jin5
Active member
the ics build with the new launcher seems to be pretty smooth over all.i'm not sure if it has hardware acceleration or not but even without it, its really good. thanks beezy and everyone else involved.
Only issue I've seen so far Batting is that certain widgets say they are 5x1 and won't add to the homescreen stating there is not enough free space. The power control widget comes to mind as the first I tried
Well that sucks.... anything we can do to workaround?
I think apps closed in the multitasking switcher stay closed for good, it seems.
Can anyone else confirm this?
I can say that after I throw away apps and open another app or simply relaunch the multitasker I see some if not all the older apps again. I think once or twice have they stayed dead for good.
Same here. I was hopeful that this update would make the multitasking act as a killer as well, but that does not seem to be the case.
Sent from my Nexus S 4G
For those that want the launcher that is in the rom batting posted if they don't want to flash another rom. Download the attached apk and install with a file manager. I choose not to use this launcher in the rom cause of the issue with the search area and losing 360 rotation.
Launcher2.apk
Dumb question, but here goes. Can this be uninstalled if it "breaks" my currently smooth running original 3.5 update? Thanks
Has anyone gotten any calendar app from the market to work? I have tried Business Calendar and Calendar Pad and neither can see my calendar. I seem to only be able to use the embedded calendar app. Anyone?
