11-15-2011 09:48 PM
2,282 ... 8687888990 ...
tools
  1. beezy's Avatar
    Where is the link for his launcher?
    Sent from my Nexus S 4G using Tapatalk
    Go up about three post there's a flashable zip
    11-12-2011 04:01 PM
  2. Batting1000's Avatar
    That didn't work for me. Told me Installation aborted.
    11-12-2011 04:44 PM
  3. beezy's Avatar
    Try toggle signature verfication. I didn't sign the zip but it flashes for me.
    11-12-2011 04:58 PM
  4. m3grady2's Avatar
    I had to reflash this rom again, the force was too strong. I was tired with how laggy the launcher was becoming and the force closes so i went to stock for a couple days and almost went insane. Thanks again beezy for all your hard work.
    beezy and Batting1000 like this.
    11-12-2011 08:44 PM
  5. Batting1000's Avatar
    Two reasons why I can't change ROMs:
    1) the google search widget stuck on the homescreen
    2) the widgets, like bookmarks, analog clock, etc.
    No other 3rd party widgets or launcher matches them.
    EDIT: Forgot the speech to text too, gets entered as you speak.
    11-12-2011 10:01 PM
  6. NYYFan325's Avatar
    What was the changes from 3.5 to 3.6?? I can't seem to find the post that had it. Did it have any performance improvements?
    11-12-2011 11:32 PM
  7. MgWach's Avatar
    Anyone else getting a ton of force closes with the new market and/or browser?
    11-12-2011 11:49 PM
  8. intheb0x's Avatar
    from what i understand, No.
    just the new boot animation and something else.
    same 3.5.
    ive noticed that after using 3.5 since it was released it gets laggy and buggy as time goes on.
    getting force closes, and lots of bug mailers.
    still trying to hold out for the update, i guess im getting tired of the small things with it.
    but i never wanna leave ICS to go back to gingerbread lol.
    11-12-2011 11:58 PM
  9. RyanK63's Avatar
    I had that problem with the market non stop. I couldn't even update my apps without it FCing. Switched back to CM7 until this becomes a little more stable.
    11-13-2011 12:16 AM
  10. beezy's Avatar
    If your using a different market then the one included in the Rom that would be the problem. I didn't add any updated apps for that reason part of the trade of of having ICS is you might have to use older apps.
    same 3.5.
    I would check out what you got going on with your apps. Try reboot when you have to charge that should help too. I don't really seem to run into that issue so it's probably cause I reboot or just don't use the apps you use.
    11-13-2011 02:27 AM
  11. dxta0's Avatar
    Just to let people know I was having problems with my WiFi not working but I was able to fix it by going to WiFi settings advance and unchecking WiFi connectivity checks.
    11-13-2011 04:08 AM
  12. m3grady2's Avatar
    Yeah the market updates to the newest version on its own for me and constantly force closes
    11-13-2011 11:34 AM
  13. Batting1000's Avatar
    I can download apps and such but clicking on screenshots and attempting to access categories fc's it.
    11-13-2011 11:54 AM
  14. beezy's Avatar
    This should be a pretty easy way to fix. Using a root explorer go to data/app delete com.vending-1.apk
    then in system/app rename MarketUpdater.apk to MarketUpdater.apk.bak then reboot. You should now be back at the older market and it shouldn't be able to update in the background now,
    11-13-2011 12:57 PM
  15. Batting1000's Avatar
    Beezy, got a launcher apk that works just like the one from the dump, but the only thing that crashes is the widget screen. It's very smooth and snappy too.
    App drawer works fine, doesn't crash, only the widget screen. I remember the GNex launcher crashed in both the app drawer and wdget screen, might help you out a little. Google search widget isn't cut off either.Only other issue is the wallpaper changes to black sometimes and you gotta bring up the change wallpaper dialog to have to change back to your wp.
    Lmk if you need it.
    11-13-2011 01:34 PM
  16. beezy's Avatar
    Lmk if you need it.
    Sure I'll have a look. Don't think they'll be much to do with it as the tools we need are still outdated. I don't think there's to much we can do about the launcher till we have source/official update. I've pretty much decided that I'm going to stick with the launcher that I've always packaged in with the rom and adding links to flashable zips that will add the other launcher if people prefer that one more.
    nickflores555 likes this.
    11-13-2011 01:40 PM
  17. Batting1000's Avatar
    Here you go Beezy. http://dl.dropbox.com/u/15668564/Lau...%20%281%29.apk
    For everyone else, this isn't something you should use unless you don't use widgets as the widget screen just crashes.
    Btw Beezy, can you change the white strip above the dock in the current rom version to the below image? It looks way better and replicates ICS more.
    http://dl.dropbox.com/u/15668564/hot...ack_holo.9.png
    If you get the strip changed, shoot me a PM and i'll check it out. In the current ROM, it's one of the hotseat images in the launcher2.apk
    beezy likes this.
    11-13-2011 01:48 PM
  18. beezy's Avatar
    Can you zip that png and just attach to your post my laptop doesn't want to allow me to download the .png.
    11-13-2011 01:53 PM
  19. Batting1000's Avatar
    11-13-2011 02:02 PM
  20. adamw1101's Avatar
    having a problem with power widget. Its set at 5x2 and won't allow me to place it on my screen. Any solution. Using battings launcher
    11-13-2011 02:57 PM
  21. Batting1000's Avatar
    Sorry, it has to be that way. It's a port of the Galaxy Nexus launcher so the widgets are made for it's screen, not the Nexus S. It can't be changed.
    11-13-2011 03:08 PM
  22. piusvelte's Avatar
    Has anyone tried to get the FaceLock.apk working? I pushed it to /system/app and rebooted, but the option isn't available under Settings. Has anyone tried installing the Settings.apk from the GNex system dump, or is that already part of the 3.6 port? Thanks!
    11-13-2011 03:30 PM
  23. Batting1000's Avatar
    FaceLock won't work yet. It needs a bunch of other files other than just the apk.
    Here's a version of the Settings app where I just cleaned up all the icons and such. No new options in it, but all the icons were fixed.
    http://dl.dropbox.com/u/15668564/Settings.apk
    piusvelte likes this.
    11-13-2011 03:33 PM
  24. Batting1000's Avatar
    I hope he is right!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    http://www.androidcentral.com/ice-cr...notion-ink-ceo
    11-13-2011 03:41 PM
  25. kbboykin's Avatar
    Me too. I pretty know, I'll go with the GNexus whenever Sprint gets it, since I am eligible now for an upgrade. It's difficult to go back to GB on my photon.
    11-13-2011 03:49 PM
