vhgomez36
Awesome. Thank you.
Sent from my Nexus S 4G using Tapatalk
Don't forget to remove the backup file that is created and save it somewhere else. Then set permission if it is not set already.
Awesome. Thank you.
What do you mean by set the permission?
When you edit the file...you the to change permission to rw-r--r-- if its not already there. You need to change them in order for the changes to take affect.
Do need root explorer or something for that?
Set permission to what?
It's quicker plus you can do it anywhere.
It didn't change it, and my phone is stuck on bootscreen.
yeah. what happened?
Changed the version to 4.0. What should I make the "display" one?
Now my home button doesn't work. Restoring to a backup, then i'll try again.
Try fixing permission from recovery first. My home button works fine.
All is good now.
Looks better than "IceCreamSandwich"
Cool. Matter of opinion. I'm sure alot of people like IceCreamSandwich.
GOOD. You just need to change the 4rth and 8th line.
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IRK40C
ro.build.display.id=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys
ro.build.version.incremental=162682
ro.build.version.sdk=13
ro.build.version.codename=IceCreamSandwich
ro.build.version.release=IceCreamSandwich
ro.build.date=Tue Aug 9 16:52:52 PDT 2011
ro.build.date.utc=1312933972
ro.build.type=userdebug
ro.build.user=android-build
ro.build.host=android-test-34.mtv.corp.google.com
ro.build.tags=test-keys
ro.product.model=Nexus S 4G
ro.product.brand=google
ro.product.name=sojus
ro.product.device=crespo4g
ro.product.board=herring
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=s5pc110
# ro.build.product is obsolete; use ro.product.device
ro.build.product=crespo4g
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys
ro.build.fingerprint=google/sojus/crespo4g:IceCreamSandwich/IRK40C/162682:userdebug/test-keys
ro.build.characteristics=nosdcard
# end build properties
# system.prop for smdkc110
rild.libpath=/vendor/lib/libsec-ril.so
rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=240
ril.ecclist=911,#911,*911
# ADDITIONAL_BUILD_PROPERTIES
ro.cdma.home.operator.numeric=310120
ro.cdma.home.operator.alpha=Sprint
ro.telephony.default_network=4
ro.wimax.interface=uwbr0
ro.opengles.version=131072
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=48m
dalvik.vm.heapsize=128m
ro.config.ringtone=Sceptrum.ogg
ro.config.notification_sound=Castor.ogg
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=false
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.clientidbase=android-google
ro.config.alarm_alert=Alarm_Classic.ogg
ro.com.android.wifi-watchlist=GoogleGuest
ro.error.receiver.system.apps=com.google.android.f eedback
ro.setupwizard.enterprise_mode=1
keyguard.no_require_sim=true
drm.service.enabled=true
dalvik.vm.lockprof.threshold=500
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
EXAMPLE:
Ro Build. Display ID= TO WHATEVER (4th line)
Ro.Build Version.Release= TO WHATEVER (8th line)
Then exit and save
Then set permission rw-r--r--
Then reboot
