11-15-2011 09:48 PM
2,282 ... 4243444546 ...
tools
  1. ws6kid's Avatar
    ok I just noticed flash player 11.0 is not working.. everyone else having the same issue?
    10-26-2011 09:05 PM
  2. djw39's Avatar
    You probably already have it but here is the market link
    https://market.android.com/details?i...droid.su&hl=en
    The one in the market didn't work for me when I tried it a few days ago, but I see it's been updated recently. This works now?
    Sent from my Nexus S 4G using Tapatalk
    10-26-2011 09:07 PM
  3. D2dyno's Avatar
    Yeah, ditto to that
    10-26-2011 09:09 PM
  4. lightyear420's Avatar
    no, flash does not work
    10-26-2011 09:33 PM
  5. silverxj's Avatar
    This is awesome....Beezy and crew,you guys rock! Couple of screenies
    Charles Dolly likes this.
    10-26-2011 09:34 PM
  6. Charles Dolly's Avatar
    Yeah, I doubt adobe has released a version for 4.0 yet.
    beezy likes this.
    10-26-2011 10:09 PM
  7. MgWach's Avatar
    Hmmm. So I copied some music onto my phone, folders with MP3's, and some of them aren't recognized by the music program. Any ideas? It's simply not seeing them while Astro shows them.
    unbeleve likes this.
    10-26-2011 10:13 PM
  8. FL0OD's Avatar
    Go to Settings-Developer Options- HDCP settings click it to never check. Should do the trick.
    Sent from my neXus S 4g
    10-26-2011 10:18 PM
  9. MgWach's Avatar
    Nevermind, think I found the problem.
    10-26-2011 10:26 PM
  10. MgWach's Avatar
    Heh, thanks. I'll check that in the future.
    10-26-2011 10:26 PM
  11. tylerwatt12's Avatar
    http://forum.xda-developers.com/atta...3&d=1319223285
    best ICS LWP pulled from the galnex
    djw39 likes this.
    10-26-2011 10:27 PM
  12. turbofan's Avatar
    I was starting to go through and compile the links for fixing root and fonts and such, but since you said you're gonna include it in the next build... I'll just wait til after. Awesome work, really amazing what you guys have done.
    10-26-2011 11:05 PM
  13. consan's Avatar
    Will this work on SGS i9000?
    10-26-2011 11:41 PM
  14. rougegoat's Avatar
    Just in case this pops up again, what was the issue?
    10-26-2011 11:45 PM
  15. rougegoat's Avatar
    Short answer? Probably not. This is designed for the NS4G, though there is also a concurrent version for the NS that is being discussed. Unless you have one of those phones, this particular version probably will not work for you. Check the forums for the SGS i9000 to see if someone has adjusted it appropriately over there, or search in here to see if it's been mentioned(going from memory, I don't think it has been).
    Charles Dolly, beezy and turbofan like this.
    10-26-2011 11:47 PM
  16. Charles Dolly's Avatar
    "If you don't have a NS4G very good idea not to flash." If you try to flash it prepare to waste a couple hours getting your phone back.
    10-26-2011 11:53 PM
  17. consan's Avatar
    Thank you for your qiuck reply.. I find this thread on XDA ICS Android 4.0.1 SDK I9000 Port - Page 5 - xda-developers is that the same ROM like the one here?
    10-26-2011 11:56 PM
  18. ws6kid's Avatar
    Well flash is on the Galaxy Nexus No? We really need that dump that someone had mentioned earlier...
    10-26-2011 11:58 PM
  19. resetreflectt's Avatar
    http://i.imgur.com/MX7x3.png
    ADW Launcher EX seems to be way smoother than stock launcher.
    Also, that thing at the top, was it there in Gingerbread? Or is it something new?
    How do you have the new messaging, people and phone icons?
    Did I miss out on a new version of the rom? o.o
    10-26-2011 11:59 PM
  20. Charles Dolly's Avatar
    Yeah, it doesn't look like they had any luck getting it to Boot.
    beezy likes this.
    10-27-2011 12:00 AM
  21. Charles Dolly's Avatar
    Yes! Batting1000 was able to put it in the ROM just flash this on top of the one you already have.
    http://dl.dropbox.com/u/15668564/ICS...st-works-2.zip
    beezy likes this.
    10-27-2011 12:04 AM
  22. beezy's Avatar
    Yes we do,i've already sent of PM's to anyone that has said anything about a dump and they exactly what to do if they can get around the new nexus. If anyone doesn't know shoot me a PM if you get your hands on a GN and ill guide you them to getting us a system dump.
    It appears their working on it,i don't know much about that phone or i could tell you more they seem to have sum good ideas just hang in there and keep a eye on the threads to see what happens.
    consan likes this.
    10-27-2011 12:07 AM
  23. consan's Avatar
    yes , they have some problem with boot image but hopefully they will solve it
    10-27-2011 12:09 AM
  24. Charles Dolly's Avatar
    That would be great.... You get ICS and you get ICS everyone gets ICS!
    10-27-2011 12:17 AM
  25. bearsblack's Avatar
    this port is friggen awesome!
    native usb tether isnt working, and the phone stays on speaker in a call. im sure theres others, just throwing out what i found. thanks for this!
    10-27-2011 12:21 AM
