11-15-2011 09:48 PM
2,282 ... 4849505152 ...
tools
  1. JBLunz's Avatar
    Yes... Facebook won't sync since its not Google. Big push for G+ in ICS. I found that using FriendCaster and setting the contact sync up works perfectly...
    10-27-2011 09:06 PM
  2. ntider's Avatar
    I flashed the update (after wiping cache, data). And my market wasn't letting me download anything. I've been running the older version for two days without major issue.
    10-27-2011 09:08 PM
  3. tylerwatt12's Avatar
    things dont like to work on first boot, reboot after opening a new app for the first time
    10-27-2011 09:10 PM
  4. garywright0's Avatar
    Boy i sure hope I am not asking something that has been answered. is everyone else able to turn on 4G? It only looks like i am getting 3G but wasnt sure if i did something wrong. Other that i have NO other issues that i have found.
    10-27-2011 09:20 PM
  5. D2dyno's Avatar
    4G capabilities have not been included in this release, as it is not that much of a priority over Bluetooth and such.
    10-27-2011 09:27 PM
  6. garywright0's Avatar
    Thanks for that...!
    10-27-2011 09:28 PM
  7. sandyto81's Avatar
    Here is a link to the market .APK hopefully that will work.
    com.android.vending-1.apk
    Still can`t work bro...
    10-27-2011 09:37 PM
  8. Paul627g's Avatar
    anyone else having problems getting Facebook to sync???
    Sent from my Nexus S 4G
    This is getting to be a trend... Everyone needs to take into consideration this is not an official release, the build.prop finger print is not setup yet to allow full Market access and many if not most applications have not yet been updated to support ICS/Android 4.0
    So for those 3rd party apps from the Market that do work, excellent... Those that don't and are having FC's, sync issues, etc... Well now you have a better explanation.
    Another 2 or 3 weeks out from now things will be a different story as devs and companies begin to udpate their software to work with ICS.
    JBLunz likes this.
    10-27-2011 09:47 PM
  9. adamw1101's Avatar
    the price you pay for living on the bleeding edge.
    Sent from my Nexus S 4G using Tapatalk
    10-27-2011 09:51 PM
  10. bnitty's Avatar
    Facebook doesn't sync with this bkuz there's no option for it to sync, but Friendcaster syncs fine.
    10-27-2011 10:04 PM
  11. crzycrkr's Avatar
    No Facebook sync on Nexus phones starting with the Nexus S
    10-27-2011 10:13 PM
  12. RMM1981's Avatar
    Facebook is for losers...
    10-27-2011 10:23 PM
  13. jinsoku3g's Avatar
    Right? You guys are running ICS... Didnt your phone already tell you Google+ is what its all about?
    Sent from my Transformer TF101 using Tapatalk
    beezy, faizalmzain and decalex like this.
    10-27-2011 10:26 PM
  14. FL0OD's Avatar
    good stuff. I needed a good laugh.
    10-27-2011 11:10 PM
  15. amehdi43's Avatar
    Any news on the G+ Integration yet?
    10-27-2011 11:39 PM
  16. rougegoat's Avatar
    It's one of the first things that the setup asks you to do, and it works pretty seamlessly from my toying around with it. Was there some issue with it that I wasn't aware of?
    Charles Dolly likes this.
    10-27-2011 11:48 PM
  17. jc4gavejc's Avatar
    You should update the first page screenshot, and package the Phase Beam LW with the ROM
    10-28-2011 12:58 AM
  18. Charles Dolly's Avatar
    Alright, Hold tight... Jon is building a market zip that you can flash. That should fix your problems.
    10-28-2011 01:32 AM
  19. Charles Dolly's Avatar
    Here you go sandyto81, take this .APK use Root explorer and put this in System > App. Stick that file there and reboot then you will have Market.
    10-28-2011 01:39 AM
  20. Dammit_Dan's Avatar
    Working pretty good. Wishing I had 4G, WiFi and Bluetooth. Besides that nice to play around with.
    10-28-2011 02:10 AM
  21. Charles Dolly's Avatar
    There is no word on when we will see 4g, Bluetooth hopefully will be in the next release, WiFi is working, after you turn it on disable WiFi security checks. Hopefully that will do it for you.
    10-28-2011 02:17 AM
  22. ZeeraF#AC's Avatar
    so far im loving the update ... only thing i dont like is the fact that now the ringtone volume and notification volume is the same .... not like in gb where u could set them seperate
    10-28-2011 08:34 AM
  23. jlopez1286's Avatar
    is this the new market version??
    10-28-2011 08:44 AM
  24. Formula84's Avatar
    I seem to be getting alot of random reboots on the 3.2 when playing with the stock launcher, adding widgets etc. On the test 2 I did not get this issue... this was a fresh install and no data was restored.
    10-28-2011 09:01 AM
  25. dawnadevin's Avatar
    3g bar and icon keep shrinking for some reason after an hour after flashing both versions love ithe rom
    10-28-2011 10:01 AM
