11-15-2011 09:48 PM
2,282 ... 3940414243 ...
tools
  1. Batting1000's Avatar
    10-26-2011 04:23 PM
  2. Paul627g's Avatar
    do i flash this one top of the one i have now or do i need to wipe and start over??
    i just read the posting over and u said over the existing rom... thanks
    You could probably just get away with flashing right over the top.... I've done it dozens of times as long as your doing it with a theme made for the ROM your currently on.... This is just an updated package with changed icons so no XML or anything probably has been affected requiring a wipe.
    Otherwise if it gives you any problems, boot into CWM wipe cache/dalvik.
    10-26-2011 04:25 PM
  3. Charles Dolly's Avatar
    do you have an zip for just the icons instead of the entire rom?
    I don't think there is one yet but you can just flash that one on top of it.
    10-26-2011 04:25 PM
  4. jlopez1286's Avatar
    Flash over it, no need to wipe.
    ok...going to flash now...for the NEXUS S 4G, right?? i know theres the 3g version also
    10-26-2011 04:26 PM
  5. Batting1000's Avatar
    Just posted a zip for it but I don't know if it's flashable. Doubt it though.
    10-26-2011 04:27 PM
  6. Batting1000's Avatar
    Yes, the 4G. I did not modify Drew Garens 3G version. I modified the ROM in the OP of this thread.
    10-26-2011 04:27 PM
  7. Charles Dolly's Avatar
    Drew Garens didn't do anything but change the name and change the boot animation... lol
    10-26-2011 04:30 PM
  8. jlopez1286's Avatar
    ok, thanks...
    10-26-2011 04:30 PM
  9. loso831's Avatar
    10-26-2011 04:33 PM
  10. Batting1000's Avatar
    Yeah, but that one works with the 3G.
    10-26-2011 04:34 PM
  11. ws6kid's Avatar
    any chance we can get the ics wallpapers too.. i know theres a wallpaper pack around here.. but updated into the rom would be nice!
    Batting1000 likes this.
    10-26-2011 04:36 PM
  12. djw39's Avatar
    Don't forget fonts, Tyler put a zip together back in the 70s
    Sent from my Nexus S 4G using Tapatalk
    tylerwatt12 likes this.
    10-26-2011 04:40 PM
  13. Charles Dolly's Avatar
    Here is what I said earlier in the thread...
    "Alright, so if you are talking about the Live wallpapers, they are not in the SDK so no one has access to them yet. Your probably going to need to wait until we need a full system dump from a Galaxy Nexus or until we see the the source code released. If your talking about the regular image wallpaper then here is a link."
    http://www.geeky-gadgets.com/wp-cont...wallpapers.jpg
    beezy likes this.
    10-26-2011 04:42 PM
  14. MrHaxx1's Avatar
    Weird. I don't own a N1, yet I still feel a little pissed off. It runs Gingerbread just fine and NS is not that much faster, yet they don't update it to ICS.
    Oh well, custom ICS roms will be out within a week of release anyway.
    10-26-2011 04:43 PM
  15. Charles Dolly's Avatar
    Don't worry, someone will have it ported day one, lol.
    loso831 likes this.
    10-26-2011 04:45 PM
  16. MrNago's Avatar
    WhatTheHell is there anything not awesome on this rom other than the icons?
    Just flashed it over Beta 2 (which has been my rom since release) but Beezy & Crew you just made my Nexus S worth every penny!
    10-26-2011 04:49 PM
  17. ws6kid's Avatar
    I know, I am referring to the static wallpapers. There is more than one though.. its a entire wallpaper pack that comes with ICS.. The link you provided is only the chroma wallpaper..
    10-26-2011 04:51 PM
  18. Charles Dolly's Avatar
    Thanks for the Feedback man And if you go back a bit in the thread you will find a zip you can flash to get the new icons.
    MrNago likes this.
    10-26-2011 04:52 PM
  19. jlopez1286's Avatar
    i flashed it over and everything seems to work good...thanks for the help... cant wait for more updates...
    10-26-2011 04:58 PM
  20. Batting1000's Avatar
    Here's the link for the ROM with the icons updated to 4.0, in case anyone missed it.
    http://dl.dropbox.com/u/15668564/ICS...st-works-2.zip
    10-26-2011 05:02 PM
  21. justmerob's Avatar
    Not being silly here but I was just about to flash this bad boy back to my NS4G after playing with it on the release day... Then saw you got the icons here with it so thought SWEET!
    But, before flashing, I noticed a big difference in the file size compared to what Beezy had/has up....
    Beezy's ROM = 140MB
    Yours = 94MB
    What's the difference? I don't think icons would take up almost 50MB?
    Answers please?
    10-26-2011 05:09 PM
  22. Batting1000's Avatar
    Beezy's ROM = 140MB
    Yours = 94MB
    Answers please?
    Wow, didn't notice that. All I did was replace each icon to their ICS equivalent. Didn't delete or change anything.
    10-26-2011 05:12 PM
  23. scientific's Avatar
    Beezy's ROM = 140MB
    Yours = 94MB
    Answers please?
    Might be a bad download...I got 140MB for both.
    10-26-2011 05:13 PM
  24. beezy's Avatar
    Its a bad download its the same size i have a copy of it. batting1000 check your PM's
    10-26-2011 05:14 PM
  25. Batting1000's Avatar
    Ok,
    10-26-2011 05:14 PM
