1. cardude10's Avatar
    Can anyone recomend a rom with kernel combo for great battery life. I have tried few of the ICS ROMS and battery life needs room for improvement.
    Had great battery life on gingerbread but ever since ics battery drain is worse
    08-12-2012 05:09 PM
  2. kevincwelch's Avatar
    My recommendation is CM9. After that, Pool Party with Matrix kernel.
    Both have been solid for me.
    You also could give a jelly bean ROM a try. This one is very nice on the battery.
    08-12-2012 07:17 PM
  3. p7486w's Avatar
    NexusMV4G Rom with the Matrix Kernel works great for me.
    08-15-2012 04:53 PM
  4. skinneejay's Avatar
    Peter Alfonso's Bugless Beast has been the best for me.
    08-16-2012 04:23 PM
  5. Noetic_Nick's Avatar
    I've been using Crossbones ROM with either the Martr1x kernel or the Crossbones Kernel. I think Mart1x has better battery efficiency.
    09-06-2012 08:43 AM
  6. 6tr6tr's Avatar
    CM9 has been pretty good for me. Not perfect, but a definite improvement. (I turn on deep idle)
    09-06-2012 03:18 PM
