12-02-2011 01:43 PM
32 12
tools
  1. digitalslacker's Avatar
    not taking any credit here
    just re-posting for folks looking to use a port of Koush's ICS rom for the GSM version.
    [ICS] [AOSP] [Nexus S 4G] Koush's Build for CDMA Nexus S 4G - xda-developers
    charn65 likes this.
    11-23-2011 08:19 AM
  2. simon.ponder's Avatar
    I jumped over to this version also, as the camcorder works, and Koush's work, IMHO will move along with better support.
    11-23-2011 11:22 AM
  3. digitalslacker's Avatar
    yup Koush seems to be moving a little faster with updates on his but everyone is also collaborating on fixes so it'll only get better.
    I've been running this since this morning and haven't had any real issues.
    11-23-2011 12:29 PM
  4. |-KGB-|CaptHowdy's Avatar
    how does one tether using ICS? Thanks
    11-23-2011 12:36 PM
  5. digitalslacker's Avatar
    Settings > More... (under Wireless & Networking) > Tethering & Portable Hotspot
    I haven't tried it but that's where you can enable it.
    11-23-2011 02:02 PM
  6. |-KGB-|CaptHowdy's Avatar
    i dont know how i missed it. thanks lol
    11-23-2011 02:34 PM
  7. digitalslacker's Avatar
    no problem!
    11-23-2011 02:43 PM
  8. Paul627g's Avatar
    @digitalslacker, thanks for posting... I've been busy doing all the family holiday stuff and fell a little behind the ball on getting this up..
    Thanks again.
    11-23-2011 03:54 PM
  9. charn65's Avatar
    Any idea where they hid the long press feature? I've been searching for an hour now...
    Sent from my Nexus S 4G using Tapatalk
    11-23-2011 06:55 PM
  10. digitalslacker's Avatar
    not exactly sure what the long press settings are...
    but they are probably under Settings > Language & input > Android Keyboard (settings on the right)
    bunch of settings in there and you can hit advanced at the bottom for a few more.
    i hope that helps!
    11-23-2011 07:18 PM
  11. charn65's Avatar
    i hope that helps!
    Sorry for the obscure reference long press for the back key, so you can kill app, instead of hitting back button over and over. I looked in that area, so it must be a feature not included yet.
    Awesome so far otherwise!
    11-23-2011 08:36 PM
  12. betachains's Avatar
    For the past couple of days, I spent a lot of time playing with all (?) 3 of the new ICS builds. With various patching contortions, I got most of the functions working. I even tried an additional kernel flash topaly around with overclocking.
    Bottom line: none of them are close to prime-time, compared to my daily CM7 nightly, slight OC, slight UV. It's not just the missing features, but the speed and responsiveness.
    It is very early, and I thank all the devs for putting ICS out in several flavors already. But as of right now, stick with Gingerbread.
    11-24-2011 02:16 AM
  13. digitalslacker's Avatar
    This build is my daily driver now, but I'd be kidding myself if i said it was stable. Few reboot and battery pulls since yesterday morning. But I'm OK with that, I got ICS!
    Some great work by all the dev's working on this...I'm gonna try to stick with ICS until it's officially released, or I get a GN, which ever comes first!
    11-24-2011 06:45 AM
  14. simon.ponder's Avatar
    I thought that was a CM feature, that some other ROMs also have. I didn't think that was an AOSP item.
    11-24-2011 07:15 AM
  15. charn65's Avatar
    I'm not sure if its specific to CM, its in the last couple Oxygen ROMs though.
    11-24-2011 07:45 AM
  16. digitalslacker's Avatar
    You can always long press the home button and the selectivlely kill any app by swiping it left or right.
    Long pressing the back button to kill was never an AOSP feature but it was picked up from CM by several custom ROMs. I'm sure we'll see it resurface as work continues on CM9 and these early ports stabelize and new custom flavors are released.
    charn65 likes this.
    11-24-2011 08:58 AM
  17. DeathsArrow's Avatar
    It's a ROM specific feature and not part of the stock gingerbread build.
    11-24-2011 10:07 AM
  18. Paul627g's Avatar
    Great build so far.. Everything seem to be working very well... Can't wait until official release so things will really get interesting... Until then this will work just fine
    11-24-2011 01:44 PM
  19. digitalslacker's Avatar
    for the daring here is a test build based off of Koush's latest Alpha 9 build
    xda-developers - View Single Post - [ICS] [AOSP] [Nexus S 4G] Koush's Build for CDMA Nexus S 4G
    I've been running it since this morning...one or two reboots...overall pretty good though
    I'm also running the latest Matrix Kernel for ICS which supports Over Clocking
    [KERNEL]*Matr1x* with BLN and voodoo v11.0 | ICS - xda-developers
    that might be the reason for the reboots
    11-25-2011 09:40 AM
  20. simon.ponder's Avatar
    Using GLaDOS release 5 for ICS(put that on the rom this morning), no reboots since I threw the v9 on my phone last night. OC to 1400, if so desired, although I have only pushed it to 1100. BLN works, just not blinking BLN, missing liblights or something. DEEP-IDLE, etc, etc. See post below:
    [KERNEL][24 NOV] GLaDOS for ICS - xda-developers
    The one thing I did notice, was that with stock build of Koush's alpha v9 on CDMA has the ability to set data limits in the data usage section. After the kernel, no dice. I have reported that, but since with sprint having unlimited Data, it is not as big of concern to me as a snappier ROM is.
    11-25-2011 02:25 PM
  21. charn65's Avatar
    I hope Sprint never takes that away from us, unlimited data that is...
    Right now, its the only thing distinguishing them from the other big two carriers.
    11-25-2011 05:01 PM
  22. chud's Avatar
    That doesnt kill the app, it just removes it from the list.
    11-25-2011 08:29 PM
  23. m3grady2's Avatar
    i get constant boot loops when installing v9
    11-25-2011 09:57 PM
  24. piaband's Avatar
    If they do, I will go to Verizon. Sprint service has gotten a lot worse over the last year by me.
    11-26-2011 02:49 PM
  25. ip_freely's Avatar
    +1
    Sent from my Google Nexus S 4G using Tapatalk
    11-26-2011 04:38 PM
32 12
