11-15-2011 09:48 PM
2,282 ... 5556575859 ...
tools
  1. cntchds's Avatar
    Thanks for the quick response. I'll check it out. : )
    Sent from my Nexus S 4G using Tapatalk
    10-30-2011 02:38 PM
  2. D2dyno's Avatar
    Noticed 2 problems with the music app. 1: if I press home, or switch between apps, the music i'm playing stops. 2: it plays (or thinks it plays) video files.
    10-30-2011 02:57 PM
  3. djw39's Avatar
    2: out play (or thinks it plays) video files.
    10-30-2011 03:08 PM
  4. keebler021's Avatar
    No prob, Bob :-)
    Sent on Ice Cream Sandwich from the future of Android
    10-30-2011 03:35 PM
  5. Batting1000's Avatar
    Everyone should share their ICS homescreens. Let's see how you've set everything with the new widgets, dock, and folders!
    Here's mine. Pretty empty for me right now, but I like the look.
    10-30-2011 03:37 PM
  6. kjaved373's Avatar
    Just a little curious. I tried extracting some apks from the rom to see if it works on other roms and tried to install them but it says problem parsing or something like that. Im guessing it's same for all roms, why is that?
    Sent from my Google Nexus S 4G
    10-30-2011 03:44 PM
  7. Batting1000's Avatar
    The apks from this ROM will only work on this ROM because of the framework. They only work with the ICS framework.
    You could also try deleting an apk then installing the one from this ROM.
    10-30-2011 03:47 PM
  8. Batting1000's Avatar
    Wanted to point out a few things I noticed in anything that has a gray scroll bar on the left side of a screen when scrolling.
    The scrool bar seems to be a little far away from the right side of the screen. Usually, the bar is touching the right side of the screen, but it doesn't seem to be in the ROMs menus.
    Example:
    Another thing is that the Manage Apps screen doesn't seem to be sized right for the screen. (I also pointed out the scroll bar is this image too.)
    As you can see, the categories at the top are a little small and bunch, and the UI itself doesn't extend to the screen sides.
    Just wanted to point these things out see we're aware, that's all.
    EDIT:
    Here's a picture of Manage Apps from the emulator. Fills up the screen more
    10-30-2011 04:09 PM
  9. grumpysasquatch's Avatar
    Hey, just wondering what's up with hero_over? I tried pming him but didn't realize I needed 5 posts. I'm really interested in seeing what he's been doing with this beautiful rom.
    10-30-2011 04:24 PM
  10. Batting1000's Avatar
    Let's keep things on topic.
    10-30-2011 04:26 PM
  11. grumpysasquatch's Avatar
    I thought the progression of ICS was the main point of this.
    10-30-2011 04:38 PM
  12. vhgomez36's Avatar
    Example:
    Click to view quoted image
    EDIT:
    I use the larger font. It looks better in my opinion and fills the display better.
    10-30-2011 04:40 PM
  13. pitmasterme's Avatar
    hey I noticed you have a voicemail icon in your status bar is that to a stock visual voicemail. I only ask because I use google voice for my voicemail and if ice cream sandwich now comes with the visual voicemail app I would like to use it
    Just standard voicemail....
    Long days and pleasant nights............
    10-30-2011 05:09 PM
  14. peterthejamaican's Avatar
    Is there a way to get the bluetooth working on this port
    10-30-2011 05:43 PM
  15. Batting1000's Avatar
    It's being worked on, hang tight.
    10-30-2011 05:52 PM
  16. intheb0x's Avatar
    Example:
    EDIT:
    Same issue here, it makes the screen look smaller than it is lol.
    I'll post some screen shots, but nothing special really, using the same stuff I was with gingerbread.
    Sent from my Nexus S 4G with Ice Cream Sandwich
    10-30-2011 05:58 PM
  17. intheb0x's Avatar
    Like?
    Wishing we had the option to remove that search bar, id love the extra real estate.
    10-30-2011 06:02 PM
  18. Batting1000's Avatar
    Like?
    I like the search widget, although it can be a tad slow at times, as can launching the browser. Been using the ROM since it came out though, can't go back.
    10-30-2011 06:09 PM
  19. FL0OD's Avatar
    Like?
    I agree, its nice having it there but I would much rather have the space.
    sent from my neXus S 4G
    10-30-2011 06:28 PM
  20. Paul627g's Avatar
    Ive already been looking at removing that search bar... That and many other little tweaks will be some of the first things probably done on theming ICS.
    intheb0x likes this.
    10-30-2011 06:35 PM
  21. Batting1000's Avatar
    Whatever you do, make a version with the search bar, in case I like your theme. :P
    10-30-2011 06:40 PM
  22. xJRECHx's Avatar
    So I want to try and get the swiping animations in the app drawer going if any dev wants to help out shoot me a PM.
    Batting1000 likes this.
    10-30-2011 06:42 PM
  23. Batting1000's Avatar
    I want them too, but I'm not experienced enough. If you need me to test anything, let me know.
    10-30-2011 06:48 PM
  24. Paul627g's Avatar
    The whole scroll bar misalignment issue probably has something to do with the multiple resolutions and screen sizes that ICS handles. Something probably isn't just tweaked correctly at this early stage. After looking at the framework-res and most apps associated with ICS so far they have almost a dozen "png or image" folders now each dedicated to fit a certain format/device depending on if its tablet or phone that its running on. Normally you had ....
    drawable (this was xml codes)
    drawable-hdpi (most commonly used images/pngs)
    drawable-land-hdpi (extra pngs specially thrown in for landscape mode)
    Now there is half a dozen or better drawable-xxxxx folders since ICS combines both tablet and phone under one OS.
    Basically, it may have to wait until official release or source is dropped before this is ironed out on some of the exact alignment issues.
    10-30-2011 06:50 PM
  25. Paul627g's Avatar
    Actually after looking into the code a bit... If you don't use the included stock launcher then the search bar doesn't appear at the top of the home screen.
    I installed ADW EX Launcher and search bar at the top was gone.
    The code for the search bar is in two parts.... Part of it to "activate it" is in the Launcher2.apk and the rest of the code is in the framework-res.apk.
    So if you don't want that search bar at the moment just flash a 3rd party launcher. Otherwise I will try and post a modded Launcher to flash a little later this evening. Shouldn't be a problem to remove.
    10-30-2011 07:01 PM
