11-15-2011 09:48 PM
2,282 ... 5758596061 ...
tools
  1. vhgomez36's Avatar
    yeah. what happened?
    GOOD. You just need to change the 4rth and 8th line.
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=IRK40C
    ro.build.display.id=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys
    ro.build.version.incremental=162682
    ro.build.version.sdk=13
    ro.build.version.codename=IceCreamSandwich
    ro.build.version.release=IceCreamSandwich
    ro.build.date=Tue Aug 9 16:52:52 PDT 2011
    ro.build.date.utc=1312933972
    ro.build.type=userdebug
    ro.build.user=android-build
    ro.build.host=android-test-34.mtv.corp.google.com
    ro.build.tags=test-keys
    ro.product.model=Nexus S 4G
    ro.product.brand=google
    ro.product.name=sojus
    ro.product.device=crespo4g
    ro.product.board=herring
    ro.product.cpu.abi=armeabi-v7a
    ro.product.cpu.abi2=armeabi
    ro.product.manufacturer=samsung
    ro.product.locale.language=en
    ro.product.locale.region=US
    ro.wifi.channels=
    ro.board.platform=s5pc110
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=crespo4g
    # Do not try to parse ro.build.description or .fingerprint
    ro.build.description=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys
    ro.build.fingerprint=google/sojus/crespo4g:IceCreamSandwich/IRK40C/162682:userdebug/test-keys
    ro.build.characteristics=nosdcard
    # end build properties
    # system.prop for smdkc110
    rild.libpath=/vendor/lib/libsec-ril.so
    rild.libargs=-d /dev/ttyS0
    ro.sf.lcd_density=240
    ril.ecclist=911,#911,*911
    # ADDITIONAL_BUILD_PROPERTIES
    ro.cdma.home.operator.numeric=310120
    ro.cdma.home.operator.alpha=Sprint
    ro.telephony.default_network=4
    ro.wimax.interface=uwbr0
    ro.opengles.version=131072
    wifi.interface=wlan0
    wifi.supplicant_scan_interval=15
    dalvik.vm.heapstartsize=5m
    dalvik.vm.heapgrowthlimit=48m
    dalvik.vm.heapsize=128m
    ro.config.ringtone=Sceptrum.ogg
    ro.config.notification_sound=Castor.ogg
    ro.com.android.dateformat=MM-dd-yyyy
    ro.com.android.dataroaming=false
    ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
    ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
    ro.com.google.clientidbase=android-google
    ro.config.alarm_alert=Alarm_Classic.ogg
    ro.com.android.wifi-watchlist=GoogleGuest
    ro.error.receiver.system.apps=com.google.android.f eedback
    ro.setupwizard.enterprise_mode=1
    keyguard.no_require_sim=true
    drm.service.enabled=true
    dalvik.vm.lockprof.threshold=500
    dalvik.vm.dexopt-flags=m=y
    net.bt.name=Android
    dalvik.vm.stack-trace-file=/data/anr/traces.txt
    EXAMPLE:
    Ro Build. Display ID= TO WHATEVER (4th line)
    Ro.Build Version.Release= TO WHATEVER (8th line)
    Then exit and save
    Then set permission rw-r--r--
    Then reboot
    D2dyno and Batting1000 like this.
    10-30-2011 08:16 PM
  2. Batting1000's Avatar
    Changed the version to 4.0. What should I make the "display" one? :P
    10-30-2011 08:20 PM
  3. vhgomez36's Avatar
    I just left it as IceCreamSandwich...that's what it is anyway.LOL
    10-30-2011 08:22 PM
  4. Batting1000's Avatar
    Now my home button doesn't work. Restoring to a backup, then i'll try again.
    10-30-2011 08:23 PM
  5. vhgomez36's Avatar
    Try fixing permission from recovery first. My home button works fine.
    10-30-2011 08:26 PM
  6. Batting1000's Avatar
    All is good now.
    Looks better than "IceCreamSandwich"
    10-30-2011 08:31 PM
  7. vhgomez36's Avatar
    All is good now.
    Cool. Matter of opinion. I'm sure alot of people like IceCreamSandwich.
    10-30-2011 08:37 PM
  8. Batting1000's Avatar
    Yeah, just my opinion. Thanks for you help!
    10-30-2011 08:54 PM
  9. Dammit_Dan's Avatar
    I don't know how people have wifi working. With the older and newer versions it has never worked for me yet. All states poor wifi connection the instantly disconnects.
    10-30-2011 08:57 PM
  10. D2dyno's Avatar
    ro.build.id=IRK40C
    ro.wifi.channels=
    net.bt.name=Android
    EXAMPLE:
    Then exit and save
    Then reboot
    Re-flashed, changed file, and now it works! thanks a bunch, it's pretty sweet.
    Batting1000 likes this.
    10-30-2011 08:59 PM
  11. intheb0x's Avatar
    Thanks! Never really knew about build.prop. Feel stupid now :P
    Sent from my Nexus S 4G using Tapatalk
    Recently i changed Nexus s 4G to nexus s and rebooted in order to get the newest version of Swype because with the 4G it shows a older version.
    Sent from my Nexus S 4G with Ice Cream Sandwich
    10-30-2011 09:01 PM
  12. intheb0x's Avatar
    Actually after looking into the code a bit... If you don't use the included stock launcher then the search bar doesn't appear at the top of the home screen.
    I installed ADW EX Launcher and search bar at the top was gone.
    The code for the search bar is in two parts.... Part of it to "activate it" is in the Launcher2.apk and the rest of the code is in the framework-res.apk.
    So if you don't want that search bar at the moment just flash a 3rd party launcher. Otherwise I will try and post a modded Launcher to flash a little later this evening. Shouldn't be a problem to remove.
    Can't wait, keep us posted, there are lots of us that want the extra screen real estate!
    Thanks
    In sure beezy would add it into the front post as a mod.
    10-30-2011 09:04 PM
  13. rougegoat's Avatar
    I noticed that whenever there is a popup on screen(such as the volume meter when you use the buttons to change it), you can't access the screen behind it. This probably isn't the desired action(it would be a step back from Gingerbread) and I didn't see it mentioned here, so....yeah. Figured I'd bring it to the thread's attention.
    10-30-2011 09:15 PM
  14. nextro's Avatar
    Can't wait to see some custom kernels working on this , gets a bit laggy at times
    10-30-2011 09:26 PM
  15. karatechess's Avatar
    Is there anyway to add a volume option on the lock screen (i.e. slide the circle to switch between silent and loud)? I know ICS probably won't be like that, so it's probably out of the question, but after having that ability to switch volume for so long, unlocking and changing with the buttons seems drawn out. It could be at the top, camera at left, and unlock at right. I mean, it makes sense to me. I don't know if there's any other interest in this however. >_<
    10-30-2011 09:38 PM
  16. vhgomez36's Avatar
    Good to hear!
    D2dyno likes this.
    10-30-2011 09:40 PM
  17. Batting1000's Avatar
    Google Music 4.0.1 refuses to install, even after deleting the current Music version
    10-30-2011 09:41 PM
  18. Batting1000's Avatar
    Well it installs but just force closes. Funny because it worked on Gingerbread but not this.
    10-30-2011 09:42 PM
  19. MrDrumngun's Avatar
    What's the latest beta?
    10-30-2011 11:07 PM
  20. codemonkey85's Avatar
    I don't suppose anyone could tell me what's going on with my signal bars here? (Click the image for a larger version)
    10-30-2011 11:25 PM
  21. xoms's Avatar
    Does anyone know what exactly is being worked on for the next release? Been using this as my daily driver for about 5 days now and was just curious. Thanks.
    10-30-2011 11:28 PM
  22. intheb0x's Avatar
    Click to view quoted image
    well first off your roaming, and you have wifi on, the up and down errors means data is moving.
    the only time signal bars show up is when you are roaming, ill post how it looks normal with 3g in a second.
    but thats how it is with everyone right now since this is a port.
    10-30-2011 11:41 PM
  23. zeigan's Avatar
    I've been wondering that same thing. I'm sure in the official release there will be an option to add a shortcut of sorts to open an app or toggle volume. If not, someone will figure out how to add one.
    10-30-2011 11:49 PM
  24. zeigan's Avatar
    Bluetooth is at the top of my wishlist, and last I heard, a priority with the masterminds behind this port. 4G is another. NFC may come down the line, as well as anything else missing from the demos (i.e. face unlock).
    10-30-2011 11:52 PM
  25. Anaglich#AC's Avatar
    I am getting anxious for an update.
    10-31-2011 12:09 AM
