Just tried with Franco's Kernel, made no difference. I'll try with some others.
this is the app that keeps on force closing. the one that is in chinese leters
Probably a hardware issue or kernel issue try flashing a gsm kernel this is built with the kernel from pete's cdma release don't know if the kernels are different. Has to be a anykernel type of zip.
Edit* does data/3G connect for you?
It doesn't. I don't know if it's the roms fault, though, as it didn't connect on another CM7 rom either.
I've tried with Franco's Kernel and Matr1x, none of them fixed the capacative.
so i tried this on my ns4g for sprint .... couldnt get pass the first screen , i know its a WIP just wanted to take a look and i must say i likes .... cant wait to give this a run
Tried to flash this on my NS4G using Clockwork v5.0.2.0 and I got
E:Can't open /sdcard/ICS_sdk-port-dirty-1b.zip
(bad)
Installation aborted.
probably cause i did not sign the zip toggle the verification and it should flash it if not download a new copy.
