- Forum
- Google Hardware, Services & Apps
- More Google Devices & Services
- Google / Samsung Nexus S Forums
- Sprint Nexus S 4G
- Sprint Nexus S 4G Rooting, ROMs, and Hacks
Could really use some help with unbricking my Nexus
- So after installing an ICS rom and encrypting my data I decided to swap roms again. So I did a full wipe and when I tried to install a zip from my SD card I get an error saying that it cant access the SD card. I've tried wiping, mounting, and restoring a backup but I cant access anything on my SD card partition. I tried the one click return to stock but because I cant actually get my phone past the bootloader there isn't much I can do. Is there something else I can try before I try and get the (un)helpful folks at sprint to take a look?01-21-2012 06:08 PMLike 0
- Paul627gAC Moderator All-StarTry this.. Download the package...
Pete Alfonso, stock images (OS)
From bootloader you would use this package...01-21-2012 07:38 PMLike 0 -
- I've done the same thing by mistake before. your going to have to wipe the SDcard partion via your PC and go from there.01-21-2012 08:59 PMLike 0
- Try this.. Download the package...
From bootloader you would use this package...01-22-2012 08:31 AMLike 0 - Paul627gAC Moderator All-Star
I have provided a zip file for you to download.
Return to Stock
1. Extract the contents
2. Use the complete folder "Return to Stock" and place it on your C:/ drive
3. Take the images/files from that Pete Alfonso download I provided earlier and place all those inside of that Return to Stock folder.
4. Connect your device via USB cable and boot into your Bootloader menu.
5. Click on the Command Prompt.bat file inside the Return to Stock folder
6. Enter in one by one the commands below pressing return and waiting for the flash process to happen before moving onward to the next command
Code:fastboot flash boot boot.img fastboot flash system system.img fastboot flash recovery recovery.img fastboot flash userdata userdata.img fastboot erase cache fastboot oem lock
01-22-2012 04:52 PMLike 0 - I have provided a zip file for you to download.
Return to Stock
01-23-2012 12:50 PMLike 0
- Forum
- Sprint Nexus S 4G
