11-15-2011 09:48 PM
2,282 ... 4950515253 ...
tools
  1. djw39's Avatar
    You should update the first page screenshot, and package the Phase Beam LW with the ROM
    Phase beam is in there, it's just not the default.
    Interesting philosophical question, what do we consider ICS features vs. Galaxy Nexus features? That is, should this rom boot up with Nexus S boot animation and LWP, or should it default to Galaxy Nexus equivalents?
    Sent from my Nexus S 4G using Tapatalk
    10-28-2011 10:01 AM
  2. ZeeraF#AC's Avatar
    okay so im getting some issues with the market , i cant seem to download anything ... now i see someone posted a market apk , but without root explorere or es file explorer i can do anything and i cant download either .... is there a flashable zip to solve the market issue ???
    10-28-2011 10:21 AM
  3. Gee's Avatar
    Right? You guys are running ICS... Didnt your phone already tell you Google+ is what its all about?
    Sent from my Transformer TF101 using Tapatalk
    People I personally know on G+: 34, most not active.
    People I personally know on Facebook: 651, almost all are active.
    MgWach likes this.
    10-28-2011 10:51 AM
  4. mntbkr's Avatar
    weird issue I'm having (I'm just nit picking here, I understand it's probably an app issue not compatible with 4.0) is that on Pandora on portrait it won't show the album art, however flip it to landscape and it shows up, anyone else notice this? other than that it's working great.
    For those having issues with Titanium backup, go to the SU app and open preferences go to SU binary and tap to update it's going to say it's up to date but just update anyway. It will also update Busybox and that was what got my Titanium working. Not sure if it was an oversight but Busybox seems to be missing and Titanium needs it to work.
    10-28-2011 11:35 AM
  5. Loco Wit The Pre's Avatar
    Once this is ACTUALLY STABLE - it should be called experimental to be correct I will make this bad boy my DD. Without 3g audio, its no point in using. Keep up the great work with our impatience.
    Charles Dolly likes this.
    10-28-2011 11:55 AM
  6. hughfitzgerald's Avatar
    What does it mean that "3G audio doesn't work"? I've got it installed, and 3G is working, audio is working, and audio streamed over 3G is working.
    10-28-2011 11:57 AM
  7. ZeeraF#AC's Avatar
    okay this market is really starting to **** me off !!!! everything i try to download i get an error message , but when i go to "my apps" i see it there trying to download but the bar just keeps moving and nothing happens
    10-28-2011 12:28 PM
  8. decalex's Avatar
    1. Chillax yo. 2. Have u tried the basic cache clear, and restart market? I've had this issue, let it sit, and then I see later the app updated.. After trying ev else.
    . . NS4G . . CM7 . .
    10-28-2011 01:22 PM
  9. anarchtic's Avatar
    I am poor so I can't give you money. But I because your the first person to make ICS rom for my phone Nexus s 4g. Here is an avatar I made for you. i dont like your current one. My website is JohnHolt.net if you would like to promote me.
    My post count isnt high enough to send pm sorry.
    beezy likes this.
    10-28-2011 01:28 PM
  10. decalex's Avatar
    Afik, this will be google's new flagship, running stock, vanilla ics. So id imagine these are all ics bells and whistles. I'm trying to remember the orig bootani on ns4g.. Pretty sure it was the nexus s ani, right? Minimal samsungness..
    10-28-2011 01:28 PM
  11. decalex's Avatar
    Ack perspective
    10-28-2011 01:31 PM
  12. Charles Dolly's Avatar
    Are you sure you did a full wipe before you flashed the rom? ie Factory reset > Cache > Dalvik
    10-28-2011 01:40 PM
  13. Charles Dolly's Avatar
    is this the new market version??
    Yep.
    10-28-2011 01:43 PM
  14. jondevere's Avatar
    make sure to be specific.. when you say FACTORY RESET, cache, etc... This should obviously be done from within Recovery.....
    10-28-2011 02:01 PM
  15. intheb0x's Avatar
    Using the new alpha, what its phase beam and is it included?
    Everything is working great.
    Cheers to all!
    Sent from my Nexus S 4G with Ice Cream Sandwich
    10-28-2011 02:14 PM
  16. jrizzut1's Avatar
    this is so freaking cool...i can't wait for the official update which is apparently a few weeks away
    even though this is WIP its running buttery smooth for me...only thing
    anyone know how to do the face unlock thing?
    10-28-2011 02:18 PM
  17. Charles Dolly's Avatar
    Face unlock is not working right now.
    10-28-2011 02:19 PM
  18. anarchtic's Avatar
    Until it works try using Download Visidon AppLock Android Application - Android Apps Labs
    it is a face unlocker for certain apps on your android device
    10-28-2011 02:22 PM
  19. jrizzut1's Avatar
    i see and will do on that app...thanks guys and thank you beezy for the delicious ice creamy goodness
    10-28-2011 02:41 PM
  20. intheb0x's Avatar
    Cheers to all!
    Nvm seen it, like black hole better.
    Awesome
    10-28-2011 02:45 PM
  21. intheb0x's Avatar
    How do I tell if I got the new market?
    It looks normal to me.
    Its
    3.1.2
    10-28-2011 02:48 PM
  22. adamw1101's Avatar
    has anyone had success using friend caster to sync Facebook contacts? And was there a special way to do it?
    10-28-2011 03:01 PM
  23. jrizzut1's Avatar
    anyone try to update gmaps and or google plus and get a package is unsigned error? Based on CM use, I would think that i'd have to flash a GApps package, but is there even an ICS GApps package out yet?
    10-28-2011 03:11 PM
  24. adamw1101's Avatar
    no there is not its most likely a market error
    edit if I'm not mistaken this version of ice cream sandwich we're running is not signed. Maybe that is your issue
    10-28-2011 03:22 PM
  25. jlopez1286's Avatar
    Yep.
    I looked at my version in settings and it says 3.1.2... i thought the new one was 3.2??
    10-28-2011 03:24 PM
