I uninstalled Wallet with Titanium and then did a fresh install of it through the Market. Used it at the store with no issues.
I'll give that a shot. Was thinking about it. Wasn't sure if Wallet would even install through the market after it being it was an OS Update thing only. Thanks for the head up.
Uh, I just tried the CM9 Kang because my GPS is still buggy on here. Same problem over there. Went back to stock for like 30 seconds. GPS worked fine. Just couldn't stay on GB. I'm back on this build again.
Edit: removed wallet with adb and installed from the market. Adding card failed. Retry worked. Seems to be working.
if anyone was wondering, flash works now with the newest update....its not the greatest, i got some flash games to work but flash video i have yet to see work properly.
i dont know what to say about my device other then its stock oicsv26 with dalvik at 48
Is GPS fixed in the new version? It's the only thing that doesn't work for me and it's enough to make me go back to GB.
I went back to GB because of this too; but, then: couldn't stand it so came back. Somewhere along the lines, though, my GPS started working on v26 before I even went to v27.
Are you on GB already? This may sound asinine and like black magic voodoo stuff; but, if your not: back up v26, go to GB, go back to v26, and update to 27. Or you could just try 27 and see if works.
I was still buggy on 26 but it seems to work fine for me on 27.
Not on GB yet. Still investigating my options. I think I will take your advice and go to GB and back to v27.
Nice to hear.... Setting up v29 right now Restoring all my stuff via MyBackup Pro...
Edit: I still can't get wireless tethering to work but I can get wired tethering to function. So were getting somewhere ...
I know all this will probably be resolved once official becomes available...
A couple fc on the launcher and on the gallery doing nothing special. Mms was sketchy yesterday but that could of been sprints network. 2 random freezes that turned into random reboots. Back to v26 until he releases his 4.0.3 build he's working on now.
Hi there, I first want to say fantastic job on the ROM. I am running v26 and it's very stable. I tried loading v27 yesterday, however google talk kept crashing whenever I loaded it, so I could not get into the market app. So, I reverted back to v26. Can you tell me if the issues with Google talk were resolved? I did full factory reset and wipe of cache as well as tried all the solutions posted here, but could not get it to work yesterday.
Sent from my Nexus S 4G using Tapatalk
Strange. I dont know about the mms but i wasnt able to send them before only receive them with the other builds.
No fc or anything here? Were you overclocked? If you were garantee thats the issue with the reboots.
v36 up and posted on xda. All reports are looking good, a few issues (probably due to phone setups)
I have downloaded, flashed, and got everything up and running.
I have GPS, I have not checked 4g (don't have because of Sprint, not phone), don't care about Wallet,
but everything else is up, snappy, etc. except Wifi, so will look into that, but it wasn't working before either.
I'm running stock, no oc, no tweaks, stock kernel, no changes. Just want to see how it is meant to run before I start tinkering.
Yeah this is the version i've been waiting for. Everything works, calendar syncs correctly and shows in the widget also. 4g works and theres a widget for it too nice.
