02-17-2012 07:45 AM
279 ... 56789 ...
tools
  1. pitmasterme's Avatar
    still can't get the damned root to work with ics. Took me 30 minutes to sign into my google account because the initial setup kept FC. Complete data wipe, cache wipe x3, dalvic wipe x3, morfics dalvic wipe x3. Flashed rom & rebooted, flashed su 3.0.7-d-sighed.zip. Still no damned root... So freakin tired of ICS (Ice Cream Sucks). If I can't get this to work in the next 30 minutes I am done with ICS.
    for the 10th time in 15 minutes the launcher fc.
    Sorry to hear of your issues....couple things...when you are wiping data and all are you also formatting data, boot, cache etc.....( snandal's wipe all zip is great!)
    Are you flashing v40? If so, su has been fixed, no need to flash su zip.....plus I, think 3.0.7 is old..... Its been updated again....
    Long days and pleasant nights............
    12-19-2011 11:54 PM
  2. Paul627g's Avatar
    Actually SU 3.0.7 is the most recent. I suggested to him to restore a GB backup or flash a GB ROM and see if he still indeed has root access or could of lost it somehow...
    12-19-2011 11:59 PM
  3. pitmasterme's Avatar
    Ahhhh....sorry. must have misread.....
    12-20-2011 12:08 AM
  4. Skunkape60's Avatar
    Just a heads up. Do not flash su over this rom or you will not get proper root. Finally tried it without flashing the su over the rom and it worked. Doh....
    12-20-2011 12:28 AM
  5. Paul627g's Avatar
    No problem... The way things have been getting updated last few days its easy to miss something....
    12-20-2011 12:29 AM
  6. pitmasterme's Avatar
    Good! Hopefully you enjoy a great experience like I have had since beezy's sdk builds!
    12-20-2011 12:35 AM
  7. Skunkape60's Avatar
    Still too laggy. Until the lag in the app tray is fixed I will stick with GB. Also several of my must have apps don't work on ICS yet. Emailed the Dev asking when or if an update to run on ICS was coming.
    My issue with the app drawer is two fold. first is the lag. I scrowl up or down and it pauses a good 2 seconds before it starts to respond to my inputs. Second, the app icons trends to stack on top of each other where it is impossible to open or even tell what app is on top of the pile. Only a restart fixes it and only for a few times into the app drawer. Usually starts happening after the 2nd or 3rd trip to the drawer or immediately after waking the screen after sleep.
    I have real funny feeling that ICS will never be as fast or smooth as
    GB. Think the software may be too much for the hardware on our phones. Hopefully this isn't the case but if it is, I'm completely ok with that as I prefer the interface on GB over the interface on ICS. GB so far handles launcher pro much better than ICS does now and probably always will. Just don't like pure google launcher on any of the current google versions. So I will most likely always be using a launcher overlay until google makes their launcher with much more configuration options.
    Sent from my Nexus S 4G using Tapatalk
    12-20-2011 08:03 AM
  8. jpirog's Avatar
    I'm using the glaDOS 2.1 kernel with this rom, and it has the voodoo settings built in. (So I've read)
    How do I get to the voodoo options (sorry, still relatively new to android coming from webOS).
    What exactly is voodoo for, and I assume it has some settings to solve the green flash of my screen?
    12-20-2011 08:30 AM
  9. Brianbgrp's Avatar
    Download voodoo controls app from market by super curio. It go es you better sound control and rgb/Gama control.
    Sent from my Nexus S 4G using Xparent Cyan Tapatalk
    jpirog likes this.
    12-20-2011 08:35 AM
  10. pitmasterme's Avatar
    That's too bad. I've been running ics since the sdk port and aside from one or twice, haven't gone back to gb.. I find ics to be way better than GB and only expect more of the same once official update comes.
    I had tried launcher pro also and found that it didn't care for ics at the time(couple weeks ago) but adw ex is extremely slick....but since I prefer the folder option on the dock in the stock launcher(which blows away any previous stock launcher) I'm currently running Nova launcher.....smooth as silk.
    maybe your phone just won't like ics and you'll be stuck on GB forever......unfortunate for you...
    12-20-2011 09:42 AM
  11. _DammitMan_'s Avatar
    oICS v41 is now available. I just updated from v40 (only wiped Dalvik this time). So far, so good.
    12-20-2011 10:28 AM
  12. Skunkape60's Avatar
    I haven't found anything I like on ICS that I like better than GB with the exception of the settings menu. Which I think is laid out better on ICS. Other than that, I don't see much reason ICS is better. As of now GB is much faster and much more stable. Plus all my NEEDED apps work on GB. Since I will always be running a launcher overlay (I hate the stock google launcher on all versions and the ICS app drawer is ugly and the gallery is hideous) I don't see any benefits of ICS. Perhaps that will change as time goes on but until my launcher and ICS learn to play well together and ICS becomes faster, smoother and stabler than GB, I have to use what works best for me and my phone. So far GB has been the best for me.
    12-20-2011 10:51 AM
  13. Paul627g's Avatar
    OP updated.....
    v41 with Changelog...
    12-20-2011 11:13 AM
  14. Paul627g's Avatar
    Running v41 for a little under an hour now but as aosp claims, the launcher its definitely more crisp and responsive.... I really think he has this build nailed down now....
    Just for bragging rights.... GlaDOS 2.1 running at 1400 OC. Looks like were starting to get some real speed out of these kernels.
    12-20-2011 11:23 AM
  15. Brianbgrp's Avatar
    Nice..on v40 with glados.. lazy 200/1k with 10% live OC I was getting 2048 quadrants. When I update to 41 here in a few hours I'll see what I can top out at.
    Edit - v40 with glados at 1400 quadrant. No 41 till wifi after work.
    12-20-2011 11:35 AM
  16. BlackHawkA4's Avatar
    Is there a problem with the weather app on this rom; or, is the weather service down from Google. Mines not loading at all. I had problems on the previous builds were I'd have to refresh it several times before it displayed. This one is just not working at all. I cleared out all the data and relaunched it. Still no luck.
    12-20-2011 04:30 PM
  17. Brianbgrp's Avatar
    Hmmn got home and flashed to 41.. then put on glados 2.2 which just showed up.. and my fpS went to 10 again on quadrant planet after being 65 fps on 40/2.1. However launcher is lag free and phone runs amazing
    12-20-2011 05:44 PM
  18. _DammitMan_'s Avatar
    I just downloaded glados 2.2 as well. The CFS version. I haven't applied it yet though. Which are you using?
    12-20-2011 05:51 PM
  19. Skunkape60's Avatar
    Click to view quoted image
    That's pretty darn slow... ;p
    My under clocked nexus will do better than that. But of course I'm on GB ROM. ;-)
    12-20-2011 06:02 PM
  20. Brianbgrp's Avatar
    i'm using the cfs versions. my phone has yet to use a bfs kernel for anything. and yeah...it's strange. i was getting 10fps on the planet test on v36 with 2.01. then when i swapped to 40 last night...not sure what else I changed, but I was getting 65 fps constant on the planet earlier on the test i screen shotted and every other test i ran at work today. came home, wiped cache/dalv/data. factory reset. flashed 41, flashed pauls 1% mod, flashed 2.2 kernel. booted up. titanium backup my apps and such, then rebooted. ran quadrant and can't break 10-13 fps now.
    at my "everyday" settings of 200/1k with 10% oc though my quadrant scores with this setup are in the 2200s, despite the horrid fps on that damn planet.(compared to 2k with the good fps setup) can't complain though, haven't had a single force close on the launcher or anything in the past hour of playing with it.
    *edit* lol, i could care less about how fast the quadrant says it is...it's just for fun and to compare to what other people have so I can tell if i'm doing something wrong so long as the phone feels snappy and runs well, i'm a happy camper.
    12-20-2011 06:07 PM
  21. Zeek19's Avatar
    For some reason after I installed I couldn't install any apps from the marketplace. Not even amazon would download any apps. I could manually install an apk though...
    12-20-2011 06:44 PM
  22. crzycrkr's Avatar
    There's fixes for this. Try clearing data for the market.
    12-20-2011 06:47 PM
  23. Zeek19's Avatar
    I had to go back wipe everything out again and reinstall, wait for it to sync all of its google data and it finally worked..For some reason when I installed the first time the market had odd results in the my apps section. All is good now!
    crzycrkr likes this.
    12-20-2011 06:53 PM
  24. Brianbgrp's Avatar
    hmmm just an update, according to ZiggSVO my fps problems was something to do with a lib...
    libGLES_android.so in system/lib/egl. i renamed it just to test and my quadrant planet shot back up to 50 fps or so and back up to 2800+ quadrant scores at 1400 with 2.2 glados. just passin along what i learned in case any were wonderin
    Time to go find out wtf libGLES_android.so is now, so I can tell if I should leave it renamed and inactive, or if i should put it back the way it was and not care about my low fps
    12-20-2011 07:38 PM
  25. Brianbgrp's Avatar
    hmmmm. sorry for double post, but totally switching frames for a sec. any of you guys tried morfics test Teuv kernel yet with oics? i was using his on my c02 1.1 setup and the battery life + performance for a uc/uv kernel was amazing. tempted to give this a go, but figured id ask you guys. may just wanna wait for a closer to final oics version before playing with kernels too much...and GladOS is rocking
    12-20-2011 08:23 PM
279 ... 56789 ...
Tags for this Thread
