11-15-2011 09:48 PM
2,282 ... 4748495051 ...
tools
  1. tylerwatt12's Avatar
    loving the rom... very smooth on my ns4g.
    i made the idiotic mistake of not backing up my stock before i flashed into this.
    can anyone walk me through or pm me the steps to getting back to stock or at least something closest to it / or will allow OTA update when official ICS is released? it's a sprint NS4G
    any help is highly appreciated
    One Click Stock
    [APP] One Click Return to stock for nexus s 4g - xda-developers
    Xhaotic likes this.
    10-27-2011 05:41 PM
  2. pitmasterme's Avatar
    My battery is a little so-so, anyone else?
    Sent from my Nexus S 4G using Tapatalk
    Uhhhhhh...... getting about 5 hours....that's with my normal use.....about 3 hrs of screen on time...thankfully I have 4 batteries!
    Long days and pleasant nights............
    10-27-2011 05:45 PM
  3. djw39's Avatar
    http://forum.xda-developers.com/show....php?t=1078213
    Xhaotic likes this.
    10-27-2011 05:45 PM
  4. D2dyno's Avatar
    Beezy, how often are you planning/expecting to release updates of the Rom?
    10-27-2011 05:52 PM
  5. Xhaotic's Avatar
    Awesome I'll give it a go... TY so much for the quick response.
    I'll check that out also, rooted stock sounds good!
    EDIT: Any idea if that one-click Stock will allow OTA updates when avail?
    10-27-2011 05:58 PM
  6. adamw1101's Avatar
    Ive been getting graphical glitches. Also if you put the phone into landscape mode while in navigation the phone crashes or screen shuts off and cancel the navigation currently running 3.2
    edit it seems the problem is resolved itself I'm not sure why but the landscape problem no longer exists
    10-27-2011 05:59 PM
  7. MgWach's Avatar
    Just in case this pops up again, what was the issue?
    Well, there was a folder that was screwing up everything else and when I removed it, everything showed up. Not sure why it did that but eh, no loss.
    10-27-2011 06:02 PM
  8. MgWach's Avatar
    So, question. I have music on my sdcard. If I'm doing a full wipe to install the latest ROM, do I have to wipe out the sdcard and re-add the music back or can I just remove the sdcard when flashing?
    10-27-2011 06:10 PM
  9. D2dyno's Avatar
    First of all there is no physical SD card in the Nexus S. Secondly, no you do not have to wipe the "internal" SD card.
    10-27-2011 06:14 PM
  10. MgWach's Avatar
    Oops. I'm still thinking of my old phone LOL. Sorry, busy day. Ok, thanks. *facepalm* Ok, so when you say to a full wipe, what does that mean exactly?
    10-27-2011 06:17 PM
  11. MgWach's Avatar
    Nevermind, got it. Thanks!
    10-27-2011 06:40 PM
  12. rougegoat's Avatar
    Anyone having problems deleting a SMS thread?
    can you be more specific? "Problems" is a very vague word.
    10-27-2011 06:56 PM
  13. Csquared's Avatar
    Im unable to delete a SMS conversation.
    10-27-2011 06:57 PM
  14. D2dyno's Avatar
    Regarding SMS, I discovered a issue, where certain letters, such as "y,g" and other letters that "dip" below the line of a message, are missing the bottom half of the letter. However, it does not happen for every message that contains those letters. weird.
    10-27-2011 07:02 PM
  15. rougegoat's Avatar
    When you long press, does it highlight the SMS conversation? If so, there's a trashcan icon you can click in the lower left corner that should delete all selected(yes, you can select multiple at one time) conversations. Or is the issue that you are doing this and it is still not deleting? Are you using the stock app or a third party? Just saying, "I can't do this" without specifying what you've tried to do is very vague to say the least.
    10-27-2011 07:10 PM
  16. evoldroid's Avatar
    Whats this blackhole app ??????
    10-27-2011 07:20 PM
  17. rougegoat's Avatar
    Live wallpaper
    10-27-2011 07:22 PM
  18. Batting1000's Avatar
    I think it's a LWP. I disabled the app though.
    10-27-2011 07:22 PM
  19. david279's Avatar
    Flash not working in browser. Is this a know issue?
    10-27-2011 07:35 PM
  20. SHOCKER07's Avatar
    I can't download the ROM from my phone...why? how do I fix this?
    10-27-2011 07:38 PM
  21. D2dyno's Avatar
    It's not an issue, it's an incompatibility. Flash has not yet been made to work for ICS.
    10-27-2011 07:41 PM
  22. Batting1000's Avatar
    Boot into recovery, wipe data/cache, install from zip, choose the ROM zip, and reboot.
    10-27-2011 07:43 PM
  23. Achtungtree's Avatar
    Stupid question I know. But I have been seeing around the net a verison of this rom with an updated lock-screen and the new Icons. Where can I get that version? Has the rom on the first page been updated?
    10-27-2011 07:49 PM
  24. Batting1000's Avatar
    Yes, the 4.0 icons are in the latest version. The lockscreen hasn't changed except for the clock font (I think, I use widgetlocker), but it's still the 4.0 lockscreen.
    10-27-2011 07:53 PM
  25. 702DROID's Avatar
    anyone else having problems getting Facebook to sync???
    10-27-2011 09:03 PM
