02-17-2012 07:45 AM
279 ... 45678 ...
tools
  1. Paul627g's Avatar
    Yep brightness is noticeably dimmer....
    Maybe something the devs can tweak in the future.
    12-18-2011 07:25 PM
  2. BlackHawkA4's Avatar
    I like it. Easy on the eyes. Better on battery too. Was too bright before.
    12-18-2011 07:36 PM
  3. CD_XX's Avatar
    Im having and issue with flash. Is shows Flash Player installed but flash sites do not show in browser. Any fixes for this issue?
    12-18-2011 07:58 PM
  4. pitmasterme's Avatar
    Uninstall and redownload from market
    Long days and pleasant nights............
    12-18-2011 08:05 PM
  5. CD_XX's Avatar
    It does not show an uninstall option in the market.
    12-18-2011 08:21 PM
  6. pitmasterme's Avatar
    U have to use a root enabled file explorer like es file explorer or root explorer.....or just use titanium backup to uninstall
    CD_XX likes this.
    12-18-2011 08:35 PM
  7. Skunkape60's Avatar
    Not having any luck with this build. originally flashed without wiping data. Had lots of forced closes, app tray started very laggy, then all icons would stack on top of each other and the updated su wouldn't grant su to any of my apps.
    Wiped all data redownloaded all files and reflashed everything. No different at all. Same issues exactly.
    I ended up back on gingerbread. Don't know why but my phone doesn't like this version at all.
    Sent from my Nexus S 4G using Tapatalk
    12-19-2011 07:55 AM
  8. Brianbgrp's Avatar
    I'm stable as hell on v36 with Pauls 1% mod. Xda wont load up for me atm...there a new version?
    12-19-2011 08:01 AM
  9. Paul627g's Avatar
    New version is available... v40 !
    Yes see above and XDA was down for maintenance...
    12-19-2011 08:20 AM
  10. Paul627g's Avatar
    v40 seems snappy, Superuser is built in now.
    My personal setup is running with GlaDOS v2.0.1 kernel set at OnDemand with stock CPU settings.
    12-19-2011 09:23 AM
  11. Brianbgrp's Avatar
    I tried to put glados bfs on my v36 and just got boot loops...phone would load up....then go back to the bootanimation ans stick. at work so can't swap to v40 yet.
    Edit* btw Paul...thanks for the 1% battery mod too. Hate not having it and bugs me to be on any from without it lol
    12-19-2011 09:37 AM
  12. pitmasterme's Avatar
    Try cfs....... usually more stable for most phones. I haven't ever had any luck with any bfs kernels from any dev.....
    12-19-2011 10:29 AM
  13. Brianbgrp's Avatar
    Ya...just got CFS and up and running...no probs so far. Haven't touched anything in nstools yet. Anyone know if deep idles working yet?
    Edit** with this kernel ICS feels incredibly snappy...things seem to load up at a thought. Pretty impressed already.
    12-19-2011 10:31 AM
  14. Skunkape60's Avatar
    I will have to try v40 when I home tonight. The previous version was awful on my phone.
    12-19-2011 10:34 AM
  15. Paul627g's Avatar
    NSTools is still pretty much broken at this point.. The devs of all these apps like Voodoo, NSTools, etc. are probably all in the process of updating things to gel with the new Android 4.0.3.
    Few days from now or sooner it will probably be all fixed and we will be happy
    12-19-2011 10:47 AM
  16. Paul627g's Avatar
    Here is an application that just was released... Specifically for this ROM. Its an update app available from the Market for free to notify you of updates, change logs and links to download the ROM.
    Very cool and something you should have on your phone if your running this ROM.
    https://market.android.com/details?i...aospoics&pli=1
    12-19-2011 11:14 AM
  17. Brianbgrp's Avatar
    OK still on oics36 with glados 2.1 just flashed. Things still running great but I can't seem to uc at all. Drop it to 200/800 and phone immediately freezes. I can Oc it without any issues.
    If I wanna swap to v40 I'll have to prolly full wipe I assume right?
    Sent from my Nexus S 4G using Xparent Cyan Tapatalk
    12-19-2011 02:01 PM
  18. Paul627g's Avatar
    Some have done it without a full wipe and been okay by just wiping dalvik....
    YMMV.....
    I would recommend the full wipe but if your feeling lucky...
    12-19-2011 02:10 PM
  19. Brianbgrp's Avatar
    Ya... tempted to try it to bypass setting everything up again lol. But I dunno.
    On a lighter note...thank god for voodoo colors lol. So nice to have em back
    12-19-2011 02:14 PM
  20. Paul627g's Avatar
    Yes love them colors..
    12-19-2011 02:15 PM
  21. tyea's Avatar
    Hi--first-time-flasher. I've been using version 36 for a few hours and I'm really enjoying it. Thanks for the quality work! I think I will donate.
    12-19-2011 03:00 PM
  22. BlackHawkA4's Avatar
    I've had one issue so far and that was with the dialer FCing after making a phone call and then trying to dial another number. Only happened once. See what happens.
    12-19-2011 05:37 PM
  23. grantheppes's Avatar
    Giving this Rom a shot. Been waiting for an ICS rom with 4G. Titanium Backup is putting my apps back on my Nexus as I type. Will give an update in 24Hours. May be picky, I love stock rom with Matr1x Kernel.
    Sent from my GT-P6210 using Tapatalk
    12-19-2011 07:55 PM
  24. Brianbgrp's Avatar
    Just confirming...went from 36 to 40 just by flashing through from manager and wiping dalvik. Letting it boot back up then went back and reflashed glados 2.1 then Pauls battery mod.
    Everything works perfectly so far. Finally got quadrant to run the moon test higher than 10fps with this build too.
    12-19-2011 08:55 PM
  25. Skunkape60's Avatar
    still can't get the damned root to work with ics. Took me 30 minutes to sign into my google account because the initial setup kept FC. Complete data wipe, cache wipe x3, dalvic wipe x3, morfics dalvic wipe x3. Flashed rom & rebooted, flashed su 3.0.7-d-sighed.zip. Still no damned root... So freakin tired of ICS (Ice Cream Sucks). If I can't get this to work in the next 30 minutes I am done with ICS.
    for the 10th time in 15 minutes the launcher fc.
    12-19-2011 10:52 PM
279 ... 45678 ...
Tags for this Thread
