11-15-2011 09:48 PM
2,282 ... 6667686970 ...
tools
  1. D2dyno's Avatar
    Not sure about the app folders, haven't tried that. Try and let me know!
    Folders are staying!
    11-03-2011 08:27 PM
  2. Batting1000's Avatar
    There's also an intermittent bug where the wallpaper changes to black, but a quick fix is to hold down on the screen, then exit the dialog that comes up.
    D2dyno likes this.
    11-03-2011 08:28 PM
  3. Batting1000's Avatar
    Great!!
    11-03-2011 08:30 PM
  4. D2dyno's Avatar
    The only problem i noticed was the black screen, also on the home page, it no longer changes orientation. is that because it's the official dump?
    11-03-2011 08:31 PM
  5. Batting1000's Avatar
    Not 100% why that is, to be honest.
    D2dyno likes this.
    11-03-2011 08:32 PM
  6. tylerwatt12's Avatar
    I present to you...Beezy's most recent ROM update with the latest launcher in it, straight from the ICS app dump!!!!! Has the latest app drawer animations, launcher animations (page overscroll on the latest pages of the launcher), working menu button, and slightly changed notification tray!!! In addition, you'll get the little tutorial when first loading the homescreen like on the virtual sdk device!!
    There is one bug which i'm sure will be fixed soon or not, but the google search widget at the top is very slightly cut off.
    Here's the link. Either flash over the current rom or wipe then install.
    http://dl.dropbox.com/u/15668564/ICS...-alpha-3.5.zip
    Enjoy!
    It's freaking awesome. A little slow, but i can understand. This IS the real launcher from the Galaxy Nexus
    11-03-2011 08:32 PM
  7. Batting1000's Avatar
    I'm OCD so the Google search widget being slightly cut off is annoying, otherwise it's great. Glad I was able to do this.
    D2dyno and xoms like this.
    11-03-2011 08:33 PM
  8. Batting1000's Avatar
    Looks like the one in the video below
    Click to view quoted video
    Hmm, seems about the same speed as the recent release, and yeah, it's straight from the dump pretty much!
    11-03-2011 08:34 PM
  9. beezy's Avatar
    For those that want the launcher that is in the rom batting posted if they don't want to flash another rom. Download the attached apk and install with a file manager. I choose not to use this launcher in the rom cause of the issue with the search area and losing 360 rotation.
    Launcher2.apk
    11-03-2011 08:39 PM
  10. Batting1000's Avatar
    Launcher2.apk
    Is the search widget issue fixable though? The images seem to be fine apk-wise. Or is it possible to remove the search widget from the top?
    11-03-2011 08:41 PM
  11. tylerwatt12's Avatar
    Launcher2.apk
    I dont think anyone would complain about that launcher being used in your rom. Afterall the more ICS like the better
    D2dyno and Batting1000 like this.
    11-03-2011 08:41 PM
  12. beezy's Avatar
    Its my own personal choice not to put it in there. I like the way the other one functions. This launcher is from a older system leak,no one has posted a official current dump.
    @batting not sure and as I said in PM theres a couple people with the new nexus so a new dump should be posted anytime and ill be switching the base to that and that whole issue should go away.
    11-03-2011 08:47 PM
  13. Batting1000's Avatar
    Is removing the search widget possible?
    11-03-2011 08:49 PM
  14. Viper05's Avatar
    Launcher2.apk
    when I try to install this in astro it says install failed. I tried switching to a different launcher then installing and still no luck. Am I doing something wrong? I don't want to download the whole rom, already on the latest from Beezy.
    Sent from my Nexus S 4G using Tapatalk
    11-03-2011 08:56 PM
  15. anderson620's Avatar
    Just wanted to stop in and say thanks for all the hard work. Also, and I'm not sure if this has been mentioned, but I know a lot of people have had trouble restoring apps. I couldn't get titanium backup to work but found that mybackup root works perfectly. It will restore apps and data and everything works great. For me, at least. Thanks again!
    11-03-2011 08:57 PM
  16. Batting1000's Avatar
    I think installing the rom would be better, tbh.
    D2dyno likes this.
    11-03-2011 09:00 PM
  17. FL0OD's Avatar
    This is pretty cool. I advise a full wipe I haven't had any crazy issues and this is niiice.
    11-03-2011 09:07 PM
  18. nexusss's Avatar
    Think You!
    谢谢!
    11-03-2011 09:10 PM
  19. Batting1000's Avatar
    is your Google search widget cut off slightly at the top?
    11-03-2011 09:12 PM
  20. alexthearmo's Avatar
    Where is that clock widget? Mine is just the lame old blue glow one. Any help?
    11-03-2011 09:12 PM
  21. Batting1000's Avatar
    Downloaded it from the market
    11-03-2011 09:14 PM
  22. FL0OD's Avatar
    Yea but its usable. Really I am one of those folks that could do without it and would rather have the screen. It could completely disappear and I would alright with that, ha
    11-03-2011 09:19 PM
  23. FL0OD's Avatar
    Also after doing a full wipe I think its a bit snappier. Probably just me.
    11-03-2011 09:21 PM
  24. RMM1981's Avatar
    So when can we expect the dump?
    The more & more I use this, the more i can't wait for actual ICS.
    Patience is virtue but dam this is killing me...lol
    Still have that stupid "data usage warning"...can anyone explain why???
    Mmmmm...ice cream...
    11-03-2011 09:22 PM
  25. NYYFan325's Avatar
    Only issue I've seen so far Batting is that certain widgets say they are 5x1 and won't add to the homescreen stating there is not enough free space. The power control widget comes to mind as the first I tried
    11-03-2011 10:11 PM
