11-15-2011 09:48 PM
2,282 ... 8182838485 ...
tools
  1. ZeeraF#AC's Avatar
    hey batting , im using the 3.6 version you posted and i tried your fix for the disappearing wall paper and it still does the same thing. may go back to beezy 3.6 cause i like the 4x1 contact widget but with your launcher its 5x2
    11-08-2011 09:04 AM
  2. RMM1981's Avatar
    yea it didn't work for me either...
    Mmmm...ice cream....
    11-08-2011 09:05 AM
  3. kbboykin's Avatar
    dont know which widget he is using but ive been using fancy widget 3.2 for the longest and even with this rom i havent had any problems ..... have you tried fixing permissions in recovery ????
    Thanks, but went back to original launcher with 3.6 and now rocking BeWeather. I'm new at flashing, so I don't know how to fix the permissions in recovery. It is still fc'ing back on the original launcher, so if you can tell me how to fix the permissions (sorry, need a step by step), I wanna get that fixed.
    pauldroidr2d2 likes this.
    11-08-2011 09:29 AM
  4. ZeeraF#AC's Avatar
    from rom manager boot into recovery , then select Advanced from the list and scroll down to fix permissions , when its done just go back and then hit reboot .... im not 100% sure this will work but its work a shot , like i said ive been using fancing widgets for a while and i go back and forth from cm7 rom and this one ..... also and this is another option , when you flashed this rom did you do a clean wipe ??? you can google "format all zip for nexus s 4g" and the first link is to an xda forum , and use that zip ... ive been an xda member long before i joined android central so i know you can find it there but im sure its some where here in this forum as well
    11-08-2011 09:35 AM
  5. m3grady2's Avatar
    If you're updated to the latest version of fancy Widgets and remove the widget and try adding it back to the home screen, it just force closes.
    11-08-2011 09:49 AM
  6. ZeeraF#AC's Avatar
    i found a unlocked version for fancy widgets 3.2 and that one hasnt given me any problems , when it ask to update i never do it
    11-08-2011 09:52 AM
  7. RMM1981's Avatar
    Ever since I flashed Batting's "fresh out the oven" thinga ma jig, I keep getting force closing on alot of stuff now. My Gtalk, Gmail, Market...just not as stable as beezy's was. I'm going back to Beezy's...
    11-08-2011 10:14 AM
  8. ZeeraF#AC's Avatar
    ive been using batting's version as well .... havent had any issues what so ever. make sure you do a clean wipe before installing and try fixing permissions too ... you never know
    11-08-2011 10:15 AM
  9. ZeeraF#AC's Avatar
    so ive been having the weirdest issue ..... i use fancy widget to show the battery % and ive noticed that while charging my battery % goes down !!! im like wtf
    11-08-2011 10:34 AM
  10. RMM1981's Avatar
    You're probably right but I hate have to start over every other day just for an update to a port. Don't get me wrong I'm loving it, its just I need my phone to act how i need it when I need it. I will keep an eye out here though. It was fun while I used it but for now I'm going back to stock. Maybe I'll get lucky and an OTA will pop up. Lol
    Sent from my Nexus S 4G using Tapatalk
    11-08-2011 11:17 AM
  11. kbboykin's Avatar
    I restored FW from a back up to the, I think, previous version and it still FC's. I'll just stick to original Launcher and BeWeather.
    11-08-2011 11:55 AM
  12. Vinnypel2ella's Avatar
    Looks pretty much the same, imo. I'll keep it though. Thanks.
    Yea I mean the one included in 3.6 isn't that far off but you can tell the difference. its still gonna look kinda grainy because I didn't actually go through the hundreds of images and format them to 480x800, I just changed the value inside desc.txt inside the zip to 480x800 so when it boots it displays at that resolution.
    Edit: just checked the resolution of the included bootanimation.zip in 3.6 and its formatted 720x1280 so yea there is a little difference. But like you said its not all too noticeable, gotta have an eye for it.
    11-08-2011 01:12 PM
  13. Batting1000's Avatar
    Sorry. It's not either of our launchers so it can't be fixed as far as I know. Beezy has a new launcher from the modaco do coming soon which should be more for the nexus s 4g. Please hang tight.
    11-08-2011 01:59 PM
  14. Batting1000's Avatar
    I'm not having any issues. I only changed the launcher, nothing else. I did not code anything or change files, etc. I merely replaced the included launcher.
    11-08-2011 02:02 PM
  15. RMM1981's Avatar
    idk but I went ahead and did a fresh install...so far no issues I can notice yet besides the wallpaper issue. But u said it's being looked at so I can deal with that for now.
    Yea I know I said I was gona go back to stock but I just couldn't do it...lol
    Who wants to go back when you've had a taste of the future???
    mmmm...ice cream...
    11-08-2011 02:08 PM
  16. intheb0x's Avatar
    Not my launcher btw got it from p3droids gnex app dump from a month or two ago.
    Lol well yours in sort that u included it for us,
    That way everyone knows what I'm talking about.
    Btw im using fancy widgets 3.4.4.
    Since 3.6 really didn't change much besides boot animation and so on I been waiting on 3.7 for the big update.
    Sent from my Nexus S 4G with Ice Cream Sandwich
    11-08-2011 02:15 PM
  17. sobis1dm's Avatar
    Streaming works for me. One thing that was discovered is that GMusic limits you to 8 devices, and each time you flash a new rom it registers your phone as a new device. So if you go to music.google.com and click the settings icon on the upper right, if you see you are maxed out on devices, just clear a bunch of them. Hope this helps.
    Bloody hell, you are the man. I knew about the 8-device limit and the flash limit too, but every time the issue came up in GB, Music gave me a prompt saying that my account had reached the limit... So I cleared out my devices and I was good to go. It seems like ICS gives no such warning.
    Thanks for the help, I'm a dumbass.
    11-08-2011 02:21 PM
  18. Batting1000's Avatar
    Is hotspot free in this ROM?
    11-08-2011 02:33 PM
  19. sobis1dm's Avatar
    Seems to be.
    11-08-2011 02:46 PM
  20. RMM1981's Avatar
    Figured out why my market & Gmail kept force closing...
    I had updated them to newer versions instead of leaving them how they were. So i uninstalled updates & seems fine now. Has anyone else updated to newer versions then what it came with? & have u had any problems?
    mmmm...ice cream...
    11-08-2011 03:35 PM
  21. bnitty's Avatar
    I had that problem with gmail even tho it never showed in the market that I needed an update, but the "data usages" error annoyed me so much I restored my Miui nandroid until another release drops or the official one
    Sent from my Google Nexus S 4G using Tapatalk
    11-08-2011 04:41 PM
  22. Batting1000's Avatar
    mmmm...ice cream...
    Did this on an older rom version with the market and the newest update to Google Reader crashes when opening an article. Had to download an older version
    11-08-2011 04:59 PM
  23. RMM1981's Avatar
    When can we expect an ota??? I'm sorry but I'm so ready for what will come afterwards...
    Custom ICS roms...
    Themes...
    Kernals...
    Patience is virtue but man this sux...lol
    mmmm...ice cream...
    Batting1000 likes this.
    11-08-2011 07:10 PM
  24. Batting1000's Avatar
    Custom ICS roms...
    Themes...
    Kernals...
    mmmm...ice cream...
    OTA meaning official update to ICS or the next version of this ROM?
    11-08-2011 07:28 PM
  25. RMM1981's Avatar
    Both??? Lol
    mmmm...ice cream...
    11-08-2011 07:40 PM
