1. YUCATEx's Avatar
    This is my 1st attempt trying this..I would like to put back 4.0 ics back on. How do I even get started? Hello to everyone...
    07-12-2012 07:22 PM
  2. Paul627g's Avatar
    Could you tell me your current status? Rooted, what version of android?
    If you want to get to stock ICS 4.x you can use the sticky above too restore to stock and then receive the OTA updates up too ICS.
    Sent from my Nexus S 4G using Android Central Forums
    07-12-2012 09:21 PM
  3. fguills's Avatar
    Did it use toilet paper or a wipe?
    Sent from my SPH-D700 using Tapatalk 2
    fomotomo likes this.
    07-12-2012 09:32 PM
