1. Label facing right's Avatar
    So I'm trying to root my NS4G and am following this but from what I've seen all of the rooting guides are pretty much the same. Anyway, everything goes fine up to the point where I need to mount the phone as USB storage device from within clockwork, it just sits there, my phone says it's in USB storage mode however my computer will not recognize it. Anyone else having this problem or know what to do to fix it?
    05-12-2011 11:01 PM
  2. piaa_nissan's Avatar
    I had the same problem, I ended up rebooting and skipping setup and going to mount USB. I installed the file and rebooted into CWM. All the superuser file does is give you permissions to install rooted software so as long as you don't try this before installing SU you should be fine.
    05-13-2011 01:02 AM
  3. KSmithInNY's Avatar
    It doesn't work which is why in my instructions I tell you to put it on the SD prior to going into fastboot
    05-13-2011 06:10 AM
  4. digitalslacker's Avatar
    I had this issue after installing the BFS Netarchy kernel for the NS4G
    the CFS kernel worked fine though.
    05-13-2011 06:54 AM
  5. prehakker622's Avatar
    Ok I have had the same issue, but I just rebooted the device and then installed it when the device went into USB mode. I am now having problems with my NS4G working in USB mass storage mode. When I connect the phone it gives the option to have the phone as a mass storage device, but when this is connected and I try to transfer files to the device it un-mounts itself and freezes up my computer. I don't know if anyone else is having this problem, but some help would be greatly appreciated.
    06-03-2011 12:00 AM
  6. lcpltyler's Avatar
    Ok need help. I rooted my Sprint Nexus S 4g I was playing with roms in the rom manager app. I installed the stock nexus s rom 2.3.3. i lost all ability to connect my phone via usb and yes i do have the drivers installed. in fast boot it says "USB Control Init" and then and the same time this pops up "USB Control Init End" cant re-root or do anything via usb.
    06-12-2011 02:43 PM
  7. hi-tech34's Avatar
    I am having same issue. It will not allow me to usb storage on computer but it will charge?
    07-21-2011 07:10 AM
  8. alaqawari's Avatar
    DId you have any luck fixing your issue? I have the same issue.
    11-18-2011 12:23 PM
  9. hi-tech34's Avatar
    Yes, it is all fixed. Look at the usb port on the phone and there is a tab that hte usb plug slides onto. On mine that tab was pushed over and was not fitting inside the usb plug so I took a small knife and bent it a little so it was more centered and it is all fixed!
    11-18-2011 02:51 PM
  10. lwanmoeoo's Avatar
    hi I need ur help, pls I rooted my Sprint Nexus S 4g I was playing with roms in the rom manager app. I installed the stock nexus s rom 2.3.3. i lost all ability to connect my phone via usb and yes i do have the drivers installed. in fast boot it says "USB Control Init" and then and the same time this pops up "USB Control Init End" cant re-root or do anything via usb.
    I waiting ur help!!!!!!
    12-15-2011 11:10 AM
  11. Skunkape60's Avatar
    do you have pdanet installed on both your computer and phone? It will make it a whole lot simpler.
    Sent from my Nexus S 4G using Tapatalk
    12-15-2011 11:59 AM
  12. hi-tech34's Avatar
    I would try a factory re-set first since you are trying to go back to the stock rom and then you should be back to original and it should work. I don't know much about rooting but this makes sense.
    12-15-2011 02:45 PM
  13. lwanmoeoo's Avatar
    fri what did you mean pdanet to install?
    12-16-2011 03:35 AM
  14. hi-tech34's Avatar
    That allows you to connect to a computer without a USB
    12-16-2011 03:49 AM
  15. Skunkape60's Avatar
    Download pdanet from the market. Download pdanet on your computer. Run the program on you computer. When it says that the Samsung drivers are installed and asks you if you want to reinstall choose yes. Follow the directions and you will get a good link from your computer to the phone.
    12-16-2011 06:44 AM
