1. James Arden's Avatar
    I currently own a Samsung Nexus S 4g from Sprint running ICS 4.0.4. I have attempted to root my nexus s 4g with clockworld mod and twrp, but I have had no luck. I used the root checker and it told me that this device does not have the proper root access. Currently, I have the TWRP 1.1.1 recovery that I am running on. Is there anything else that I can do to get my phone rooted so I can install jelly bean? Any help is appreciated. Thanks.
    James Arden
    08-12-2012 10:11 AM
  2. moonoverparma00's Avatar
    Qbking77 does a good video on YouTube showing how to root. Have you checked that out? Its how I learned how to do all this stuff.
    James Arden likes this.
    08-12-2012 10:18 AM
  3. James Arden's Avatar
    Thanks, I will check that out.
    James Arden
    08-12-2012 10:54 AM
  4. mschooler93's Avatar
    Having recovery is not good enough for root. You have to flash superuser.zip with twrp.
    I'm sorry, but I don't have any links to dl it, just Google superuser nexus s 4g and you should find it. It should be in a .zip format, put it on the root of the SD card/USB storage (not in a folder, just on it) then go to recovery and find flash zip from SD card, find the superuser.zip, wait for it to do it then reboot. You should now be rooted.
    Sent from my Nexus S 4G using Tapatalk 2
    08-19-2012 12:02 AM
  5. WillDaBeast509's Avatar
    Find Nexusshacks's tut on YouTube, its what I used. You use the 'fast OEM unlock' command from the console, but I don't remember the details.
    Sent from my Nexus S 4G using Android Central Forums
    08-19-2012 12:28 AM
  6. James Arden's Avatar
    Thanks for all the posts. I finally got my ns4g rooted and jelly bean installed. Only problem I have ran into is now my voicemail doesn't work. Any suggestions?
    08-22-2012 11:42 PM
  7. philb#AC's Avatar
    Google voice
    sent from Amazon Fire running jellybean with taptalk2
    08-29-2012 03:02 PM
  8. lyingfromyou's Avatar
    Hit Phone Icon>Menu Button>Settings>Voicemail>Setup
    Then Change To Your Area Code & Number! Viola!
    08-29-2012 04:47 PM
