11-15-2011 09:48 PM
2,282 ... 7980818283 ...
tools
  1. dawnadevin's Avatar
    hey beezy, thought i'd throw this up there. The boot animation included in 3.6 is awesome but the images are not exactly formatted for our screens. This attached boot animation is formatted for our screens and IMO looks a little better. If you want to try it out for yourself make a backup copy using root explorer of bootanimation.zip in /system/media and replace it with the one i attached. reboot and see if you think it looks better, if you don't you can always replace it with the backup of the original you made. The images are formatted 480x800. Check it out and see what yall think.
    Looks nice thank you
    11-07-2011 06:04 PM
  2. bnitty's Avatar
    like I had mentioned earlier did u do a fresh install & wipe everything? That's what I had to do & I haven't seen it yet...fingers crossed...lol
    Mmmm...ice cream....
    I was trying to avoid that bkuz i don't wanna have to set up all my icons & widgets again, but I may be forced to lol
    Sent from my Nexus S 4G using Tapatalk
    11-07-2011 06:10 PM
  3. Batting1000's Avatar
    hey , would u be kind and share that wallpaper ?
    Here you go.
    http://dl.dropbox.com/u/15668564/PhaseBeam.apk
    Make a backup of the phase beam.apk in the system/app folder with a root file manager, then add in that file above and reboot.
    There are a few visual artifacts, but overall it's ok.
    11-07-2011 06:10 PM
  4. MgWach's Avatar
    Ok. Not sure what I'm doing wrong here but this is LCD density at 215 and it looks different than Battings.
    11-07-2011 06:12 PM
  5. tylerwatt12's Avatar
    Will try it out right now.
    Remember that .zip i posted back around page 70?
    That had the galnex bootanimation in it, lol
    I don't think you guys seriously took that it was the real Galaxy Nexus bootanimation until after the guy over ad MoDaCo dumped it all. Oh well, lol
    11-07-2011 06:13 PM
  6. Batting1000's Avatar
    I knew it was the real one...
    11-07-2011 06:15 PM
  7. Batting1000's Avatar
    You don't have the newest launcher2.apk
    Replace the one you have on there with this one, then set the density to 215:
    http://dl.dropbox.com/u/15668564/Launcher2.apk
    11-07-2011 06:18 PM
  8. djw39's Avatar
    I still think the colors look grainy.
    And I had the question, is this meant to be a pure ICS rom or a Galaxy Nexus port? Because I regard the boot animation as separate from stock AOSP, I wouldn't expect to see that boot animation on any other device (though of course you can do it). Do you think the official ICS build for the Nexus S will have its own boot animation? What does the Nexus One boot with on Gingerbread, does it use the Nexus S animation?
    Batting1000 and vhgomez36 like this.
    11-07-2011 06:25 PM
  9. Batting1000's Avatar
    Yes, it does.
    11-07-2011 06:26 PM
  10. G1toEVO's Avatar
    Here you go.
    Thanks bro . Also i changed my LCD Density to 215 with root explorer I rebooted and its still the same . Do I have to wipe cache and dalvic also ?
    11-07-2011 06:28 PM
  11. Batting1000's Avatar
    1 sec. Let me get you the ROM i'm using, with the new launcher included.
    11-07-2011 06:29 PM
  12. MgWach's Avatar
    Ok, I tried to run adb install launcher2.apk from command prompt and got Failure [INSTALL_PARSE_FAILED_NO_CERTIFICATES]
    Batting1000 likes this.
    11-07-2011 06:31 PM
  13. Batting1000's Avatar
    Uploading...will edit file in when complete.
    11-07-2011 06:31 PM
  14. MgWach's Avatar
    Ok thanks. That'll help me too.
    11-07-2011 06:33 PM
  15. G1toEVO's Avatar
    okay GREAT !
    11-07-2011 06:37 PM
  16. Batting1000's Avatar
    Fresh out of the oven...
    http://dl.dropbox.com/u/15668564/ICS...-alpha-3.6.zip
    Flash the above file, no need to wipe unless you really want to. Then download the free version of ROM Toolbox, go to the Performance tab > build.prop tweaks > change LCD Density to 210 (my mistake earlier, I said 215). Reboot.
    EDIT: Actually 215 and 210 are pretty similar, I don't notice any differences.
    11-07-2011 06:43 PM
  17. MgWach's Avatar
    Thank yas!
    11-07-2011 06:46 PM
  18. Batting1000's Avatar
    Thank yas!
    Np. That launcher is pretty the same as what you'll see on the GNex. App drawer animations, homescreen page overscroll animations, modified search widget at the top, etc. It's pretty much a replica once the density is set at 215/210. May look a tad small, but that's how the GNex looks.
    11-07-2011 06:49 PM
  19. MgWach's Avatar
    Nice! Not sure how I missed it before. O_o
    11-07-2011 06:52 PM
  20. Batting1000's Avatar
    Yeah, let me know how it goes.
    EDIT: Oh yeah, menu buttons works on homescreen too.
    11-07-2011 06:52 PM
  21. dawnadevin's Avatar
    Has anyone heard official release of 4.0 on the nexus s 4g sorry to go off topic
    11-07-2011 06:58 PM
  22. Batting1000's Avatar
    If you're asking for a specific release date, then no, no one knows, but Google said a few weeks. It has been confirmed that the Nexus S/4G will be receiving the update though.
    11-07-2011 06:59 PM
  23. Rem3Dy's Avatar
    I would recommend you ask Santa Clause.
    dawnadevin likes this.
    11-07-2011 07:07 PM
  24. MgWach's Avatar
    WOOOT!!! Much better! Thanks!!!
    11-07-2011 07:09 PM
  25. Batting1000's Avatar
    That's what I said when I tried it because of my OCD.
    No problemo!
    11-07-2011 07:12 PM
