Upgrade to 5G: Save $50 on the unlocked Pixel 4a today
- Forum
- Google Hardware, Services & Apps
- More Google Devices & Services
- Google / Samsung Nexus S Forums
- Sprint Nexus S 4G
- Sprint Nexus S 4G Rooting, ROMs, and Hacks
[ROM][WIP][ALPHA][NS4G] oICSv43 | AOSP 4.0.3 (ICS)
- I'm running v43 now, was running Peter Alphonso's rooted stock GB ROM previously.
Does anyone else find this a little sluggish as compared to GB? It takes quite awhile for gmail and such to start up.
Also, my email and text notifications don't stop, the ringtone just keeps going until I view the notification. Is there a way to turn that off?12-27-2011 06:52 PMLike 0 - I'm running v43 now, was running Peter Alphonso's rooted stock GB ROM previously.
Sent from my Nexus S 4G using Tapatalkcrzycrkr likes this.12-27-2011 07:43 PMLike 1 - I'm running v43 now, was running Peter Alphonso's rooted stock GB ROM previously.
Sent from my Nexus S 4G using Tapatalk12-27-2011 07:54 PMLike 0 - The kernel that aosp posted in the xda thread...Eugene's 3.1.5 kernel that aosp asked people to try is running very smooth on my phone all day today. Ucd it to my usual dd setting of 220/880 using smartassv2 I've gone all day....on the initial flash with good batt results already(10+ hours with 2-3 screen on time phone still at 30% before I put on charger)
And still 2100+ quads at that setting
Sent from my Nexus S 4G using Xparent Cyan Tapatalk12-27-2011 08:51 PMLike 0 - Another question. My WiFi icon has something flashing on it, and even though the location is "saved", it doesn't connect automatically after a reboot.
My router is not secured, so there's no password or anything like that... What could the issue be?
It was working fine before.gutt3 likes this.12-27-2011 10:44 PMLike 1 - BlackHawkA4Drop the BagVery annoying when the screen is dim because its dark then gets bright for no reason.12-28-2011 05:39 AMLike 0
EDIT: Also, in regards to my previous post about bluetooth, it still isn't sending song info to my radio on version 43 either.12-28-2011 08:50 AMLike 0 - I've noticed lately that every so often my signal bars turn gray, and they no longer indicate 3G or 1x. When this occurs I can still send and receive texts and calls, however I cannot use data, so browser, tweetdeck, and basically anything that uses data will not function. Seeing as I've both updated to v43 AND switched to matr1x 13, I don't know which is causing this. The only method that alleviates the problem is rebooting the phone which is obviously inconvenient. Since I switched both at once (full wipe before anyone asks, including formatting boot, etc.) I don't know which update this problem could be attributed to. If anyone else has this problem could you tell me your set up or a way you fixed it? That would be greatly appreciated! Thanks!
Edit: Switching airplane mode off and on didn't fix the problem. Only a full reboot fixes it.
Sent from my Nexus S 4G using Tapatalk12-29-2011 02:14 PMLike 0 -
- I loaded this rom and the only issue I had was that the gallery and music app, did not recognize my internal storage and could not see my music or pictures. The files are visible in root explorer or other file managers, Anyone else experiencing this or have a fix, I am using the stock kernel?12-29-2011 03:50 PMLike 0
Sent from my Nexus S 4G using Tapatalk12-29-2011 04:04 PMLike 0 - I'll have to restore my Nandroid of it and see (had to go back to GB since its my work phone too), seems like I rebooted and it still didn't see it but I will check.12-29-2011 04:07 PMLike 0
- Decided to take this build for a spin (with Matr1x 13.0). Did a full wipe, etc. Went swimmingly for about 24 hours, then my phone locked up and I had to do a battery pull. Then it wouldn't boot. Kept locking up on the (really cool looking) boot animation. So I nandroided back to GB but have a new issue. I can't boot into recovery now. I just get the robot with the exclamation point, so I can't even try to re-flash ICS again. Any ideas on what either I or it did/am doing wrong?12-29-2011 11:06 PMLike 0
- Paul627gAC Moderator All-StarDecided to take this build for a spin (with Matr1x 13.0). Did a full wipe, etc. Went swimmingly for about 24 hours, then my phone locked up and I had to do a battery pull. Then it wouldn't boot. Kept locking up on the (really cool looking) boot animation. So I nandroided back to GB but have a new issue. I can't boot into recovery now. I just get the robot with the exclamation point, so I can't even try to re-flash ICS again. Any ideas on what either I or it did/am doing wrong?
http://forums.androidcentral.com/spr...-recovery.html
Area your interested in is below...
-Download THIS FILE and place in platform-tools on your PC
-In CMD
Code:
fastboot flash recovery recovery-clockwork-5.0.2.0-crespo4g.img12-30-2011 12:53 AMLike 0 - actually i wound up updating ROM manager, then reflashing CWM from there. Works fine now. As far as ICS locking the phone, its actually happened twice. I suspect its an issue with the Kernel, my phone gets unstable at CPU speeds and voltages where it used to be rock solid before. I got it all set back up how I wanted and made a Nandroid backup right away. If it happens again Im going to try a different kernel, for now Im going to leave voltages alone and be less agressive on the clock settings.12-30-2011 01:29 AMLike 0
- well after about 12 hours the phone randomly locked and went into a boot loop like 5 or 6 times. when it finally booted up it wouldn't wake from sleep so I had to nandroid back again. weird that it seems to happen about every 12 hrs and the phone completely breaks. time to try a different kernel and hope that does it, because I really don't want to go back to gingerbread now that I've tasted the Ice Creamy goodness.12-30-2011 07:57 PMLike 0
- well after about 12 hours the phone randomly locked and went into a boot loop like 5 or 6 times. when it finally booted up it wouldn't wake from sleep so I had to nandroid back again. weird that it seems to happen about every 12 hrs and the phone completely breaks. time to try a different kernel and hope that does it, because I really don't want to go back to gingerbread now that I've tasted the Ice Creamy goodness.12-30-2011 08:51 PMLike 0
- Yeah Im leaning towards kernel not getting along with my phone. Not sure what else to try instead yet.12-30-2011 11:27 PMLike 0
- Speaking of that (and I agree) really cool looking boot animation- any way to make THAT a live wallpaper for us to download or is that sucker too much of a battery suck? (maybe drop the framerate?)
The stock nexus s boot up would be cool too.12-31-2011 02:47 AMLike 0 - Yeah Im leaning towards kernel not getting along with my phone. Not sure what else to try instead yet.
Thebullfrog,
If you think you are having kernel issues with this rom, try Eugene's 3.1.6 speedy 2, its in xda under our phone. I have switched to that based on aosp's recommendations, running it at developers stock settings and getting very good performance and best battery life I have seen. All reports in the thread have been nothing but positive, everything works.
Matrix 13.0 had been very good for me, but this is running better on my phone with aospv4301-02-2012 08:37 AMLike 0 - I'll give that kernel a look. I know now for sure that's the issue. If I dont overclock at all its perfectly fine. For some reason it gets really unstable even at 1.2 when I used to be able to run 1.4. That being said, at stock speed my phone runs much smoother than it ever did on GB. I really love this ROM.01-04-2012 02:33 AMLike 0
- Forum
- Sprint Nexus S 4G
« Cannot update?
Overclocking »
