2: out play (or thinks it plays) video files.
Sent from my Nexus S 4G
Thanks for the quick response. I'll check it out. : )
Sent from my Nexus S 4G using Tapatalk
Just a little curious. I tried extracting some apks from the rom to see if it works on other roms and tried to install them but it says problem parsing or something like that. Im guessing it's same for all roms, why is that?
Sent from my Google Nexus S 4G
Hey, just wondering what's up with hero_over? I tried pming him but didn't realize I needed 5 posts. I'm really interested in seeing what he's been doing with this beautiful rom.
Wanted to point out a few things I noticed in anything that has a gray scroll bar on the left side of a screen when scrolling.
The scrool bar seems to be a little far away from the right side of the screen. Usually, the bar is touching the right side of the screen, but it doesn't seem to be in the ROMs menus.
Example:
Click to view quoted image
Another thing is that the Manage Apps screen doesn't seem to be sized right for the screen. (I also pointed out the scroll bar is this image too.)
As you can see, the categories at the top are a little small and bunch, and the UI itself doesn't extend to the screen sides.
Just wanted to point these things out see we're aware, that's all.
EDIT:
Here's a picture of Manage Apps from the emulator. Fills up the screen more
hey I noticed you have a voicemail icon in your status bar is that to a stock visual voicemail. I only ask because I use google voice for my voicemail and if ice cream sandwich now comes with the visual voicemail app I would like to use it
Is there a way to get the bluetooth working on this port
Example:
EDIT:
Like?
Wishing we had the option to remove that search bar, id love the extra real estate.
Sent from my Nexus S 4G with Ice Cream Sandwich
Like?
