NYYFan325
What was the changes from 3.5 to 3.6?? I can't seem to find the post that had it. Did it have any performance improvements?
Anyone else getting a ton of force closes with the new market and/or browser?
I had that problem with the market non stop. I couldn't even update my apps without it FCing. Switched back to CM7 until this becomes a little more stable.
from what i understand, No.
just the new boot animation and something else.
same 3.5.
ive noticed that after using 3.5 since it was released it gets laggy and buggy as time goes on.
getting force closes, and lots of bug mailers.
still trying to hold out for the update, i guess im getting tired of the small things with it.
but i never wanna leave ICS to go back to gingerbread lol.
Yeah the market updates to the newest version on its own for me and constantly force closes
I can download apps and such but clicking on screenshots and attempting to access categories fc's it.
This should be a pretty easy way to fix. Using a root explorer go to data/app delete com.vending-1.apk
then in system/app rename MarketUpdater.apk to MarketUpdater.apk.bak then reboot. You should now be back at the older market and it shouldn't be able to update in the background now,
Beezy, got a launcher apk that works just like the one from the dump, but the only thing that crashes is the widget screen. It's very smooth and snappy too.
App drawer works fine, doesn't crash, only the widget screen. I remember the GNex launcher crashed in both the app drawer and wdget screen, might help you out a little. Google search widget isn't cut off either.
Lmk if you need it.
Here you go Beezy. http://dl.dropbox.com/u/15668564/Launcher2 (1).apk
For everyone else, this isn't something you should use unless you don't use widgets as the widget screen just crashes.
Btw Beezy, can you change the white strip above the dock in the current rom version to the below image? It looks way better and replicates ICS more.
http://dl.dropbox.com/u/15668564/hotseat_track_holo.9.png
If you get the strip changed, shoot me a PM and i'll check it out. In the current ROM, it's one of the hotseat images in the launcher2.apk
having a problem with power widget. Its set at 5x2 and won't allow me to place it on my screen. Any solution. Using battings launcher
Sent from my Nexus S 4G using Tapatalk
Has anyone tried to get the FaceLock.apk working? I pushed it to /system/app and rebooted, but the option isn't available under Settings. Has anyone tried installing the Settings.apk from the GNex system dump, or is that already part of the 3.6 port? Thanks!
I hope he is right!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.androidcentral.com/ice-cream-sandwich-source-code-coming-nov-17-says-notion-ink-ceo
