1. darwin2k#AC's Avatar
    I've had the phone about a month now and generally like it. But I have this persistent problem where I can't get a 3G or data connection when moving from a roaming area into a valid 3G/4G area.
    Is there a setting I'm missing where the phone will automatically pick up the signal once I move into a valid 3G zone? Right now the only solution is to power down and back up for the phone to get the 3G connection.
    Thanks in advance for your help/suggestions.
    09-15-2011 04:52 PM
  2. grantheppes's Avatar
    Good luck with finding the solution.
    The only thing I can suggest is messing around with the roaming settings.
    I ran into a similar problem when I was up in the middle of nowhere Vermont, but here in the DC area I never roam.
    09-15-2011 06:47 PM
  3. Makinola's Avatar
    Try changing the roaming settings first. If that doesn't work its best to put the phone into airplane mode wait 30 seconds then disable airplane mode
    09-15-2011 08:31 PM
  4. darwin2k#AC's Avatar
    Thanks for the suggestions. Unfortunately no luck. Only a full power down / reboot cycle will find a 3G signal. Which will prove more fruitful -- contacting Sprint, Google, or neither?
    09-19-2011 12:53 AM
  5. actionjackson22's Avatar
    contact sprint. they'll help you as long as you annoy the **** outta them,
    09-19-2011 10:18 AM
