11-15-2011 09:48 PM
2,282 ... 8586878889 ...
tools
  1. MgWach's Avatar
    MgWach,
    Try adb install -r market-3.3.11.apk
    Ok. Tried that and get [INSTALL_PARSE_FAILED_INCONSISTENT_CERTIFICATES] :/
    11-11-2011 07:05 PM
  2. piusvelte's Avatar
    MgWach,
    In that case, I think you need to uninstall the existing market app first.
    I think you'll want to run...
    adb uninstall com.android.vending
    ...first and then try to install the new version. I'm trying to verify this.
    Bryan
    11-11-2011 07:40 PM
  3. MgWach's Avatar
    MgWach,
    Bryan
    Hrmm.... failure on that.
    11-11-2011 07:56 PM
  4. bnitty's Avatar
    happened to me while using usb tether with pda net. reflashing the system image took care of it.
    how do I flash that?
    Sent from my Google Nexus S 4G using Tapatalk
    11-11-2011 09:01 PM
  5. Kuffoman's Avatar
    Anyone experience force closes on the music app?
    11-11-2011 09:07 PM
  6. beezy's Avatar
    Hey guys. Ok, so I have the market-3.3.11.apk file and I've tried adb install market-3.3.11.apk and get [INSTALL_FAILED_ALREADY_EXISTS]. But the version of market on my phone is 3.1.2. How so I get around this?
    Make sure the market apk your trying to push is this exactly Vending.apk. Then place the Vending.apk in the same folder that the adb file of android sdk is in. From command line run the following.
    Code:
    adb remount
    adb push Vending.apk /system/app
    adb reboot
    11-11-2011 10:34 PM
  7. MgWach's Avatar
    Code:
    adb remount
    adb reboot
    Thanks for the info. I finally got it to work after setting the system folder as r/w which I didn't know I had to do. Thanks!
    OJMBrooklyn likes this.
    11-11-2011 10:51 PM
  8. Kuffoman's Avatar
    Wat page can I find battings (sorry if misspelled) launcher at?
    11-12-2011 02:44 AM
  9. bnitty's Avatar
    around 170ish but don't quote me lol
    Sent from my Nexus S 4G using Tapatalk
    Kuffoman likes this.
    11-12-2011 02:47 AM
  10. Kuffoman's Avatar
    thanks man, I'll scavenge lol
    11-12-2011 02:50 AM
  11. kbboykin's Avatar
    This, again, may be a dumb question - but here goes. If I temporarily deactivate this phone, will I have to flash back to GB to reactivate it? I have to use my photon for business reasons for the next 1-2 days. Thanks.
    11-12-2011 06:30 AM
  12. Batting1000's Avatar
    I can post it when I get back later if you can't find it (the launcher)
    11-12-2011 06:41 AM
  13. Batting1000's Avatar
    You're removing service from it, not removing a ROM. The phone can't change OS versions on its own.
    kbboykin likes this.
    11-12-2011 06:44 AM
  14. thegtfusion's Avatar
    hi beezy, i have a question. are u planning to bring this to the nexus s 3G?
    i know about drewgarens work, but with all the betas from him wifi doesnt work for me.
    11-12-2011 09:21 AM
  15. lightyear420's Avatar
    You have to have a previous ICS nandroid backup
    Boot CWM>backup & restore>advanced restore>xx_your backup img_xx>restore system....this won't wipe your data partition but it will reformat your system and install only the system partition from that backup....any current text messages, system apps, etc. will be lost!! Basically, you will have a frankenstein rom with an old system partition and your current data partition.
    11-12-2011 09:59 AM
  16. Batting1000's Avatar
    Did you try wiping when installing his roms?
    11-12-2011 10:06 AM
  17. thegtfusion's Avatar
    yes. full wipe, wiped cache, wiped dalvik cache..
    i reported it many times on the xda thread. but no result.. hopefully if beezy releases his version for ns3g it will work for me..(i really hope that he'll do it)
    11-12-2011 10:24 AM
  18. Batting1000's Avatar
    I don't think its part of his game plan but I'm not 100% sure.
    11-12-2011 10:32 AM
  19. thegtfusion's Avatar
    this is what he said in the first post(under the screenies)
    If you don't have a NS4G very good idea not to flash.
    Once i get the edits made for other nexus version ill post them.
    cant wait :P
    11-12-2011 10:37 AM
  20. cadams14#AC's Avatar
    Thanks for releasing the ICS 3. for Nexus S 4G. Works good for Alpha. However I would use it on a daily driver if the bt was working. Seems to be a kernel issue, however I am not sure. If someone could direct me to a fix for this, if there is one, would appreciate it?
    Also noticed some issue with Google Latitude menu key button? Dont have 4G in this area but other than I really like the latest build and its on in Alpha stage. Thanks for your hard work on this build.
    11-12-2011 11:36 AM
  21. anon(5021)'s Avatar
    No, you can activate it while running ICS. The same activation steps should apply. I switched from the nexus when I had ICS and then back to it from my EVO....
    As long as you don't activate the nexus on another line, you should just have to call back and tell them to switch back (call from a 3rd phone... not the nexus or photon)
    since it's already been activated on your account you won't have to reprogram it.
    remember: any hash codes they give you for the dialer ##786# for example will need to be changed to the following.... *#*#786#*#* so in case they tell you to punch in ##1234# (example) keep that in mind
    11-12-2011 12:04 PM
  22. beezy's Avatar
    Launcher-replacement-2.zip
    That should be the flashable zip I made to flash the launcher.
    Yes,I hope to have a update soon for the NS4G at that time I also plan to try and have a tester up for the 3g model
    There's no fix as of yet. 4G I'm pretty sure won't ever work till official source.
    11-12-2011 01:37 PM
  23. thegtfusion's Avatar
    thanks .. if you need a ns3G tester, im ur man just pm me if the 3g version is out, and ill test it
    11-12-2011 01:51 PM
  24. Kuffoman's Avatar
    Thanks man! Mine seems to act up and I like this Tom too much to go back haha
    11-12-2011 01:58 PM
  25. adamw1101's Avatar
    For the folders, Batting's launcher fixed that.
    Where is the link for his launcher?
    11-12-2011 03:50 PM
