11-15-2011 09:48 PM
2,282 ... 4647484950 ...
tools
  1. evoldroid's Avatar
    Loving this Rom.Question guys do some games such as gunstrike from android market need flash to play?Also netflix?
    10-27-2011 02:11 PM
  2. Charles Dolly's Avatar
    I don't think that flash would be the problem, it's probably just that some app developers are not ready for ICS yet, and Netflix locks there app down so were probably going to need to wait for an official release from them for ICS.
    beezy likes this.
    10-27-2011 02:17 PM
  3. beezy's Avatar
    Is there going to be a change log posted
    Until this stop being a 'WIP",dirty,alpha,beta,no there will not be a official change log. Everyone involved is putting countless amount of time into the development and fixing things that a changelog would just be to hard to keep track of.
    Charles pretty much hit the nail on the head. A lot of app dev. need to update their app to ICS before they will work.
    10-27-2011 02:34 PM
  4. alexthearmo's Avatar
    Is there no way to send a group text message to a Google Group through the stock messaging app?
    Can anyone please confirm?
    10-27-2011 02:48 PM
  5. Csquared's Avatar
    Looks like you can only setup a group with email addresses. I'm unable to add a contact to a group that only has SMS.
    Sent from my Nexus S 4G using Tapatalk
    10-27-2011 02:57 PM
  6. beezy's Avatar
    I don't send group text, there probably is a couple people around here that do.Im sure when they see this they chime in on wether it works for them or not.
    10-27-2011 02:59 PM
  7. zeigan's Avatar
    here is what I posted on page 112
    "Alright guys New update is about to drop, Superuser now comes with the ROM Batting1000's Font and Icon work has been added, also the Boot Image has been Cleaned up Beezy has been working on Bluetooth all day hopefully it will be working in the next update.
    By the way, a full wipe is recommended for this update."
    Can't wait for bluetooth functionality! It's the only thing I really need for this to be my daily. I do a lot of driving and regular radio just isn't cutting it at all. Thanks for the update and keep up the outstanding work fellas!
    10-27-2011 03:00 PM
  8. alexthearmo's Avatar
    Thanks for the reply. That's a bummer. Google really failed on leaving that out.
    10-27-2011 03:05 PM
  9. Csquared's Avatar
    scratch my last response about only adding contacts with emails. I can add anyone to a group but after that i can not find a way to send eirher a group SMS or email.
    10-27-2011 03:14 PM
  10. Csquared's Avatar
    Anyone having problems deleting a SMS thread?
    10-27-2011 03:15 PM
  11. FL0OD's Avatar
    Anyone with the original ROM may want to do a full wipe. I did and having everything combined instead of layers of flashes for root and icons seemed to speed this up considerably. Just my experience.
    Sent from my Nexus S 4g
    10-27-2011 03:24 PM
  12. jlawou's Avatar
    trying to get espn radio to work, which isn't in the Market on this rom, with root explorer. There is a zip file in data/app and an apk that goes in data/app private. I've placed them both in the proper places and checked permissions but when I reboot the apk in data/app private is missing. Anyone have an idea?
    10-27-2011 03:26 PM
  13. beezy's Avatar
    That's what I think too, I meant to put full wipe in the OP but i was almost ready to pass out at the keyboard. Thanks.
    10-27-2011 03:28 PM
  14. beezy's Avatar
    There's your problem even if it stayed you wouldn't be able to use it. The footprint for ICS is not set to allow all apps yet and ESPN app might not be ready for ICS so all it would do is FC on you.
    10-27-2011 03:30 PM
  15. FL0OD's Avatar
    Yea you all really made this a lot more responsive. Everything is snappier. Appreciate all the hard work.
    beezy likes this.
    10-27-2011 03:49 PM
  16. jlopez1286's Avatar
    has any one had random reboots?? is it cuz i flashed over the previous builds?? and is doing a full wipe and reflashing the newest update the best way to go??
    10-27-2011 04:37 PM
  17. FL0OD's Avatar
    Was for me. Everything is quicker too. I didn't have any problems with the old one but I always like to do fresh installs when a bunch of things have been added to a rom. You should see a difference with a full wipe, I did.
    10-27-2011 04:50 PM
  18. jlopez1286's Avatar
    Ok, going to try it...thanks..
    10-27-2011 04:51 PM
  19. Batting1000's Avatar
    My battery is a little so-so, anyone else?
    10-27-2011 05:06 PM
  20. skola28's Avatar
    Were still talking about the ROM install process right? :P
    10-27-2011 05:10 PM
  21. Batting1000's Avatar
    Well actually maybe its not too bad. 11 he's and I'm on 37% battery but I do small bouts of charging throughout the day.
    10-27-2011 05:11 PM
  22. aldouse's Avatar
    the rom is great! quick and smooth like cream! battery life is on par with the OEM nexus for me. so i dont see too much of a power difference...
    my only gripe now is TB doesnt want to work anymore. sigh... quite sad but nonetheless great!
    10-27-2011 05:16 PM
  23. landerg's Avatar
    Mine certainly was in the initial build (am about to update to 3.2). I went to the battery section under settings and saw that the Wallet app had used up over 70% of the used power since rebooting my phone (and fully charging).
    10-27-2011 05:24 PM
  24. crankless's Avatar
    Wallet was causing countinous sync for me so I removed it, might be your case also
    10-27-2011 05:29 PM
  25. Xhaotic's Avatar
    loving the rom... very smooth on my ns4g.
    i made the idiotic mistake of not backing up my stock before i flashed into this.
    can anyone walk me through or pm me the steps to getting back to stock or at least something closest to it / or will allow OTA update when official ICS is released? it's a sprint NS4G
    any help is highly appreciated
    10-27-2011 05:39 PM
