1. lsufronier's Avatar
    Hey guys I just ordered my Nexus and I am trying to figure out what is the best way to transfer the pictures I have on my EVO to my new Nexus. Any suggestions? Thanks
    07-27-2011 11:59 AM
  2. scoobdude's Avatar
    Upload the to picassa which will then sync with your Google account. Not the fastest by it is the easiest and you won't lose them if you root.
    07-27-2011 12:05 PM
  3. lsufronier's Avatar
    Okay so once I upload them to Picasa how do I get them saved on the Nexus? Thanks
    07-27-2011 12:24 PM
  4. Tenebrous's Avatar
    The phone will sync to your picasa account automatically so long as your e.mail accounts are the same for your Picasa account and Nexus S 4g phone - just check your gallery on your phone.
    07-27-2011 12:45 PM
  5. AndroidOne's Avatar
    Connect your Evo to your computer via USB (or remove the SD card and use a reader) and transfer all your picks to a folder of your choosing. When your Nexus arrives, connect the Nexus to the computer and transfer them into the built in storage.
    07-27-2011 01:00 PM
  6. gearjunkeez's Avatar
    EDIT: Didn't see post above mine until after i posted. Yeah - what he said...
    Put the sd card into a card reader. Attach the Nexus to your computer as a disk drive/USB storage. Drag and drop. Done.
    07-27-2011 01:03 PM
  7. lsufronier's Avatar
    Okay thanks everyone I appreciate it very much.
    07-27-2011 01:10 PM
