11-15-2011 09:48 PM
2,282 ... 7778798081 ...
tools
  1. snarf77's Avatar
    Any changelog?
    11-07-2011 03:44 AM
  2. dawnadevin's Avatar
    Everything is smaller of course but looks good to me I usually set it too 200 on all the rom's I flash trying to post screen shot
    11-07-2011 03:52 AM
  3. dawnadevin's Avatar
    220 is better bigger icons Google search is still fixed I will post screen shots when I get to my computer browser keeps fc on me
    beezy likes this.
    11-07-2011 04:48 AM
  4. djw39's Avatar
    Here's 220. Looks pretty good! The dock looks out of proportion though. Thanks for the tip
    (This is a line in build.prop we're editing.)
    Sent from my Nexus S 4G using Tapatalk
    beezy likes this.
    11-07-2011 05:52 AM
  5. beezy's Avatar
    Thanks,no biggie on the shots I was just being lazy. Maybe try 230 I'm off to sleep for a little while.
    11-07-2011 06:09 AM
  6. jsnryn's Avatar
    When I answer a call it always answers on speaker phone. I doesn't happen when I place a call, just when I receive a call.
    Is this happening to anyone else?
    11-07-2011 07:22 AM
  7. Batting1000's Avatar
    Need a flashable zip of the launcher. I want to change the LCD density too!!
    11-07-2011 08:03 AM
  8. Batting1000's Avatar
    Post a flashable zip of the launcher if possible
    11-07-2011 08:11 AM
  9. piusvelte's Avatar
    Is it possible that NFC support could be added using the system dumps? I use Google Wallet at least once a week and have been holding off on trying this ICS port due to lack of NFC. Do you need someone to try to look into it or test? I'd be glad to help! Thanks for all of the hard work!
    11-07-2011 08:14 AM
  10. simon.ponder's Avatar
    @Batting1000 - I use Rom Toolbox from the market. The free version can change density. See pictures.
    11-07-2011 08:19 AM
  11. keebler021's Avatar
    Have you tried this with ICS? Just asking because there've been a few apps thus far that don't work :-)
    Sent on Ice Cream Sandwich from the future of Android
    11-07-2011 09:03 AM
  12. simon.ponder's Avatar
    Yes, the screeenshots have been taken with Vol Down and Power. Check the details in the picture and in my user information on my posts.
    Short answer - Yes
    11-07-2011 09:06 AM
  13. kbboykin's Avatar
    @ Batting here's a flashable zip with the Download and Settings apk. Everyone can flash this if they would like to get the updated look. To see exactly what it looks like just back a couple pages Batting posted the screenshots. Thanks.
    If you are the type that doesn't want to flash you can download the apks from Batting's post or download the zip extract the apks. Place both apks in the android sdk foldr that has adb in it. Then at the command line run the following.
    Code:
    adb remount
    adb push DownloadProviderUi.apk /system/app
    adb push Settings.apk /system/app
    Either way works I tested both ways.
    I used Batting's tutorial, but now my Settings icon is gone from the Google Apps container on the home screen. How to get it back?
    Never mind...I figured it out.
    11-07-2011 09:31 AM
  14. keebler021's Avatar
    Short answer - Yes
    -laughs- Sorry. Big derp moment for me there. Awesome though, thanks for the tip on the app!
    11-07-2011 09:38 AM
  15. Mrjandd's Avatar
    Hey Beezy is there anyway you can bump up important/update posts to the top of the fourm? Tired of searching through the posts
    11-07-2011 09:55 AM
  16. Shadow Death's Avatar
    Someone a while back mentioned turning off the GPS location and I've found that monumentally helped. Just sayin' :-)
    Thanks for the info. I just turned it off, I'll run it for a few days and see how she goes.
    11-07-2011 09:57 AM
  17. kbboykin's Avatar
    I seem to only get my battery to charge to 96% with this port. I was getting to 100% in GB before I flashed this. Anyone else having this issue?
    11-07-2011 10:11 AM
  18. quincyb2's Avatar
    my nexus never have got 100% always 96% the only way to get 100% is wifi hotspot and screen on till 100 %
    11-07-2011 10:13 AM
  19. kbboykin's Avatar
    I have the Nexus S 4g, how much different are they fro each other?
    11-07-2011 10:19 AM
  20. heggers's Avatar
    Hey Beezy.. This is my first attempt to root and flash a new ROM on a phone. In my case, I'm on a Sprint Nexus S.. Just want you to know how much I appreciate your efforts and keep up the good work.
    11-07-2011 10:20 AM
  21. quincyb2's Avatar
    not much only other radio, screen and firmware but i think battery is the same my battery is a samsung 3,7v 5,55wh
    11-07-2011 10:22 AM
  22. kbboykin's Avatar
    Yup, that's what Ive got also.
    11-07-2011 10:25 AM
  23. quincyb2's Avatar
    the battery is the same and Google have a sort of protection that you can't damage your battery. so it can't go past 96 % with a standard rom
    11-07-2011 10:30 AM
  24. bnitty's Avatar
    no one knows how to get the "data usage warning" to go away? says "usage exceeds 2.0 GB" & showed up while I was tethering.
    11-07-2011 10:35 AM
  25. Batting1000's Avatar
    I need the launcher though. Deleted it on accident
    11-07-2011 10:39 AM
