pardon the ignorance. This is my first time rooting and i want to get it right. I unlocked my bootloader and gave myself superuser priveledges. yesterday
Anyway i just dowloaded the java and the android sdk, I subsequently updated it. I am following the instructions in the sticky from: "http://www.androidcentral.com/unlock-bootloader-and-install-su-and-cwm-nexus-s-4g-forums"
I am on the step where is says to:
"go into the Settings menu, then choose Applications > Development > USB Debugging. After you've done that, plug your phone into your computer and let it try to install all the drivers. It'll mostly succeed, but something will be missing. This is where PdaNet helps us out."
I installed pdanet on my windows pc because I saw it as a prerequisite instructions. I believe that it already installed necessary samsung drivers. My issue is that when I plugged my phone in to "let it try to install all drivers" I did not see that occur.
Is that normal? Am i safe to proceed in getting adb? Any help and insight is much
i want to flash dooderbut's 4.0.3 ics rom. and i am trying to install custom recovery so i can proceed with his instructions. as i said i have an unlocked bootloader and superuser privilidges.
pls help!!!!! i want to have ics goodness
