Charles Dolly
OMFG!!!!!!
Yeah, I doubt adobe has released a version for 4.0 yet.no, flash does not work
Hmmm. So I copied some music onto my phone, folders with MP3's, and some of them aren't recognized by the music program. Any ideas? It's simply not seeing them while Astro shows them.
Go to Settings-Developer Options- HDCP settings click it to never check. Should do the trick.
Sent from my neXus S 4g
Nevermind, think I found the problem.
Will this work on SGS i9000?
"If you don't have a NS4G very good idea not to flash." If you try to flash it prepare to waste a couple hours getting your phone back.Will this work on SGS i9000?
Short answer? Probably not. This is designed for the NS4G, though there is also a concurrent version for the NS that is being discussed. Unless you have one of those phones, this particular version probably will not work for you. Check the forums for the SGS i9000 to see if someone has adjusted it appropriately over there, or search in here to see if it's been mentioned(going from memory, I don't think it has been).
How do you have the new messaging, people and phone icons?http://i.imgur.com/MX7x3.png
ADW Launcher EX seems to be way smoother than stock launcher.
Also, that thing at the top, was it there in Gingerbread? Or is it something new?
Yeah, it doesn't look like they had any luck getting it to Boot.Thank you for your qiuck reply.. I find this thread on XDA ICS Android 4.0.1 SDK I9000 Port - Page 5 - xda-developers is that the same ROM like the one here?
Yes! Batting1000 was able to put it in the ROM just flash this on top of the one you already have.How do you have the new messaging, people and phone icons?
Did I miss out on a new version of the rom? o.o
Well flash is on the Galaxy Nexus No? We really need that dump that someone had mentioned earlier...
That would be great.... You get ICS and you get ICS everyone gets ICS!yes , they have some problem with boot image but hopefully they will solve it
