11-15-2011 09:48 PM
2,282 ... 3536373839 ...
tools
  1. Formula84's Avatar
    I restored a couple apps with Titanium and the processing mode is AUTO, DIrect.
    Weird, I tried forcing System Busybox after installing from the market and the restore was still borked... I did however find the menu option under troubleshooting for app processing mode and tried the other two options...only one that worked for me was the third one that interacts liek you are installing an apk manually. Its a PIA but it worked, I will try again when the newer version is released in the future.
    10-26-2011 08:37 AM
  2. zeigan's Avatar
    Beezy,
    Still working with that md5 issue. I have several other backups from several different roms. None of them worked, all failed md5 check right off the bat. I can make and restore backups of the ICS rom no problem.
    Any ideas on how to fix this? Do you think doing the root fix would make any difference or does that not affect CWM?
    It would be really great to get this fixed. Anyone else having this issue?
    Thanks,
    Ed
    When I was having restore issues, I re-flashed ColockworkMod Recovery from within Rom Manager, then it worked. If you can't run Rom Manager, I'm sure there are different ways to re-flash it.
    10-26-2011 08:52 AM
  3. MrHaxx1's Avatar
    http://i.imgur.com/MX7x3.png
    ADW Launcher EX seems to be way smoother than stock launcher.
    Also, that thing at the top, was it there in Gingerbread? Or is it something new?
    10-26-2011 09:10 AM
  4. Shadow Death's Avatar
    I've been watching this rom since it was first announced. So far great job. On the main page you said wifi doesn't obtain an IP address. Its working great for me via dhcp.
    10-26-2011 09:14 AM
  5. HTC_EVO112's Avatar
    Thank you. I have su permission now. I tried updating my old one but that didn't work. And I also tried flashing the netarchy kernel, but the rom didn't like that at all. It wouldn't boot for me.
    10-26-2011 09:14 AM
  6. loso831's Avatar
    your not supposed to flash netarchy kernel
    10-26-2011 09:25 AM
  7. zeigan's Avatar
    I'm loving this rom! But any updates on Wimax 4G, Bluetooth, and NFC being able to work soon? I know getting these to work can take time, but just want to see how that was coming along. It kind of sucks not being able to listen to my tunes in my car through the bluetooth. OTA radio is terrible.
    Kudos to all who have contributed to making this rom happen!
    10-26-2011 09:32 AM
  8. HTC_EVO112's Avatar
    I wanted to flash that kernel because it gives BLN.
    10-26-2011 09:36 AM
  9. Shadow Death's Avatar
    I found another issue. The power button doesn't always lock the phone.
    Edit: never mind.. it was a pebkac error.
    10-26-2011 09:44 AM
  10. Paul627g's Avatar
    Flashing existing kernels its not going to work since they are based on Gingerbread, 2.3.7.
    Your just going to have to hold out for BLN and other things down the road.
    HTC_EVO112 likes this.
    10-26-2011 09:46 AM
  11. Bobguy21's Avatar
    I used your version b3. And it went okay on my ns4g. But the data did not work. Other than that it was good mostly everything worked smoothly and I moved it. Please help me if you can. Thank you for the awesome job.
    10-26-2011 10:21 AM
  12. turbofan's Avatar
    Thanks to those who were trying to help me resolve this issue!
    It has been resolved. Wanna know what it was??
    I had renamed my backups and put spaces in the names. Like, you know, spaces between the words. I had NO IDEA that would cause a problem, but when I went in to a file explorer and removed the spaces, it restored no problem.
    Hitting the donate button. Can't wait for a fully working build. Wifi worked perfectly for me, even better than perfect -- pages rendered very quickly. I loved it!! My biggest problems were the camera, and sometimes things just didn't display the way they should, like certain settings menus and such. I also really need a reliably working camera, I use my phone camera a ton. I can't donate much (recently unemployed college student) but this is just such an awesome project. I'll be watching and waiting on MIUI 'til a few more bugs are fixed!
    beezy likes this.
    10-26-2011 10:24 AM
  13. loso831's Avatar
    HOW TO GET DATA WORKING:
    1.Skip Through Setup When Phone Starts
    2.Settings
    3.More
    4.Mobile Networks
    5.Access Point Names
    6.Hit your menu key, select new APN
    7.Type in your carriers APN settings
    8.Hit the menu button again and click save
    9.It will force close, go back and make sure your APN saved, if it did not. Then repeat
    courtesy of Drew Garen
    10-26-2011 10:26 AM
  14. bnitty's Avatar
    can you OC or use a kernel like Matr1x?
    10-26-2011 10:40 AM
  15. dlozanout's Avatar
    for those having trouble with the notification bar, when you pull it down and it wont let you pull it back up, the way i have been "fixing" this is by opening up an app (ive been opening modern combat) and let it load up a bit, then when i go back home, the notification lets me pull up and down without a problem. and i usually only have to do that when i restart my phone. its really weird, but that is what has been working for me
    10-26-2011 10:40 AM
  16. slacker76's Avatar
    I hear that theres a zip i can flash to achieve root. Can someone tell me where i can find it?
    10-26-2011 10:40 AM
  17. bnitty's Avatar
    I just hit the back button to pull the notification bar up
    10-26-2011 10:41 AM
  18. bnitty's Avatar
    I believe it's on page 71
    slacker76 likes this.
    10-26-2011 10:43 AM
  19. loso831's Avatar
    any1 know where i can get the blue wallpaper from the galaxy nexus?
    10-26-2011 11:00 AM
  20. slacker76's Avatar
    So titanium backup doesnt work? Is there an app that will restore apps with data?
    10-26-2011 11:07 AM
  21. quincyb2's Avatar
    I have flashed this but i am living in the Netherlands and my carrier is T-Mobile NL i can't get 3g working i use the scream for ICS b3 from drewgaren i have set the apn but it isn't working . i can call and text
    10-26-2011 11:08 AM
  22. quincyb2's Avatar
    Can i flash the netarchy kernel because i need voodoo sound control
    10-26-2011 11:10 AM
  23. HTC_EVO112's Avatar
    I already tried to flash the netarchy kernel. If you flash it, the phone will not boot.
    10-26-2011 11:14 AM
  24. jleon723's Avatar
    does anyone know how to download attachments from gmail? i cant seem to figure it out
    10-26-2011 11:15 AM
  25. jlopez1286's Avatar
    I know this Rom has file from Gingerbread so it can work, i have a question... would the NFC files work with this Rom to make Google Wallet work??
    10-26-2011 11:17 AM
