11-15-2011 10:48 PM
2,282 ... 5657585960 ...
tools
  1. Batting1000's Avatar
    Actually after looking into the code a bit... If you don't use the included stock launcher then the search bar doesn't appear at the top of the home screen.
    I installed ADW EX Launcher and search bar at the top was gone.
    The code for the search bar is in two parts.... Part of it to "activate it" is in the Launcher2.apk and the rest of the code is in the framework-res.apk.
    So if you don't want that search bar at the moment just flash a 3rd party launcher. Otherwise I will try and post a modded Launcher to flash a little later this evening. Shouldn't be a problem to remove.
    Yeah, I was just saying that if you make a themed version, make a version that includes the Google search bar at the top, because I like it and I'll want it if I like your modded launcher.
    10-30-2011 08:06 PM
  2. vhgomez36's Avatar
    Hey guys I manage to change my Android version from IceCreamSandwich to 4.0. Also my build number just says IceCreamSandwich IRK40C. LOL
    10-30-2011 08:09 PM
  3. Batting1000's Avatar
    How? lol
    10-30-2011 08:13 PM
  4. NickNanko's Avatar
    I don't know if this is only my phone but the wallpaper crop seems to be off for all the wallpapers that i download from something like zedge, and even the stock gingerbread wallpapers too. Is there a way to fix this or some place i can get wallpapers that actually FIT. Thanks.
    10-30-2011 08:17 PM
  5. berkmanmd's Avatar
    modify the build.prop
    10-30-2011 08:20 PM
  6. vhgomez36's Avatar
    How? lol
    Just by editing build.prop in system. You can change the Android version and the Build # to whatever you want.
    10-30-2011 08:21 PM
  7. Batting1000's Avatar
    Ok, thanks, and what are you guys using to view/edit xml's?
    10-30-2011 08:25 PM
  8. Batting1000's Avatar
    What do I change in build.prop?
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=IRK40C
    ro.build.display.id=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys
    ro.build.version.incremental=162682
    ro.build.version.sdk=13
    ro.build.version.codename=IceCreamSandwich
    ro.build.version.release=IceCreamSandwich
    ro.build.date=Tue Aug 9 16:52:52 PDT 2011
    ro.build.date.utc=1312933972
    ro.build.type=userdebug
    ro.build.user=android-build
    ro.build.host=android-test-34.mtv.corp.google.com
    ro.build.tags=test-keys
    ro.product.model=Nexus S 4G
    ro.product.brand=google
    ro.product.name=sojus
    ro.product.device=crespo4g
    ro.product.board=herring
    ro.product.cpu.abi=armeabi-v7a
    ro.product.cpu.abi2=armeabi
    ro.product.manufacturer=samsung
    ro.product.locale.language=en
    ro.product.locale.region=US
    ro.wifi.channels=
    ro.board.platform=s5pc110
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=crespo4g
    # Do not try to parse ro.build.description or .fingerprint
    ro.build.description=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys
    ro.build.fingerprint=google/sojus/crespo4g:IceCreamSandwich/IRK40C/162682:userdebug/test-keys
    ro.build.characteristics=nosdcard
    # end build properties
    # system.prop for smdkc110
    rild.libpath=/vendor/lib/libsec-ril.so
    rild.libargs=-d /dev/ttyS0
    ro.sf.lcd_density=240
    ril.ecclist=911,#911,*911
    # ADDITIONAL_BUILD_PROPERTIES
    ro.cdma.home.operator.numeric=310120
    ro.cdma.home.operator.alpha=Sprint
    ro.telephony.default_network=4
    ro.wimax.interface=uwbr0
    ro.opengles.version=131072
    wifi.interface=wlan0
    wifi.supplicant_scan_interval=15
    dalvik.vm.heapstartsize=5m
    dalvik.vm.heapgrowthlimit=48m
    dalvik.vm.heapsize=128m
    ro.config.ringtone=Sceptrum.ogg
    ro.config.notification_sound=Castor.ogg
    ro.com.android.dateformat=MM-dd-yyyy
    ro.com.android.dataroaming=false
    ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
    ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
    ro.com.google.clientidbase=android-google
    ro.config.alarm_alert=Alarm_Classic.ogg
    ro.com.android.wifi-watchlist=GoogleGuest
    ro.error.receiver.system.apps=com.google.android.feedback
    ro.setupwizard.enterprise_mode=1
    keyguard.no_require_sim=true
    drm.service.enabled=true
    dalvik.vm.lockprof.threshold=500
    dalvik.vm.dexopt-flags=m=y
    net.bt.name=Android
    dalvik.vm.stack-trace-file=/data/anr/traces.txt
    10-30-2011 08:27 PM
  9. Paul627g's Avatar
    You have to use APK TOOL or APK Manager to decompile the apks and then Notepad ++ to view the XMLs...
    At this point I really wouldn't recommend messing with it as I'm having enough of a hurdle doing these little things because without official source being dropped the tools required to de compile (baksmali and APK TOOL) are not yet updated to support ICS and de compiling has been a real touch and go situation....
    On another subject about modding in the build.prop, you can change those lines in the About Phone to say whatever you like... They can say Batting1000's ROM if you like... That is why in the early stages months ago when the first leaked pics of ICS came out people said it was themes and then people just modified the build.prop to say ICS 4.0 or whatever they like... Oldest trick in the book...
    vhgomez36 likes this.
    10-30-2011 08:29 PM
  10. vhgomez36's Avatar
    The forth and eighth line up to the equal signs starting at the end.
    10-30-2011 08:31 PM
  11. vhgomez36's Avatar
    Its fairly easy though and I know I'm going to wipe it once the update comes up.
    10-30-2011 08:34 PM
  12. Batting1000's Avatar
    Thanks! Never really knew about build.prop. Feel stupid now :P
    Sent from my Nexus S 4G using Tapatalk
    10-30-2011 08:35 PM
  13. Paul627g's Avatar
    ro.build.id=IRK40C
    ro.build.display.id=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys (this will change the BUILD NUMBER)
    (I forget which one of these two but one will change the ANDROID VERSION)
    ro.wifi.channels=
    ro.error.receiver.system.apps=com.google.android.f eedback
    net.bt.name=Android
    The rest all have a purpose and I wouldn't change them because they will affect things in the ROM. The only other things to really toy with is in the last paragraph I highlighted 3 lines that controls the stock setting for the notifications, ringer and alarm sounds...
    mcollini likes this.
    10-30-2011 08:37 PM
  14. Batting1000's Avatar
    ro.build.id=IRK40C
    [HL]ro.build.display.id=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys[/HL] (this will change the BUILD NUMBER)
    [HL]ro.build.version.codename=IceCreamSandwich
    ro.build.version.release=IceCreamSandwich[/HL] (I forget which one of these two but one will change the ANDROID VERSION)
    ro.wifi.channels=
    [HL]ro.config.ringtone=Sceptrum.ogg
    ro.config.notification_sound=Castor.ogg[/HL]
    [HL]ro.config.alarm_alert=Alarm_Classic.ogg[/HL]
    net.bt.name=Android
    Awesome. Thank you.
    10-30-2011 08:39 PM
  15. vhgomez36's Avatar
    I never expect everyone to know everything. I learn something everyday from the very helpful forum community.
    10-30-2011 08:41 PM
  16. vhgomez36's Avatar
    Awesome. Thank you.
    Don't forget to remove the backup file that is created and save it somewhere else. Then set permission if it is not set already.
    10-30-2011 08:47 PM
  17. D2dyno's Avatar
    Set permission to what?
    10-30-2011 08:51 PM
  18. Batting1000's Avatar
    What do you mean by set the permission?
    10-30-2011 08:51 PM
  19. vhgomez36's Avatar
    When you edit the file...you the to change permission to rw-r--r-- if its not already there. You need to change them in order for the changes to take affect then reboot phone.
    Sorry Man watching the Cowboy vs Eagles game.
    10-30-2011 08:57 PM
  20. Batting1000's Avatar
    When you edit the file...you the to change permission to rw-r--r-- if its not already there. You need to change them in order for the changes to take affect.
    Do need root explorer or something for that?
    10-30-2011 08:59 PM
  21. vhgomez36's Avatar
    It's quicker plus you can do it anywhere.
    10-30-2011 09:02 PM
  22. vhgomez36's Avatar
    Sorry I mist your post. I'm guessing you know what its about now.
    10-30-2011 09:05 PM
  23. D2dyno's Avatar
    It didn't change it, and my phone is stuck on bootscreen.
    10-30-2011 09:06 PM
  24. vhgomez36's Avatar
    Did you make an Nandroid?
    10-30-2011 09:08 PM
  25. D2dyno's Avatar
    yeah. what happened?
    10-30-2011 09:09 PM
