Batting1000
Whoa whoa, so we might have a rom by tonight or tomorrow on the ns4g!? :-D
Highly doubt by tonight or tomorrow. It's more than just downloading a file and flashing it, if I had to take a guess.
Radios and stuff should be usable from what we already have... SHOULD.... Don't quote me there..Is that stuff hard to obtain? Just trying to get an idea of how this will all pan out, pretty excited.
See above...Could we flash the radios from the 2.3.7 update? Any kind of backwards compatibility like that?
Sent from my HP Touchpad using Tapatalk
Sure, no problem... Its in the OP right now...Whoa whoa, so we might have a rom by tonight or tomorrow on the ns4g!? :-D
Yep as Beezy said go right ahead and dive in... Even with official source this is still going to be quite a bit of work... Galaxy Nexus and its older relatives Nexus S/NS4G are close but there are enough differences to make it challenging...
Man that was fast!
"drewgaren Drew
Yay for ICS...AOSP build should be coming shortly with some mods."
Would it be possible to add the sprint radios into his build then flash it?
would also like to know, seems odd that NS users can flash NS4G roms with some success.
(correct me if i'm wrong.)
Also
Drew is most likely building off his nice Mac which may or may not have 4-8 cores
In, other words. He's almost done building from source
Batting if you want to try....
Flash one of his ICS 3G roms... and then flash the latest radio. You can get it on ROM manager under Peter Alfonso. I don't know if you Wifi works on a NS3G ROM while using our phone but maybe download the radio before flashing.
That should give you an idea if that would work or not
I can't imagine anything terrible would happen. You already stated you flashed a 3G ROM before. As long as you have a backup I don't for-see a unrecoverable issue...
