Limited time deal: Save 20% on select Samsung tablets today
- Forum
- Google Hardware, Services & Apps
- More Google Devices & Services
- Google / Samsung Nexus S Forums
- Sprint Nexus S 4G
- Sprint Nexus S 4G Rooting, ROMs, and Hacks
[ROM] ICS SDK Port [WIP]
- You're right. I tried flashing an earlier beta of his and it worked, but it didn't get service since it was for the 3G Nexus. Not sure if it would be the same for the source build.11-14-2011 09:13 PMLike 0
- Batting if you want to try....
Flash one of his ICS 3G roms... and then flash the latest radio. You can get it on ROM manager under Peter Alfonso. I don't know if you Wifi works on a NS3G ROM while using our phone but maybe download the radio before flashing.
That should give you an idea if that would work or not11-14-2011 09:16 PMLike 0 - Batting if you want to try....
That should give you an idea if that would work or not11-14-2011 09:24 PMLike 0 - I understand, but it's my only phone and I'd rather just wait for a proper build. Shouldn't be too much longer before a source build for the 4G pops up.11-14-2011 09:30 PMLike 0
Beezy was the original developer of the ROM and has spent countless hours both supporting and releasing updates for the benefit of the community.
What many of you may or may not know is that Drew has repeatedly downloaded and re-uploaded this ROM and then claims he is the one responsible for these updates. After comparing "his" ROM with Beezy's we found one or more of the following after each of his "releases:"
- Line breaks in the build prop.
- Changes to the settings file.
- Launcher files from older builds of ICS that were copied, pasted, and overwritten to the more current release of ICS that Beezy built.
If anyone wants to do any of these things all you have to do is unzip the ROM, copy these files over, zip it back up and then flash.
I've asked Drew several times to provide us with a list of code changes he has made and he has ignored each request. You will notice he does not take nor answer questions in any forum.
To top this off Beezy received an email and a PM from a member stating that he had donated $50 to Drew and that if he could get Bluetooth working he would send him $50 as well.
So after seeing Drew improperly credited at Droid-Life, being given donations, and now seeing this turn into a support/fan thread for Drew, this thread is no longer necessary. If you can find a forum that Drew will respond in; please ask your questions there.
I'm still open to seeing Drew's list of Code changes if he wants to send them to me.11-15-2011 10:48 PMLike 26
- Forum
- Sprint Nexus S 4G
Tags for this Thread
