    If I plug it in and unplug it, it woks again.
    Sent from my Nexus S 4G using Tapatalk
    10-26-2011 05:12 AM
  25. djw39's Avatar
    I have experienced this as well, usually when the phone is charging but occasionally when unplugged as well. I second the suggestion to try plug and unplug.
    10-26-2011 05:45 AM
